534559
534559
    FESTO(费斯托)
    FESTO - 534559 - Air Solenoid Valve, 5/3 Way, Closed, 8 bar, 24 VDC, 1000 l/min
534559 数据手册
Air solenoid valve VSVA-B-P53C-H-A1-1R5L Part number: 534559 General operating condition Data sheet Feature Value Valve function 5/3, closed Actuation type Electrical Width 26 mm Standard nominal flow rate 1000 l/min Pneumatic working port Sub-base, size 26 mm according to ISO 15407-1 Operating voltage 24V DC Operating pressure 0.3 MPa ... 0.8 MPa Operating pressure 3 bar ... 8 bar Structural design Piston gate valve Reset method Mechanical spring Certification RCM compliance mark c UL us - Recognized (OL) CE marking (see declaration of conformity) As per EU EMC directive UKCA marking (see declaration of conformity) To UK instructions for EMC To UK RoHS instructions Degree of protection IP65 NEMA 4 Nominal width 9 mm Width dimension 27 mm Exhaust air function With flow control option Via throttle plate Via individual sub-base Sealing principle Soft Mounting position Any Conforms to standard ISO 15407-1 Manual override Non-detenting Type of control Pilot-controlled Pilot air supply port Internal Flow direction Non-reversible Symbol 00991080 Lap Overlap Reverse polarity protection for all electrical connections Additional functions Holding current reduction Safety shut-down Signal status display LED b-value 0.24 C value 4.35 l/sbar 5/22/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Flow rate of pneumatic valve 1400 l/min Flow rate of pneumatic valve on individual sub-base 1100 l/min Optimized flow rate of pneumatic valve pneumatically concatenated flow 1000 l/min Switching time off 52 ms On switching time 20 ms Duty cycle 100% Max. positive test pulse with 0 signal 400 µs Max. negative test pulse on 1 signal 100 µs Nominal pick-up current per solenoid coil 110 mA to 20 ms Nominal current with current reduction 30 mA after 20 ms Coil characteristics 24 V DC: low-current phase 1.0 W, high-current phase 2.4 W Permissible voltage fluctuations +/- 10 % Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) Vibration resistance Transport application test with severity level 2 as per FN 942017-4 and EN 60068-2-6 Shock resistance Shock test with severity level 2 as per FN 942017-5 and EN 60068-2-27 Corrosion resistance class (CRC) 2 - Moderate corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Temperature of medium -5 °C ... 50 °C Relative air humidity 0 - 90 % Protection against direct and indirect contact PELV Pilot medium Compressed air as per ISO 8573-1:2010 [7:4:4] Ambient temperature -5 °C ... 50 °C Max. tightening torque for valve mounting 1.8 Nm ... 2.2 Nm Product weight 270 g Electrical connection 3-pin M12x1 Central plug Round design Type of mounting On sub-base With through-hole and screw Note on materials RoHS-compliant Seals material FPM HNBR NBR Housing material Die-cast aluminum 5/22/24 - Subject to change - Festo SE & Co. KG 2/2
534559 价格&库存
很抱歉,暂时无法提供与“534559”相匹配的价格&库存,您可以联系我们找货
