214217
214217
    RUKO
214217 数据手册
« www.ruko.de » Twist drill sets DiN 338 type N, Hss ground 1.01 214 214 214 214 S 214 214 RO 250 214 TRO Description Article no. HSS-G Article no. HSS-G Article no. HSS-G TiN 19-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 214 214 214 214 S 250 214 T 25-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 214 215 214 215 S 250 215 T 41-piece set of twist drills DIN 338 type N Ø 6,0 mm up to 10,0 mm in increments of 0,1 mm in steel case 214 218 — — 50-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 5,9 mm in increments of 0,1 mm in steel case 214 217 — — 19-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 214 214 RO 214 214 SRO 250 214 TRO 25-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in plastic case 214 215 RO 214 215 SRO 250 215 TRO 57
214217 价格&库存
很抱歉,暂时无法提供与“214217”相匹配的价格&库存,您可以联系我们找货
