178291
178291
    FESTO(费斯托)
    FESTO - 178291 - Proximity Sensor, 0.8 mm, 5 x 5 x 25 mm, PNP, 10 VDC to 30 VDC, SIES Series
178291 数据手册
Proximity sensor SIES-Q5B-PS-K-L Part number: 178291 General operating condition Data sheet Feature Value Conforms to standard EN 60947-5-2 Symbol 00991702 Certification RCM compliance mark c UL us - Listed (OL) CE marking (see declaration of conformity) As per EU EMC directive Rated operating distance 0.8 mm Assured operating distance 0.64 mm Reduction factors Aluminum = 0.4 Stainless steel St 18/8 = 0.7 Copper = 0.3 Brass = 0.4 Steel St 37 = 1.0 Ambient temperature -25 °C ... 70 °C Repetition accuracy 0.04 mm Switching output PNP Switching element function N/O contact Max. switching frequency 3000 Hz Max. switching frequency DC 3000 Hz Max. output current 200 mA Voltage drop 2V Short-circuit protection Pulsed DC operating voltage range 10 V ... 30 V Residual ripple 10 % Idle current ≤10 mA Reverse polarity protection for all electrical connections Electrical connection 3-wire Cable Cable length 2.5 m Material of cable sheath TPE-U(PUR) Size 5x5x25 mm Type of mounting With internal thread Mounting type Flush Product weight 22 g Housing material Brass Nickel-plated Switching status indication LED yellow Degree of protection IP67 LABS (PWIS) conformity VDMA24364-B2-L 5/8/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Selection of additional sensor information Special design Electrical output PNP Selection of sensor version Standard 5/8/24 - Subject to change - Festo SE & Co. KG 2/2
178291 价格&库存
很抱歉,暂时无法提供与“178291”相匹配的价格&库存,您可以联系我们找货
