FBS-SUB-9-BU-2X5POL-B 数据手册
Plug
Part number: 532219
Data sheet
Feature
Value
Width
20 mm
Height
62 mm
Length
61 mm
Type code
FBS
Protocol
CAN
Product weight
60 g
Fieldbus interface
2x 5 spring-loaded terminals
Note on fieldbus interface
BUS In - BUS Out looped through
Approved cable diameter
5 mm ... 10 mm
Degree of protection
IP65
IP67
In mounted state
as per IEC 60529
Ambient temperature
0 °C ... 50 °C
Storage temperature
-20 °C ... 70 °C
Relative air humidity
95 %
Non-condensing
Note on materials
RoHS-compliant
Housing material
PA-reinforced
Material of union nut
Brass
Material of screws
Steel
Seals material
NBR
6/20/21 - Subject to change - Festo AG & Co. KG
1/1
FBS-SUB-9-BU-2X5POL-B 价格&库存
很抱歉,暂时无法提供与“FBS-SUB-9-BU-2X5POL-B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1027.79376
- 10+914.77964
