CTEU-PN
CTEU-PN
    FESTO(费斯托)
    FESTO - CTEU-PN - BUS NODE, 4A, 24VDC, M12X1
CTEU-PN 数据手册
Bus node CTEU-PN Part number: 2201471 Data sheet Feature Value Type code CTEU Dimensions W x L x H 40 mm x 91 mm x 50 mm Width dimension 40 mm Type of mounting On electrical interface On electrical sub-base Product weight 93 g Protocol PROFINET Fieldbus interface, type Ethernet Fieldbus interface, protocol PROFINET RT Fieldbus interface, function Bus connection, incoming/forwarding Fieldbus interface, connection type 2x socket Fieldbus interface, connection technology M12x1, D-coded as per EN 61076-2-101 Fieldbus interface, number of poles/wires 4 Fieldbus interface, connection pattern 00995716 Fieldbus interface, galvanic isolation yes Fieldbus interface, transmission rate 100 Mbit/s Internal cycle time 1 ms per 1 byte of user data Max. address capacity inputs 64 byte Max. address capacity outputs 64 byte Power supply, function Electronics and load Power supply, type of connection Plug Power supply, connection technology M12x1, A-coded as per EN 61076-2-101 Power supply, number of pins/wires 5 Power supply, connection pattern 00995383 Diagnostics Communication error System diagnostics Undervoltage Additional functions Conformance class C Fast start-up (FSU) LLDP MRP PROFINET IRT PROFIenergy SNMP Shared device Web server Configuration support GSDML file 6/20/21 - Subject to change - Festo AG & Co. KG 1/2 Feature Value LED display (product-specific) PS: operating voltage for electronics and load supply X1: module system status at I-Port 1 X2: module system status at I-Port 2 LED display (bus-specific) NF: network fault TP1: network active port 1 TP2: network active, port 2 DC operating voltage range 18 V ... 30 V Nominal operating voltage DC 24 V Intrinsic current consumption at nominal operating voltage Typ. 80 mA Max. power supply 4A Certification RCM compliance mark c UL us - Listed (OL) KC characters KC EMC CE marking (see declaration of conformity) As per EU EMC directive Corrosion resistance class (CRC) 2 - Moderate corrosion stress Storage temperature -20 °C ... 70 °C Degree of protection IP65 IP67 Note on degree of protection In mounted state Unused connections sealed Ambient temperature -5 °C ... 50 °C Housing material PA Note on materials Contains paint-wetting impairment substances RoHS-compliant 6/20/21 - Subject to change - Festo AG & Co. KG 2/2
CTEU-PN 价格&库存
很抱歉,暂时无法提供与“CTEU-PN”相匹配的价格&库存,您可以联系我们找货
CTEU-PN
  • 1+3199.66185
库存:3
