525618
525618
    FESTO(费斯托)
    FESTO - 525618 - SIM-M12-8GD-5-PU PLUG SOCKET WITH CABLE
525618 数据手册
Plug socket with cable SIM-M12-8GD-5-PU Part number: 525618 General operating condition Data sheet Feature Value Conforms to standard DIN 47100 EN 61076-2-101 Cable designation Without label holder Product weight 343 g Electrical connection 1, function Field device end Electrical connection 1, design Round Electrical connection 1, connection type Socket Electrical connection 1, cable outlet Straight Electrical connection 1, connection technology M12x1 A-coded as per EN 61076-2-101 Electrical connection 1, number of pins/wires 8 Electrical connection 1, occupied pins/wires 8 Electrical connection 1, type of mounting Screw-type lock Electrical connection for input 1, connection pattern 00992265 Electrical connection 2, function Control side Electrical connection 2, connection type Cable Electrical connection 2, connection technology Open end Electrical connection 2, number of pins/wires 8 Electrical connection 2, occupied pins/wires 8 DC operating voltage range 0 V ... 30 V Operating voltage range AC 0 V ... 30 V Current rating at 40° C 2A Surge resistance 0.8 kV Cable length 5m Cable characteristic Standard Bending radius, fixed cable installation ≥32 mm Bending radius, flexible cable installation ≥66 mm Cable diameter 6.3 mm Cable diameter tolerance ± 0.2 mm Cable design 8 x 0.25 mm² Shielded Nominal conductor cross section 0.25 mm² Wire ends Tin-plated Degree of protection IP67 Note on degree of protection In mounted state Ambient temperature -25 °C ... 80 °C Ambient temperature with flexible cable installation -5 °C ... 80 °C 5/27/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value CE marking (see declaration of conformity) As per EU RoHS directive UKCA marking (see declaration of conformity) To UK RoHS instructions LABS (PWIS) conformity VDMA24364-B2-L Note on materials RoHS-compliant Contamination level 3 Corrosion resistance class (CRC) 2 - Moderate corrosion stress Material of cable sheath TPE-U(PUR) Color cable sheath Gray Housing material TPE-U(PUR) Material of screw-type lock Brass, nickel-plated Seals material FPM Material of pin contacts Bronze, gold-plated Insulating sheath material PP 5/27/24 - Subject to change - Festo SE & Co. KG 2/2
525618 价格&库存
很抱歉,暂时无法提供与“525618”相匹配的价格&库存,您可以联系我们找货
