1491843
1491843
    FESTO(费斯托)
    FESTO - 1491843 - SOLENOID VALVE
1491843 数据手册
Air solenoid valve VZWD-L-M22C-M-G14-25-V-1P4-22 Part number: 1491843 General operating condition Data sheet Feature Value Structural design Directly controlled poppet valve Actuation type Electrical Sealing principle Soft Mounting position Any Type of mounting Line installation Fitting connection G1/4 Electrical connection Form A Plug as per EN 175301-803 Rectangular design Nominal width 2.5 mm Valve function 2/2, closed, monostable Manual override None Flow direction Non-reversible Medium Compressed air as per ISO 8573-1:2010 [7:4:4] Inert gas Mineral oil Water Neutral liquids Other flow media on request Nominal pressure of fitting PN 100 Pressure difference 0 MPa Differential pressure 0 bar Pressure difference 0 psi Coil characteristics 24 V DC: 11.0 W Insulation class H Permissible voltage fluctuations +/- 10 % Duty cycle 100% Reset method Mechanical spring Type of control Direct Symbol 00992979 Medium pressure 0 MPa ... 2.2 MPa 5/8/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Medium pressure 0 bar ... 22 bar Medium pressure 0 psi ... 319 psi Max. viscosity 22 mm²/s Temperature of medium -10 °C ... 80 °C Ambient temperature -10 °C ... 35 °C Leak rate to EN 12266-1 A Flow rate Kv 0.16 m³/h Standard nominal flow rate 170 l/min On switching time 20 ms Switching time off 18 ms Note on materials RoHS-compliant LABS (PWIS) conformity VDMA24364 zone III Housing material Cast brass Material number of housing CW617N Seals material FPM Product weight 550 g Degree of protection IP65 Corrosion resistance class (CRC) 1 - Low corrosion stress 5/8/24 - Subject to change - Festo SE & Co. KG 2/2
1491843 价格&库存
很抱歉,暂时无法提供与“1491843”相匹配的价格&库存,您可以联系我们找货
