186321
186321
    FESTO(费斯托)
186321 数据手册
Push-in fitting QS-V0-G3/8-10 Part number: 186321 General operating condition Data sheet Feature Value Size Standard Nominal width 9 mm Material fire test UL94 V-0 (housing) UL94 V-0 (releasing ring) Type of seal on screwed plug Sealing ring Design Straight design Pack size 10 Structural design Push-pull principle Operating pressure for entire temperature range -0.095 MPa ... 1 MPa Operating pressure for entire temperature range -0.95 bar ... 10 bar Operating pressure for entire temperature range -13.775 psi ... 145 psi Information on operating pressure Water: max. 0.6 MPa at max. 50 °C Operating medium Compressed air as per ISO 8573-1:2010 [7:-:-] Water (liquid, ice-free) Information on operating and pilot media Operation with oil lubrication possible Corrosion resistance class (CRC) 2 - Moderate corrosion stress LABS (PWIS) conformity VDMA24364-B1/B2-L Ambient temperature 0 °C ... 60 °C Nominal tightening torque 15.5 Nm Tolerance for nominal tightening torque ± 20% Product weight 23 g Type of mounting External hexagon, AF 19 Pneumatic connection 1 External thread G3/8 Pneumatic connection 2 for pneumatic tubing outside diameter 10 mm Releasing ring color Black Material of screwed plug Brass, nickel-plated Note on materials RoHS-compliant Housing material PBT Material of threaded seal Aluminum PBT Releasing ring material PBT Material of tubing seal NBR Material of tube retaining claw High-alloy stainless steel Brass 6/4/24 - Subject to change - Festo SE & Co. KG 1/1
186321 价格&库存
很抱歉,暂时无法提供与“186321”相匹配的价格&库存,您可以联系我们找货
  • 1+116.209011+15.06290
  • 10+108.5373010+14.06850
  • 30+100.7784130+13.06280
