153167
153167
    FESTO(费斯托)
    FESTO - 153167 - Push-In Fitting, Bulkhead,, G3/8, 6 bar, 8 mm Outer Dia Tube, Brass
153167 数据手册
Bulkhead push-in fitting QSSF-3/8-8-B Part number: 153167 General operating condition Data sheet Feature Value Size Standard Nominal width 7 mm Mounting position Any Design Bulkhead Pack size 10 Structural design Push-pull principle Operating pressure for entire temperature range -0.095 MPa ... 0.6 MPa Operating pressure for entire temperature range -0.95 bar ... 6 bar Operating pressure for entire temperature range -13.775 psi ... 87 psi Temperature-dependent operating pressure -0.095 MPa ... 1.4 MPa Temperature-dependent operating pressure -0.95 bar ... 14 bar Temperature-dependent operating pressure -13.775 psi ... 203 psi Operating medium Compressed air as per ISO 8573-1:2010 [7:-:-] Water as per manufacturer's declaration at www.festo.com Information on operating and pilot media Operation with oil lubrication possible Corrosion resistance class (CRC) 1 - Low corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Cleanroom class Class 4 according to ISO 14644-1 Ambient temperature -10 °C ... 80 °C Nominal tightening torque 15.5 Nm Tolerance for nominal tightening torque ± 20% Product weight 38 g Type of mounting External hexagon, AF 19 External hexagon, AF 21 Pneumatic connection 1 Internal thread G3/8 Pneumatic connection 2 for pneumatic tubing outside diameter 8 mm Releasing ring color Blue Note on materials RoHS-compliant Housing material Brass, nickel-plated Releasing ring material POM Nut material Brass, nickel-plated Material of tubing seal NBR Material of tube retaining claw High-alloy stainless steel 5/20/24 - Subject to change - Festo SE & Co. KG 1/1
153167 价格&库存
很抱歉,暂时无法提供与“153167”相匹配的价格&库存,您可以联系我们找货
