193144
193144
    FESTO(费斯托)
193144 数据手册
One-way flow control valve GRLA-1/8-QS-6-D Part number: 193144 General operating condition Data sheet Feature Value Valve function Exhaust air flow control non-return function Pneumatic connection 1 QS-6 Pneumatic connection 2 G1/8 Adjusting element Slotted screw Type of mounting Screw-in Standard nominal flow rate in flow control direction 185 l/min Standard nominal flow rate in non-return direction 160 l/min ... 240 l/min Ambient temperature -10 °C ... 60 °C Maritime classification See certificate Mounting position Any Symbol 00991452 Operating pressure for entire temperature range 0.2 bar ... 10 bar Standard flow rate in flow control direction 6 -> 0 bar 370 l/min Standard flow rate in non-return direction at 6 -> 0 bar 330 l/min ... 390 l/min Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) LABS (PWIS) conformity VDMA24364-B1/B2-L Cleanroom class Class 4 according to ISO 14644-1 Temperature of medium -10 °C ... 60 °C Nominal tightening torque 3 Nm Tolerance for nominal tightening torque ± 10% Product weight 22 g Material of screwed plug Wrought aluminum alloy Note on materials RoHS-compliant Seals material NBR Releasing ring material POM Material of adjusting screw Brass Swivel joint material Die-cast zinc Chromated 5/23/24 - Subject to change - Festo SE & Co. KG 1/1
193144 价格&库存
很抱歉,暂时无法提供与“193144”相匹配的价格&库存,您可以联系我们找货
  • 1+192.953021+24.95040
  • 5+180.106975+23.28930
  • 10+167.2609110+21.62820
库存:4
193144
  • 1+193.36085
  • 5+180.46055
  • 10+167.58420
库存:4
