156588
156588
    FESTO(费斯托)
    FESTO - 156588 - Compact Air Cylinder, Piston Rod, Double Acting, 12 mm, M5, 1.2 bar to 10 bar, 15 m...
156588 数据手册
Compact air cylinder ADVU-12-15-A-P-A Part number: 156588 General operating condition Data sheet Feature Value Stroke 15 mm Piston diameter 12 mm Cushioning Elastic cushioning rings/pads at both ends Mounting position Any Mode of operation Double-acting Piston rod end External thread Structural design Piston Piston rod Position sensing For proximity sensor Symbol 00991217 Variants Piston rod at one end Operating pressure 0.12 MPa ... 1 MPa Operating pressure 1.2 bar ... 10 bar Operating pressure 17.4 psi ... 145 psi Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) Corrosion resistance class (CRC) 2 - Moderate corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Ambient temperature -20 °C ... 80 °C Impact energy in the end positions 0.07 J Theoretical force at 6 bar, retracting 51 N Theoretical force at 6 bar, advancing 68 N Moving mass at 0 mm stroke 8g Additional moving mass per 10 mm stroke 2g Basic weight with 0 mm stroke 87 g Additional weight per 10 mm stroke 15 g Type of mounting Optionally: With through-hole With accessories Pneumatic connection M5 Flange screws material High-alloy stainless steel Cover material Wrought aluminum alloy Material of dynamic seals NBR TPE-U(PU) Piston rod material High-alloy stainless steel Material of cylinder barrel Wrought aluminum alloy 5/8/24 - Subject to change - Festo SE & Co. KG 1/1
156588 价格&库存
很抱歉,暂时无法提供与“156588”相匹配的价格&库存,您可以联系我们找货
