186150
186150
    FESTO(费斯托)
186150 数据手册
Push-in L-fitting QSLV-G1/8-8-I Part number: 186150 General operating condition Data sheet Feature Value Size Standard Nominal width 4.2 mm Type of seal on screwed plug Sealing ring Mounting position Any Design L-shape Pack size 10 Structural design Push-pull principle Operating pressure for entire temperature range -0.095 MPa ... 0.6 MPa Operating pressure for entire temperature range -0.95 bar ... 6 bar Operating pressure for entire temperature range -13.775 psi ... 87 psi Temperature-dependent operating pressure -0.095 MPa ... 1.4 MPa Temperature-dependent operating pressure -0.95 bar ... 14 bar Temperature-dependent operating pressure -13.775 psi ... 203 psi Operating medium Compressed air as per ISO 8573-1:2010 [7:-:-] Water as per manufacturer's declaration at www.festo.com Information on operating and pilot media Operation with oil lubrication possible Corrosion resistance class (CRC) 1 - Low corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Cleanroom class Class 4 according to ISO 14644-1 Ambient temperature -10 °C ... 80 °C Nominal tightening torque 5.4 Nm Tolerance for nominal tightening torque ± 20% Product weight 22 g Type of mounting Internal hexagon, AF 8 Pneumatic connection 1 External thread G1/8 Pneumatic connection 2 for pneumatic tubing outside diameter 8 mm Releasing ring color Blue Note on materials RoHS-compliant Housing material PBT Hollow bolt material Brass, nickel-plated Releasing ring material POM Material of tubing seal NBR Material of tube retaining claw High-alloy stainless steel 5/29/24 - Subject to change - Festo SE & Co. KG 1/1
186150 价格&库存
很抱歉,暂时无法提供与“186150”相匹配的价格&库存,您可以联系我们找货
  • 1+80.029911+10.37340
  • 10+74.7120210+9.68410
  • 30+69.3941330+8.99480
库存:4
