175041
175041
    FESTO(费斯托)
    FESTO - 175041 - Flow Control Valve, Non-Return, QS-3, M3, 0.2 bar to 10 bar, 41 l/min, Screw-In, -1...
175041 数据手册
One-way flow control valve GRLA-M3-QS-3 Part number: 175041 General operating condition Data sheet Feature Value Valve function Exhaust air flow control non-return function Pneumatic connection 1 QS-3 Pneumatic connection 2 M3 Adjusting element Slotted screw Type of mounting Screw-in Standard nominal flow rate in flow control direction 41 l/min Standard nominal flow rate in non-return direction 27 l/min ... 50 l/min Operating pressure 0.2 bar ... 10 bar Ambient temperature -10 °C ... 60 °C Maritime classification See certificate Mounting position Any Symbol 00991452 Standard flow rate in flow control direction 6 -> 0 bar 95 l/min Standard flow rate in non-return direction at 6 -> 0 bar 75 l/min ... 110 l/min Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) LABS (PWIS) conformity VDMA24364-B1/B2-L Cleanroom class Class 4 according to ISO 14644-1 Temperature of medium -10 °C ... 60 °C Max. tightening torque 0.3 Nm Product weight 7g Material of screwed plug Brass Nickel-plated Note on materials RoHS-compliant Seals material NBR Releasing ring material POM Material of adjusting screw Brass Swivel joint material Die-cast zinc 5/30/24 - Subject to change - Festo SE & Co. KG 1/1
175041 价格&库存
很抱歉,暂时无法提供与“175041”相匹配的价格&库存,您可以联系我们找货
