Pressure regulator
LR-1/4-D-7-MIDI
Part number: 186453
General operating condition
Data sheet
Feature
Value
Size
Midi
Series
D
Actuator lock
Rotary knob with detent
Mounting position
Any
Structural design
Directly controlled diaphragm regulator
Controller function
Outlet pressure constant
With primary pressure compensation
With secondary exhausting
Symbol
00991538
Pressure gauge
with pressure gauge
Operating pressure
0 MPa ... 1.6 MPa
Operating pressure
0 bar ... 16 bar
Pressure regulation range
0.5 bar ... 7 bar
Max. pressure hysteresis
0.02 MPa
0.2 bar
2.9 psi
Standard nominal flow rate
2200 l/min
Operating medium
Compressed air as per ISO 8573-1:2010 [7:4:4]
Inert gas
Information on operating and pilot media
Operation with oil lubrication possible (required for further use)
Corrosion resistance class (CRC)
2 - Moderate corrosion stress
LABS (PWIS) conformity
VDMA24364-B1/B2-L
Air quality class at the output
Inert gas
Temperature of medium
-10 °C ... 60 °C
Ambient temperature
-10 °C ... 60 °C
Product weight
720 g
Type of mounting
Front panel mounting
Line installation
With accessories
Pneumatic connection 1
G1/4
Pneumatic connection 2
G¼
Note on materials
RoHS-compliant
Material of sub-base
Die-cast zinc
Seals material
NBR
Housing material
Die-cast zinc
5/26/24 - Subject to change - Festo SE & Co. KG
1/1
很抱歉,暂时无法提供与“186453”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1667.11556
- 10+1633.77491
