555760
555760
    FESTO(费斯托)
    FESTO - 555760 - Regulator Plate, 54 mm, 1 bar to 6 bar, IP65, Aluminium
555760 数据手册
Regulator plate VABF-S1-2-R2C2-C-10 Part number: 555760 General operating condition Data sheet Feature Value Width 54 mm Based on norm ISO 5599-1 Mounting position Any Pneumatic vertical stacking Pressure regulator for 2 Controller function Outlet pressure constant With secondary exhausting Symbol 00991581 Optional pressure gauge Possible Pressure regulation range MPa 0.1 MPa ... 1 MPa Pressure regulation range 1 bar ... 10 bar Pressure regulation range psi 14.5 psi ... 145 psi Inlet pressure 1 0.5 bar ... 10 bar Inlet pressure 1 MPa 0.05 MPa ... 1 MPa Inlet pressure 1 psi 7.25 psi ... 145 psi Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) Corrosion resistance class (CRC) 0 - No corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Degree of protection IP65 NEMA 4 Ambient temperature -5 °C ... 50 °C Product weight 1230 g Vertical stacking mounting type On manifold sub-base On individual sub-base Pressure gauge connection With retaining clamp Note on materials RoHS-compliant Material of operator panel PA Controller housing material Die-cast aluminum 5/20/24 - Subject to change - Festo SE & Co. KG 1/1
555760 价格&库存
很抱歉,暂时无法提供与“555760”相匹配的价格&库存,您可以联系我们找货
