554227
554227
    FESTO(费斯托)
    FESTO - 554227 - Compact Air Cylinder, Yoke Piston Rod, Double Acting, 20 mm, M5, 1.5 bar to 10 bar,...
554227 数据手册
Compact air cylinder ADNGF-20-50-P-A Part number: 554227 General operating condition Data sheet Feature Value Stroke 50 mm Piston diameter 20 mm Based on norm ISO 21287 Cushioning Elastic cushioning rings/pads at both ends Mounting position Any Structural design Piston Piston rod Profile barrel Position sensing For proximity sensor Protection against torsion/guide Guide rod with yoke Operating pressure 0.15 MPa ... 1 MPa Operating pressure 1.5 bar ... 10 bar Mode of operation Double-acting Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) Corrosion resistance class (CRC) 2 - Moderate corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Ambient temperature -20 °C ... 80 °C Impact energy in the end positions 0.2 J Theoretical force at 6 bar, retracting 141 N Theoretical force at 6 bar, advancing 188 N Moving mass 112 g Product weight 284 g Pneumatic connection M5 Note on materials RoHS-compliant Flange screws material Steel Cover material Wrought aluminum alloy, anodized Seals material TPE-U(PUR) End plate material Wrought aluminum alloy, anodized Piston rod material High-alloy steel Material of cylinder barrel Wrought aluminum alloy, smooth-anodized 5/28/24 - Subject to change - Festo SE & Co. KG 1/1
554227 价格&库存
很抱歉,暂时无法提供与“554227”相匹配的价格&库存,您可以联系我们找货
