8022035
8022035
    FESTO(费斯托)
    FESTO - 8022035 - VMPA2-M1BH-J-PI SOLENOID VALVE
8022035 数据手册
Air solenoid valve VMPA2-M1BH-J-PI Part number: 8022035 General operating condition Data sheet Feature Value Valve function 5/2, bistable Actuation type Electrical Valve size 20 mm Standard nominal flow rate 860 l/min Operating voltage 24V DC Operating pressure -0.09 MPa ... 1 MPa Operating pressure -0.9 bar ... 10 bar Structural design Piston gate valve Certification c UL us - Recognized (OL) Degree of protection IP65 as per IEC 60529 Sealing principle Soft Mounting position Any Manual override Detenting Non-detenting Type of control Pilot-controlled Flow direction Reversible Symbol 00991067 Lap Overlap Signal status display yes Pilot pressure MPa 0.3 MPa ... 0.8 MPa Pilot pressure 3 bar ... 8 bar Suitability for vacuum yes Standard nominal flow rate with QS-10 860 l/min On switching time 9 ms Changeover time 22 ms Max. positive test pulse with 0 signal 400 µs Max. negative test pulse on 1 signal 900 µs Permissible voltage fluctuations +/- 25 % Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Information on operating and pilot media Operation with oil lubrication possible (required for further use) Vibration resistance Transport application test with severity level 2 as per FN 942017-4 and EN 60068-2-6 Shock resistance Shock test with severity level 2 as per FN 942017-5 and EN 60068-2-27 Corrosion resistance class (CRC) 1 - Low corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L 5/8/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Storage temperature -20 °C ... 40 °C Temperature of medium -5 °C ... 50 °C Relative air humidity Max. 90 % at 40 °C Ambient temperature -5 °C ... 50 °C Max. tightening torque for valve mounting 0.65 Nm Product weight 100 g Type of mounting With through-hole Note on materials RoHS-compliant Seals material NBR Housing material Die-cast aluminum 5/8/24 - Subject to change - Festo SE & Co. KG 2/2
8022035 价格&库存
很抱歉,暂时无法提供与“8022035”相匹配的价格&库存,您可以联系我们找货
