8046904
8046904
    FESTO(费斯托)
    FESTO - 8046904 - REGULATORS PNEUMATICS
8046904 数据手册
Proportional pressure control valve VEAA-L-3-D9-Q4-A4-1R1 Part number: 8046904 General operating condition Data sheet Feature Value Valve function 3-way proportional pressure control valve Type of control Direct Reset method Mechanical spring Actuation type Electrical Mounting position Any Sealing principle Soft Symbol 00995607 Ambient temperature 0 °C ... 50 °C Temperature of medium 5 °C ... 50 °C Storage temperature -20 °C ... 70 °C Dimensions W x L x H 15 mm x 54.5 mm x 85 mm Pneumatic connection 1 QS-4 Pneumatic connection 2 QS-4 Pneumatic connection 3 QS-4 Seals material NBR Type of mounting Optionally: With through-hole With accessories Inlet pressure 1 MPa 0 MPa ... 1.1 MPa Inlet pressure 1 0 bar ... 11 bar Inlet pressure 1 psi 0 psi ... 159.5 psi Output pressure 2 0.003 MPa ... 0.6 MPa Outlet pressure 2 0.03 bar ... 6 bar Output pressure 2 0.435 psi ... 87 psi Standard nominal flow rate ≥10 l/min Standard nominal flow rate 2-3 ≥6 l/min Linearity error FS 0.5 % Repetition accuracy in ± %FS 0.4 %FS Hysteresis in ± %FS 0.25 %FS Temperature coefficient 0.05 %/K Absolute accuracy in ± %FS at room temperature 0.75 %FS Product weight 55 g Operating medium Compressed air as per ISO 8573-1:2010 [7:4:4] Inert gas Information on operating and pilot media Operation with oil lubrication not possible 6/1/24 - Subject to change - Festo SE & Co. KG 1/2 Feature Value Degree of protection IP65 Certification RCM compliance mark KC characters KC EMC CE marking (see declaration of conformity) As per EU EMC directive As per EU RoHS directive UKCA marking (see declaration of conformity) To UK instructions for EMC To UK RoHS instructions Note on materials RoHS-compliant LABS (PWIS) conformity VDMA24364 zone III Corrosion resistance class (CRC) 2 - Moderate corrosion stress DC operating voltage range 19 V ... 29 V Nominal operating voltage DC 24 V Residual ripple 10 % Reference value 4 - 20 mA Analog output signal range 4 - 20 mA Precision analog output in ± %FS 2 %FS Max. electrical power consumption 1W Reverse polarity protection for all electrical connections Short-circuit protection For all electrical connections Safety instructions VEAA/VEAB safety position: if the electrical power supply is lost, the outlet pressure is maintained in uncontrolled form, it may increase or fall – pneumatic valve blocked. Display type LED Electrical connection 4-pin M8x1 Plug as per EN 60947-5-2 Housing material PA-reinforced 6/1/24 - Subject to change - Festo SE & Co. KG 2/2
8046904
物料型号:8046904
器件简介: - 该阀是一个3通比例压力控制阀,采用直接控制方式,通过机械弹簧复位,电气驱动。 - 可以安装在任意位置,密封原理为软密封。 - 符号为00995607。
引脚分配: - 电气连接为4针M8x1插头,符合EN 60947-5-2标准。
参数特性: - 环境温度:0°C至50°C - 介质温度:5°C至50°C - 存储温度:-20°C至70°C - 尺寸:宽15mm、长54.5mm、高85mm - 气动连接:QS-4 - 密封材料:NBR - 安装类型:可选带通孔或附件 - 入口压力:0至1.1MPa(0至11bar,0至159.5psi) - 输出压力:0.003至0.6MPa(0.03至6bar,0.435至87psi) - 标准名义流量:≥101/min(2-3通道)≥61/min - 线性误差:FS的0.5% - 重复精度:FS的0.4% - 滞后:FS的0.25% - 温度系数:0.05%/K - 常温下的绝对精度:FS的0.75% - 产品重量:55g - 工作介质:符合ISO 8573-1:2010标准的压缩空气或惰性气体 - 操作和控制介质信息:不可用油润滑操作
功能详解: - 保护等级:IP65 - 认证:符合RCM合规标志 - KC特性:KC EMC - CE标志:符合EU EMC指令和EU RoHS指令 - UKCA标志:符合UK EMC和UK RoHS指令 - 材料说明:符合RoHS - LABS(PWIS)符合性:VDMA24364区域III - 耐腐蚀等级(CRC):2-中等腐蚀应力 - DC工作电压范围:19V至29V - 标称工作电压DC:24V - 剩余纹波:10% - 参考值:4-20mA - 模拟输出信号范围:4-20mA - 模拟输出精度:+FS的2% - 最大电力消耗:1W - 反极性保护:所有电气连接 - 短路保护:所有电气连接 - 安全说明:如果电源丢失,出口压力将不受控制地保持,可能会增加或下降 - 气动阀被阻塞。
应用信息: - 该阀适用于需要精确压力控制的场合,如自动化机械、气动控制系统等。
封装信息: - 外壳材料:增强型PA(聚酰胺)。
8046904 价格&库存
很抱歉,暂时无法提供与“8046904”相匹配的价格&库存,您可以联系我们找货
    • 1+6365.57250
    • 10+6238.26105
