Bus node
CTEU-EC
Part number: 572556
Data sheet
Feature
Value
Type code
CTEU
Dimensions W x L x H
40 mm x 91 mm x 50 mm
Width dimension
40 mm
Type of mounting
On electrical interface
On electrical sub-base
Product weight
90 g
Protocol
EtherCAT
Fieldbus interface, type
Ethernet
Fieldbus interface, protocol
EtherCAT
Fieldbus interface, function
Bus connection, incoming/forwarding
Fieldbus interface, connection type
2x socket
Fieldbus interface, connection technology
M12x1, D-coded as per EN 61076-2-101
Fieldbus interface, number of poles/wires
4
Fieldbus interface, connection pattern
00995716
Fieldbus interface, galvanic isolation
yes
Fieldbus interface, transmission rate
100 Mbit/s
Internal cycle time
1 ms per 1 byte of user data
Max. address capacity inputs
16 byte
Max. address capacity outputs
16 byte
Power supply, function
Electronics and load
Power supply, type of connection
Plug
Power supply, connection technology
M12x1, A-coded as per EN 61076-2-101
Power supply, number of pins/wires
5
Power supply, connection pattern
00995383
Diagnostics
Communication error
System diagnostics
Undervoltage
Parameterization
Activate diagnostics
Fail-safe and idle response
Additional functions
Acyclic data access via "SDO"
Diagnostic object
Emergency message
Modular Device Profile (MDP)
Configuration support
XML file
Control elements
DIL switch
LED display (product-specific)
PS: operating voltage for electronics and load supply
X1: module system status at I-Port 1
X2: module system status at I-Port 2
6/20/21 - Subject to change - Festo AG & Co. KG
1/2
Feature
Value
LED display (bus-specific)
L/A1: network active, port 1
L/A2: network active, port 2
Run: communication status
DC operating voltage range
18 V ... 30 V
Nominal operating voltage DC
24 V
Intrinsic current consumption at nominal operating voltage
Typ. 60 mA
Max. power supply
4A
Certification
RCM compliance mark
c UL us - Listed (OL)
KC characters
KC EMC
CE marking (see declaration of conformity)
As per EU EMC directive
Corrosion resistance class (CRC)
2 - Moderate corrosion stress
Storage temperature
-20 °C ... 70 °C
Degree of protection
IP65
IP67
Note on degree of protection
In mounted state
Unused connections sealed
Ambient temperature
-5 °C ... 50 °C
Housing material
PA
Note on materials
Contains paint-wetting impairment substances
RoHS-compliant
2/2
很抱歉,暂时无法提供与“CTEU-EC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5372.904741+698.34660
