159683
159683
    FESTO(费斯托)
    FESTO - 159683 - MN1H-5/3E-D-1-C SOLENOID VALVE
159683 数据手册
Air solenoid valve MN1H-5/3E-D-1-C Part number: 159683 General operating condition Data sheet Feature Value Valve function 5/3, exhausted Actuation type Electrical Width 42 mm Standard nominal flow rate 1200 l/min Pneumatic working port Sub-base, size 1 according to ISO 5599-1 G1/4 Operating voltage Via solenoid coil, to be ordered separately Operating pressure 0.3 MPa ... 1 MPa Operating pressure 3 bar ... 10 bar Structural design Piston gate valve Reset method Mechanical spring Certification c UL us - Recognized (OL) Maritime classification See certificate Certificate issuing authority DNV-TAA000032X Degree of protection IP65 Nominal width 8 mm Width dimension 43 mm Exhaust air function With flow control option Sealing principle Soft Mounting position Any Conforms to standard ISO 5599-1 Manual override Detenting via accessory Non-detenting ISO code 157 Type of control Pilot-controlled Pilot air supply port Internal Flow direction Non-reversible Symbol 00991082 Lap Overlap Switching time off 46 ms On switching time 20 ms Max. positive test pulse with 0 signal 3700 µs Max. negative test pulse on 1 signal 4600 µs Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) 6/4/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Vibration resistance Transport application test with severity level 1 as per FN 942017-4 and EN 60068-2-6 Shock resistance Shock test with severity level 2 as per FN 942017-5 and EN 60068-2-27 LABS (PWIS) conformity VDMA24364-B1/B2-L Temperature of medium -5 °C ... 50 °C Noise level 85 dB(A) Pilot medium Compressed air as per ISO 8573-1:2010 [7:4:4] Ambient temperature -5 °C ... 50 °C Product weight 650 g Electrical connection Via N1 coil, to be ordered separately Type of mounting On sub-base With through-hole Pilot air port 12 Sub-base, size 1 as per ISO 5599-1 Pilot air port 14 Sub-base, size 1 as per ISO 5599-1 Pneumatic connection 1 Sub-base, size 1 as per ISO 5599-1 Pneumatic connection 2 Sub-base, size 1 as per ISO 5599-1 Pneumatic connection 3 Sub-base, size 1 as per ISO 5599-1 Pneumatic connection 4 Sub-base, size 1 as per ISO 5599-1 Pneumatic connection 5 Sub-base, size 1 as per ISO 5599-1 Note on materials RoHS-compliant Seals material HNBR NBR Housing material Die-cast aluminum 6/4/24 - Subject to change - Festo SE & Co. KG 2/2
159683 价格&库存
很抱歉,暂时无法提供与“159683”相匹配的价格&库存,您可以联系我们找货
