535443
535443
    FESTO(费斯托)
    FESTO - 535443 - Linear/Swivel Clamp, Piston Rod, Double Acting, 25 mm, M5, 2 bar to 10 bar, 10 mm, ...
535443 数据手册
Swing clamp cylinder CLR-25-10-R-P-A Part number: 535443 General operating condition Data sheet Feature Value Complete stroke 23 mm Piston diameter 25 mm Piston rod thread M6 Swivel angle 90 deg +/- 3 deg Clamping stroke 10 mm Cushioning Elastic cushioning rings/pads at both ends Mounting position Any Structural design Piston Piston rod Cylinder barrel Position sensing For proximity sensor Swivel direction Right Symbol 00991217 Operating pressure 2 bar ... 10 bar Mode of operation Double-acting Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) Corrosion resistance class (CRC) 2 - Moderate corrosion stress LABS (PWIS) conformity VDMA24364-B2-L Ambient temperature -10 °C ... 80 °C Effective clamping force at 2 bar 63 N Effective clamping force at 4 bar 127 N Effective clamping force at 6 bar 188 N Max. clamping finger screw tightening torque 12 Nm Theoretical clamping force at 6 bar 227 N Product weight 395 g Type of mounting Optionally: With through-hole With internal thread With accessories Pneumatic connection M5 Flange screws material Steel Galvanized Cover material Wrought aluminum alloy Coated Seals material NBR TPE-U(PU) 5/10/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Housing material Wrought aluminum alloy Smooth anodized Piston rod material High-alloy stainless steel Material of cylinder barrel Wrought aluminum alloy Smooth anodized 5/10/24 - Subject to change - Festo SE & Co. KG 2/2
535443 价格&库存
很抱歉,暂时无法提供与“535443”相匹配的价格&库存,您可以联系我们找货
