186108
186108
    FESTO(费斯托)
    FESTO - 186108 - Push-In Fitting, G1/4, 6 bar, 6 mm Outer Dia Tube, Brass
186108 数据手册
Push-in fitting QS-G1/4-6-I Part number: 186108 General operating condition Data sheet Feature Value Size Standard Nominal width 4.2 mm Type of seal on screwed plug Sealing ring Mounting position Any Design Straight design Pack size 10 Structural design Push-pull principle Operating pressure for entire temperature range -0.095 MPa ... 0.6 MPa Operating pressure for entire temperature range -0.95 bar ... 6 bar Operating pressure for entire temperature range -13.775 psi ... 87 psi Temperature-dependent operating pressure -0.095 MPa ... 1.4 MPa Temperature-dependent operating pressure -0.95 bar ... 14 bar Temperature-dependent operating pressure -13.775 psi ... 203 psi Operating medium Compressed air as per ISO 8573-1:2010 [7:-:-] Water as per manufacturer's declaration at www.festo.com Information on operating and pilot media Operation with oil lubrication possible Corrosion resistance class (CRC) 1 - Low corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Ambient temperature -10 °C ... 80 °C Nominal tightening torque 9 Nm Tolerance for nominal tightening torque ± 20% Product weight 13 g Type of mounting Internal hexagon, AF 4 Pneumatic connection 1 External thread G1/4 Pneumatic connection 2 for pneumatic tubing outside diameter 6 mm Releasing ring color Blue Note on materials RoHS-compliant Housing material Brass, nickel-plated Releasing ring material POM Material of tubing seal NBR Material of tube retaining claw High-alloy stainless steel 5/31/24 - Subject to change - Festo SE & Co. KG 1/1
186108 价格&库存
很抱歉,暂时无法提供与“186108”相匹配的价格&库存,您可以联系我们找货
  • 1+35.481671+4.59910
  • 10+33.1278510+4.29400
  • 30+30.7740330+3.98890
库存:3
