Push-in fitting
QSF-1/4-6-B
Part number: 153024
General operating condition
Data sheet
Feature
Value
Size
Standard
Nominal width
5 mm
Type of seal on screwed plug
Coating
Mounting position
Any
Design
Straight design
Pack size
10
Structural design
Push-pull principle
Operating pressure for entire temperature range
-0.095 MPa ... 0.6 MPa
-0.95 bar ... 6 bar
-13.775 psi ... 87 psi
Temperature-dependent operating pressure
-0.095 MPa ... 1.4 MPa
-0.95 bar ... 14 bar
-13.775 psi ... 203 psi
Operating medium
Compressed air as per ISO 8573-1:2010 [7:-:-]
Water as per manufacturer's declaration at www.festo.com
Information on operating and pilot media
Operation with oil lubrication possible
Corrosion resistance class (CRC)
1 - Low corrosion stress
LABS (PWIS) conformity
VDMA24364-B1/B2-L
Ambient temperature
-10 °C ... 80 °C
Nominal tightening torque
9 Nm
Tolerance for nominal tightening torque
± 20%
Product weight
23 g
Type of mounting
External hexagon, AF 17
Pneumatic connection 1
Internal thread G1/4
Pneumatic connection 2
for pneumatic tubing outside diameter 6 mm
Releasing ring color
Blue
Note on materials
RoHS-compliant
Housing material
Brass, nickel-plated
Releasing ring material
POM
Material of tubing seal
NBR
Material of tube retaining claw
High-alloy stainless steel
5/23/24 - Subject to change - Festo SE & Co. KG
1/1
很抱歉,暂时无法提供与“153024”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+50.476381+6.54270
- 10+47.1636010+6.11330
- 30+43.7636430+5.67260
