FBS-SUB-9-GS-DP-B
FBS-SUB-9-GS-DP-B
    FESTO(费斯托)
    FESTO - FBS-SUB-9-GS-DP-B - FBS-SUB-9-GS-DP-B PLUG
FBS-SUB-9-GS-DP-B 数据手册
Plug FBS-SUB-9-GS-DP-B Part number: 532216 Data sheet Feature Value Width 20 mm Height 62 mm Length 61 mm Type code FBS Protocol PROFIBUS Control elements DIL switch Additional functions Deactivation of forwarding bus segment Product weight 60 g Fieldbus interface 2x 2 spring-loaded terminals Approved cable diameter 5 mm ... 10 mm Degree of protection IP65 IP67 In mounted state as per IEC 60529 Ambient temperature 0 °C ... 50 °C Storage temperature -20 °C ... 70 °C Relative air humidity 95 % Non-condensing Note on materials RoHS-compliant Housing material PA-reinforced Material of union nut Brass Material of screws Steel Seals material NBR 6/20/21 - Subject to change - Festo AG & Co. KG 1/1
FBS-SUB-9-GS-DP-B 价格&库存
很抱歉,暂时无法提供与“FBS-SUB-9-GS-DP-B”相匹配的价格&库存,您可以联系我们找货
FBS-SUB-9-GS-DP-B
  • 1+717.09682
库存:22
