101003
101003
    RUKO
101003 数据手册
Tube and sheet drills Tube and sheet drills HSS, CBN ground with split point Point cut: work´s specification with split point DIN 1412 C Point angle: 118° Cone angle: 20-30° Ø tolerance: work´s specification Surface: bright Right hand cutting The CBN ground flutes guarantee quiet running and high cutting performance. The cone makes it easier to withdraw the tool from the material. 1.3 No. 1 Packing unit: in plastic tubes of 1 No. 2 Size no. Drilling range mm Total length mm Shank-Ø mm Article no. 1 2 3 4 5 6 7 8 9 3,0 - 14,0 5,0 - 20,0 16,0 - 30,5 24,0 - 40,0 36,0 - 50,0 40,0 - 61,0 5,0 - 25,4 5,0 - 31,0 5,0 - 22,5 58 71 76 89 97 103 87 103 79 6 8 9 10 12 13 10 9 8 101 001 101 002 101 003 101 004 101 005 101 006 101 007 101 008 101 022 Price / each € No. 3 No. 4 Tube and sheet drills HSS Co 5, CBN ground with split point Point cut: work´s specification with split point DIN 1412 C Point angle: 118° Cone angle: 20-30° Ø tolerance: work´s specification Surface: bright Right hand cutting No. 5 The CBN ground flutes guarantee quiet running and high cutting performance. The cone makes it easier to withdraw the tool from the material. No. 6 Packing unit: in plastic tubes of 1 Size no. Drilling range mm Total length mm Shank-Ø mm Article no. 1 2 3 8 3,0 - 14,0 5,0 - 20,0 16,0 - 30,5 5,0 - 31,0 58 71 76 103 6 8 9 9 101 001 E 101 002 E 101 003 E 101 008 E Price / each € No. 7 “Inch” No. 8 “Long” Tube and sheet drills HSS-TiN, CBN ground with split point Point cut: work´s specification with split point DIN 1412 C Point angle: 118° Cone angle: 20-30° Ø tolerance: work´s specification Surface: titanium-nitride coated Right hand cutting No. 9 “Antenna” The CBN ground flutes guarantee quiet running and high cutting performance. The cone makes it easier to withdraw the tool from the material. No. 1 Packing unit: in plastic tubes of 1 No. 2 Size no. Drilling range mm Total length mm Shank-Ø mm Article no. 1 2 3 8 3,0 - 14,0 5,0 - 20,0 16,0 - 30,5 5,0 - 31,0 58 71 76 103 6 8 9 9 101 001 T 101 002 T 101 003 T 101 008 T - 51 - Price / each € No. 3 No. 8 “Long”
101003 价格&库存
很抱歉,暂时无法提供与“101003”相匹配的价格&库存,您可以联系我们找货
