Plastic tubing
PLN-4X0,75-BL
Part number: 558205
General operating condition
Data sheet
Feature
Value
Outside diameter
4 mm
Bending radius relevant for flow rate
25 mm
Inside diameter
2.9 mm
Min. bending radius
12 mm
Temperature-dependent operating pressure
-0.095 MPa ... 1.4 MPa
-0.95 bar ... 14 bar
-13.775 psi ... 203 psi
Information on operating pressure
Water: max. 0.6 MPa at 0 - 50 °C
Certification
German Technical Control Board (TÜV)
Certificate issuing authority
B 013277 0506 00
Operating medium
Compressed air as per ISO 8573-1:2010 [7:-:-]
Water (liquid, ice-free)
LABS (PWIS) conformity
VDMA24364-B2-L
Cleanroom class
Statically installed element, no meaningful evaluation possible
according to ISO 14644-1
For use in the food industry
See supplementary material information
Ambient temperature
-30 °C ... 80 °C
Product weight by length
0.0056 kg/m
Pneumatic connection
For plug connection outside diameter 4 mm
For barbed fitting, inside diameter 3 mm, with union nut
Color
Blue
Note on materials
RoHS-compliant
Material of pneumatic tubing
PE
5/23/24 - Subject to change - Festo SE & Co. KG
1/1
很抱歉,暂时无法提供与“558205”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+20.952405+2.72330
- 20+19.5613720+2.54250
- 50+18.1703450+2.36170
