CTEU-CO
CTEU-CO
    FESTO(费斯托)
    FESTO - CTEU-CO - BUS NODE, 4A, 24VDC, M12X1
CTEU-CO 数据手册
Bus node CTEU-CO Part number: 570038 Data sheet Feature Value Type code CTEU Dimensions W x L x H 40 mm x 91 mm x 50 mm Width dimension 40 mm Type of mounting On electrical interface On electrical sub-base Product weight 90 g Protocol CANopen Fieldbus interface, type CAN bus Fieldbus interface, protocol CANopen Fieldbus interface, function Bus connection, incoming/forwarding Fieldbus interface, connection type Plug Fieldbus interface, connection technology Sub-D Fieldbus interface, number of poles/wires 9 Fieldbus interface, connection pattern 00995639 Note on fieldbus interface Optional connection technology with accessories: Optional connection technology with accessories: micro style (plug/ socket M12x1 A-coded, 5-pin, degree of protection: IP65), open style (terminal strip, 5-pin, degree of protection: IP20) Open style (screw terminal, 5-pin, degree of protection: IP20) Fieldbus interface, galvanic isolation yes Fieldbus interface, transmission rate 125 kbit/s 250 kbit/s 500 kbit/s 1000 kbit/s Internal cycle time 1 ms per 1 byte of user data Max. address capacity inputs 8 byte Information on inputs Extendable to max. 16 bytes Max. address capacity outputs 8 byte Note on outputs Extendable to max. 16 bytes Power supply, function Electronics and load Power supply, type of connection Plug Power supply, connection technology M12x1, B-coded as per EN 61076-2-101 Power supply, number of pins/wires 5 Power supply, connection pattern 00995719 Diagnostics Communication error System diagnostics Undervoltage Parameterization Diagnostic behavior Fail-safe response 6/20/21 - Subject to change - Festo AG & Co. KG 1/2 Feature Value Additional functions Acyclic data access via "SDO" Emergency message Configuration support EDS file Control elements DIL switch LED display (product-specific) PS: operating voltage for electronics and load supply X1: module system status at I-Port 1 X2: module system status at I-Port 2 LED display (bus-specific) IO: I/O status MNS: network status DC operating voltage range 18 V ... 30 V Nominal operating voltage DC 24 V Intrinsic current consumption at nominal operating voltage Typ. 65 mA Max. power supply 4A Certification RCM compliance mark c UL us - Listed (OL) KC characters KC EMC CE marking (see declaration of conformity) As per EU EMC directive Corrosion resistance class (CRC) 2 - Moderate corrosion stress Storage temperature -20 °C ... 70 °C Degree of protection IP65 IP67 Note on degree of protection In mounted state Unused connections sealed Ambient temperature -5 °C ... 50 °C Housing material PA Note on materials Contains paint-wetting impairment substances RoHS-compliant 6/20/21 - Subject to change - Festo AG & Co. KG 2/2
CTEU-CO 价格&库存
很抱歉,暂时无法提供与“CTEU-CO”相匹配的价格&库存,您可以联系我们找货
CTEU-CO
    • 1+2133.73273
    库存:2
    CTEU-CO
      • 1+5039.303831+651.96847
