575568
575568
    FESTO(费斯托)
    FESTO - 575568 - Air Solenoid Valve, 3/2 Way, Closed, Monostable, G3/8, 2.5 bar to 10 bar, 24 VDC, 2...
575568 数据手册
Air solenoid valve VUVS-L30-M32C-AD-G38-F8-1C1 Part number: 575568 General operating condition Data sheet Feature Value Valve function 3/2, closed, monostable Actuation type Electrical Valve size 31 mm Standard nominal flow rate 2300 l/min Pneumatic working port G3/8 Operating voltage 24V DC Operating pressure 0.25 MPa ... 1 MPa Operating pressure 2.5 bar ... 10 bar Structural design Piston gate valve Reset method Pneumatic spring Certification c UL us - Recognized (OL) Degree of protection IP65 With plug socket as per IEC 60529 Nominal width 9.4 mm Exhaust air function With flow control option Sealing principle Soft Mounting position Any Manual override Detenting Non-detenting Type of control Pilot-controlled Pilot air supply port Internal Flow direction Non-reversible Symbol 00991655 Lap Overlap b-value 0.3 C value 9.8 l/sbar Switching time off 36 ms On switching time 19 ms Duty cycle 100% Max. positive test pulse with 0 signal 2000 µs Max. negative test pulse on 1 signal 3600 µs Coil characteristics 24 V DC: 3.3 W Permissible voltage fluctuations +/- 10 % Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) 5/21/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Vibration resistance Transport application test with severity level 2 as per FN 942017-4 and EN 60068-2-6 Shock resistance Shock test with severity level 2 as per FN 942017-5 and EN 60068-2-27 Corrosion resistance class (CRC) 2 - Moderate corrosion stress Temperature of medium -10 °C ... 60 °C Pilot medium Compressed air as per ISO 8573-1:2010 [7:4:4] Ambient temperature -10 °C ... 60 °C Product weight 405 g Electrical connection Form C as per EN 175301-803 Type of mounting Optionally: On terminal strip With through-hole Venting hole connection Not ducted Pilot exhaust air port 82 M5 Pneumatic connection 1 G3/8 Pneumatic connection 2 G3/8 Pneumatic connection 3 G3/8 Note on materials RoHS-compliant Seals material HNBR NBR Housing material Die-cast aluminum Painted Piston slide material Wrought aluminum alloy Material of screws Steel, nickel-plated 5/21/24 - Subject to change - Festo SE & Co. KG 2/2
575568 价格&库存
很抱歉,暂时无法提供与“575568”相匹配的价格&库存,您可以联系我们找货
