4165865
4165865
    FESTO(费斯托)
    FESTO - 4165865 - Hand Lever Valve, 5/3 Way, Closed, G1/8, 700 l/min, -0.95 bar to 10 bar, VHEF Seri...
4165865 数据手册
Hand lever valve VHEF-HS-B53C-G18 Part number: 4165865 General operating condition Data sheet Feature Value Valve function 5/3, closed Actuation type Manual Width 20 mm Standard nominal flow rate 700 l/min Pneumatic working port G1/8 Operating pressure -0.095 MPa ... 1 MPa Operating pressure -0.95 bar ... 10 bar Structural design Piston gate valve Nominal width 5.2 mm Exhaust air function With flow control option Application note Operate by hand only Sealing principle Soft Mounting position Any Manual override Detenting Type of control Direct Flow direction Reversible Symbol 00995888 Lap Overlap Max. switching frequency 0.5 Hz Explosion prevention and protection Zone 1 (ATEX) Zone 2 (ATEX) Zone 21 (ATEX) Zone 22 (ATEX) Operating medium Compressed air as per ISO 8573-1:2010 [7:-:-] Information on operating and pilot media Operation with oil lubrication possible (required for further use) Corrosion resistance class (CRC) 1 - Low corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Temperature of medium -10 °C ... 60 °C Ambient temperature -10 °C ... 60 °C Actuating torque 0.7 Nm Max. force on actuator 200 N Max. transverse load on actuator 200 N Product weight 265 g Type of mounting Optionally: Front panel mounting With through-hole Pneumatic connection 1 G1/8 5/24/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Pneumatic connection 2 G1/8 Pneumatic connection 3 G1/8 Pneumatic connection 4 G1/8 Pneumatic connection 5 G1/8 Note on materials RoHS-compliant Cover material PA-reinforced Seals material NBR Housing material Wrought aluminum alloy, anodized Lever material PA-reinforced 5/24/24 - Subject to change - Festo SE & Co. KG 2/2
4165865 价格&库存
很抱歉,暂时无法提供与“4165865”相匹配的价格&库存,您可以联系我们找货
