FBS-M12-5GS-PG9
FBS-M12-5GS-PG9
    FESTO(费斯托)
    FESTO - FBS-M12-5GS-PG9 - Sensor Connector, FBS Series, M12, Female, 5 Positions, Screw Pin, Straigh...
FBS-M12-5GS-PG9 数据手册
Plug FBS-M12-5GS-PG9 Part number: 175380 Data sheet Feature Value Type code FBS Based on norm EN 61076-2-101 EN 61984 Type of mounting With threaded sleeve Mounting position Any Product weight 23.5 g Electrical connection 5-pin Form A M12x1 Straight plug/screw terminal DC operating voltage range ≤60 V Operating voltage range AC ≤60 V Current rating at 40°C 4A Surge resistance 1.5 kV Cable fitting Pg9 Approved cable diameter 6 mm ... 8 mm Connection cross section 0.75 mm² Degree of protection IP67 Ambient temperature -40 °C ... 85 °C CE marking (see declaration of conformity) As per EU low voltage directive Note on materials RoHS-compliant Contamination level 3 Corrosion resistance class (CRC) 1 - Low corrosion stress Housing material PA-reinforced Housing colour Black Material of union nut Die-cast zinc Nickel-plated Material of pin contacts Brass Nickel-plated and gold-plated 6/20/21 - Subject to change - Festo AG & Co. KG 1/1
FBS-M12-5GS-PG9 价格&库存
很抱歉,暂时无法提供与“FBS-M12-5GS-PG9”相匹配的价格&库存,您可以联系我们找货
