10K3A1B
10K3A1B
    BETATHERM
10K3A1B 数据手册
10K3A1 Series 1 Thermistor • • • • • Thermally conductive epoxy coating Ø 2.4 mm Maximum Diameter 32 AWG Alloy 180 Leads Choice of 4 temperature tolerance classifications RoHS Compliant DESCRIPTION The BetaCURVE Chip is Soldered to 32 AWG Alloy 180 Leads and Encapsulated in Stycast Epoxy Resin FEATURES APPLICATIONS • • Interchangeability Proven Stability and Reliability • Rapid time response • Alloy lead wires for reduced thermal conductivity ("stem effect") Thermally Conductive Epoxy Coating Temperature range -40 ºC to +125ºC • • • • • Temperature sensing, control and compensation Tight Tolerance Instrumentation Assembly into probes for a wide variety of applications • General Instrumentation applications PERFORMANCE SPECS Parameters Resistance @ +25°C 10K3A1A Resistance tolerance from 0°C to +70°C 10K3A1B Resistance tolerance from 0°C to +70°C 10K3A1C Resistance tolerance from 0°C to +70°C 10K3A1D Resistance tolerance from 0°C to +70°C Alpha Value @ 25°C Beta Value 25/85 Tolerance on Beta Value 25/85 Time response in Liquids Dissipation Constant in still air Model Number 10K3A1 Series 1 Units Ohms °C °C °C °C %/°C K % Seconds mW/°C www.meas-spec.com 1/3 Value 10,000 0.1 0.2 0.5 1.0 4.39 3976 0.5
10K3A1B 价格&库存
很抱歉,暂时无法提供与“10K3A1B”相匹配的价格&库存,您可以联系我们找货
10K3A1B
    库存:1851
