153134
153134
    FESTO(费斯托)
153134 数据手册
Push-in T-connector QST-6-4 Part number: 153134 General operating condition Data sheet Feature Value Size Standard Nominal width 2.3 mm Mounting position Any Design T-shape Pack size 10 Structural design Push-pull principle Operating pressure for entire temperature range -0.095 MPa ... 0.6 MPa Operating pressure for entire temperature range -0.95 bar ... 6 bar Operating pressure for entire temperature range -13.775 psi ... 87 psi Temperature-dependent operating pressure -0.095 MPa ... 1.4 MPa Temperature-dependent operating pressure -0.95 bar ... 14 bar Temperature-dependent operating pressure -13.775 psi ... 203 psi Maritime classification See certificate Operating medium Compressed air as per ISO 8573-1:2010 [7:-:-] Water as per manufacturer's declaration at www.festo.com Information on operating and pilot media Operation with oil lubrication possible Corrosion resistance class (CRC) 1 - Low corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Ambient temperature -10 °C ... 80 °C Product weight 11 g No. of outlets 2 No. of supply lines 1 Pneumatic connection 1 For pneumatic tubing outside diameter 6 mm Pneumatic connection 2 for pneumatic tubing outside diameter 4 mm Releasing ring color Blue Note on materials RoHS-compliant Housing material PBT Releasing ring material POM Material of tubing seal NBR Material of tube retaining claw High-alloy stainless steel 5/8/24 - Subject to change - Festo SE & Co. KG 1/1
153134 价格&库存
很抱歉,暂时无法提供与“153134”相匹配的价格&库存,您可以联系我们找货
  • 1+54.137881+7.01730
  • 10+50.4763810+6.54270
  • 30+46.9020630+6.07940
库存:5
