197379
197379
    FESTO(费斯托)
197379 数据手册
Plastic tubing PUN-H-10X1,5-NT Part number: 197379 General operating condition Data sheet Feature Value Outside diameter 10 mm Bending radius relevant for flow rate 52 mm Inside diameter 7 mm Min. bending radius 28 mm Application note TPE-U Ether based Tubing characteristics Suitable for energy chains Operating pressure for entire temperature range -0.095 MPa ... 0.6 MPa Operating pressure for entire temperature range -0.95 bar ... 6 bar Operating pressure for entire temperature range -13.775 psi ... 87 psi Temperature-dependent operating pressure -0.095 MPa ... 1 MPa Temperature-dependent operating pressure -0.95 bar ... 10 bar Temperature-dependent operating pressure -13.775 psi ... 145 psi Information on operating pressure Water: temperature-dependent operating pressure, see diagram, max. 0.3 MPa at 0 - 60 °C Certification German Technical Control Board (TÜV) Certificate issuing authority B 013277 0506 00 Operating medium Compressed air as per ISO 8573-1:2010 [7:-:-] Water (liquid, ice-free) Material fire test UL94 HB LABS (PWIS) conformity VDMA24364-B2-L Suitability for the production of Li-ion batteries Metals with more than 1% by mass of copper, zinc or nickel by mass are excluded from use. Exceptions are nickel in steel, chemically nickelplated surfaces, printed circuit boards, cables, electrical plug connectors and coils Cleanroom class Statically installed element, no meaningful evaluation possible according to ISO 14644-1 For use in the food industry See supplementary material information Ambient temperature -35 °C ... 60 °C Product weight by length 0.0465 kg/m Pneumatic connection For plug connection outside diameter 10 mm Color Natural Shore hardness D 52 +/-3 Note on materials RoHS-compliant Material of pneumatic tubing TPE-U(PU) 6/3/24 - Subject to change - Festo SE & Co. KG 1/1
197379 价格&库存
很抱歉,暂时无法提供与“197379”相匹配的价格&库存,您可以联系我们找货
