161414
161414
    FESTO(费斯托)
    FESTO - 161414 - Air Solenoid Valve, 5/2 Way, Monostable, M7, -0.9 bar to 10 bar, 24 VDC, 400 l/min
161414 数据手册
Air solenoid valve CPV10-M1H-5LS-M7 Part number: 161414 General operating condition Data sheet Feature Value Valve function 5/2, monostable Actuation type Electrical Valve size 10 mm Standard nominal flow rate 400 l/min Pneumatic working port M7 Operating voltage 24V DC Operating pressure -0.09 MPa ... 1 MPa Operating pressure -0.9 bar ... 10 bar Structural design Piston gate valve Reset method Pneumatic spring Degree of protection IP65 Nominal width 4 mm Exhaust air function Without flow control option Sealing principle Soft Mounting position Any Manual override Detenting Non-detenting Type of control Pilot-controlled Pilot air supply port External Internal Flow direction Non-reversible Symbol 00991027 Lap Overlap Pilot pressure MPa 0.3 MPa ... 0.8 MPa Pilot pressure 3 bar ... 8 bar b-value 0.4 C value 1.6 l/sbar Switching time off 27 ms On switching time 17 ms Duty cycle 100% in combination with holding current reduction Electrical power consumption 0.46 W Max. positive test pulse with 0 signal 1400 µs Max. negative test pulse on 1 signal 700 µs Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) Corrosion resistance class (CRC) 2 - Moderate corrosion stress 5/11/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value LABS (PWIS) conformity VDMA24364-B1/B2-L Storage temperature -20 °C ... 40 °C Temperature of medium -5 °C ... 50 °C Ambient temperature -5 °C ... 50 °C Product weight 70 g Type of mounting With through-hole Pilot air port 12/14 Common port Pilot exhaust air port 82/84 Common port Pneumatic connection 1 Common port Pneumatic connection 11 Common port Pneumatic connection 2 M7 Pneumatic port 3/5 combined Common port Pneumatic connection 4 M7 Note on materials RoHS-compliant Seals material HNBR NBR Housing material Die-cast aluminum Brass POM PPS Steel 5/11/24 - Subject to change - Festo SE & Co. KG 2/2
161414 价格&库存
很抱歉,暂时无法提供与“161414”相匹配的价格&库存,您可以联系我们找货
