8086004
8086004
    FESTO(费斯托)
    FESTO - 8086004 - Pressure Regulator, QS-6, 90 l/min, 1 to 8 bar Regulation, 0°C to 60°C, PBT
8086004 数据手册
Pressure regulator VRPA-CM-Q6-E Part number: 8086004 General operating condition Data sheet Feature Value Controller function Outlet pressure constant With secondary exhausting With return flow function Pneumatic connection 1 QS-6 Pneumatic connection 2 QS-6 Type of mounting With through-hole Standard nominal flow rate 90 l/min Ambient temperature 0 °C ... 60 °C Housing material PBT Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Mounting position Any Actuation type Manual Adjusting element Rotary knob with detent Symbol 00991558 Pressure gauge with pressure gauge Pressure regulation range MPa 0.1 MPa ... 0.8 MPa Pressure regulation range 1 bar ... 8 bar Pressure regulation range psi 14.5 psi ... 116 psi Information on operating and pilot media Operation with oil lubrication possible (required for further use) LABS (PWIS) conformity VDMA24364-B2-L Cleanroom class Class 4 according to ISO 14644-1 Product weight 23 g Note on materials RoHS-compliant Static seal material NBR 5/8/24 - Subject to change - Festo SE & Co. KG 1/1
8086004 价格&库存
很抱歉,暂时无法提供与“8086004”相匹配的价格&库存,您可以联系我们找货
  • 1+874.35807
  • 5+817.01938
  • 10+757.29707
