152609
152609
    FESTO(费斯托)
    FESTO - 152609 - Suction Cup, Round Bellows, 125 mm Dia, 125 mm Effective Dia, G3/8, NBR, VASB Serie...
152609 数据手册
Vacuum suction cup VASB-125-3/8-NBR Part number: 152609 General operating condition Data sheet Feature Value Nominal width 7 mm Suction cup diameter 125 mm Effective suction cup diameter 125 mm Connection position Top Symbol 00991485 Suction cup shape Round bellows, 1.5 convolutions Operating pressure -0.095 MPa ... 0 MPa Operating pressure -0.95 bar ... 0 bar Operating pressure -13.775 psi ... 0 psi Nominal operating pressure -0.07 MPa Nominal operating pressure -0.7 bar Nominal operating pressure -10.15 psi Operating medium Atmospheric air based on ISO 8573-1:2010 [7:-:-] LABS (PWIS) conformity VDMA24364-A1-L Ambient temperature -20 °C ... 80 °C Breakaway force at 70% vacuum 606 N Holding force at nominal operating pressure 606 N Mounting thread G3/8 Suction cup mounting G3/8 Vacuum connection G3/8 Color Black Shore hardness 60 +/- 5 Material of screwed plug Die-cast zinc Note on materials RoHS-compliant Suction cup material NBR 5/26/24 - Subject to change - Festo SE & Co. KG 1/1
152609 价格&库存
很抱歉,暂时无法提供与“152609”相匹配的价格&库存,您可以联系我们找货
