566207
566207
    FESTO(费斯托)
    FESTO - 566207 - Pneumatic Actuator, Semi Rotary Drive, Double Acting, Size 25, M5, 10 bar, DSM Seri...
566207 数据手册
Rotary actuator DSM-25-270-P1-A-B Part number: 566207 General operating condition Data sheet Feature Value Size 25 Cushioning angle 7.5 deg Adjustment range of swivel angle 0 deg ... 246 deg Swivel angle 0 deg ... 246 deg Cushioning Elastic cushioning rings/pads at both ends with fixed stop Mounting position Any Precision adjustment -6 deg Mode of operation Double-acting Structural design Rotary vane Position sensing For proximity sensor Symbol 00991265 Operating pressure 0.15 MPa ... 1 MPa Operating pressure 1.5 bar ... 10 bar Max. swivel frequency at 6 bar 2 Hz Operating medium Compressed air as per ISO 8573-1:2010 [7:-:-] Corrosion resistance class (CRC) 0 - No corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Ambient temperature -10 °C ... 60 °C Max. axial force 50 N Max. radial force 120 N Theoretical torque at 6 bar 5 Nm Permissible mass moment of inertia 0.45 kgm² Product weight 715 g Type of mounting With internal thread Pneumatic connection M5 Note on materials RoHS-compliant Drive shaft material Steel Nickel-plated Seals material TPE-U(PU) Housing material Wrought aluminum alloy 6/3/24 - Subject to change - Festo SE & Co. KG 1/1
566207 价格&库存
很抱歉,暂时无法提供与“566207”相匹配的价格&库存,您可以联系我们找货
