1384805
1384805
    FESTO(费斯托)
    FESTO - 1384805 - Cylinder, Piston Rod, Double Acting, 100 mm, G1/2, 0.4 bar to 12 bar, 40 mm
1384805 数据手册
ISO cylinder DSBC-100-40-PPVA-N3 Part number: 1384805 General operating condition Data sheet Feature Value Stroke 40 mm Piston diameter 100 mm Piston rod thread M20x1.5 Cushioning Pneumatic cushioning, adjustable at both ends Mounting position Any Conforms to standard ISO 15552 Piston rod end External thread Structural design Piston Piston rod Profile barrel Position sensing For proximity sensor Symbol 00991235 Variants Piston rod at one end Operating pressure 0.04 MPa ... 1.2 MPa Operating pressure 0.4 bar ... 12 bar Mode of operation Double-acting Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) Corrosion resistance class (CRC) 2 - Moderate corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Ambient temperature -20 °C ... 80 °C Impact energy in the end positions 2.5 J Cushioning length 31 mm Theoretical force at 6 bar, retracting 4418 N Theoretical force at 6 bar, advancing 4712 N Moving mass at 0 mm stroke 1000 g Additional moving mass per 10 mm stroke 39 g Basic weight with 0 mm stroke 3665 g Additional weight per 10 mm stroke 101 g Type of mounting Optionally: With internal thread With accessories Pneumatic connection G1/2 Note on materials RoHS-compliant Cover material Die-cast aluminum, coated Piston seal material TPE-U(PU) 5/8/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Material of piston Wrought aluminum alloy Piston rod material High-alloy steel Piston rod wiper material TPE-U(PU) Buffer seal material TPE-U(PU) Cushion piston material POM Material of cylinder barrel Wrought aluminum alloy, smooth-anodized Nut material Steel, galvanized Material of bearing POM Flange screws material Steel, galvanized 5/8/24 - Subject to change - Festo SE & Co. KG 2/2
1384805 价格&库存
很抱歉,暂时无法提供与“1384805”相匹配的价格&库存,您可以联系我们找货
