102-107
102-107
    RUKO
102-107 数据手册
Taper and deburring countersinkers Taper and deburring countersinkers DIN 335 type C 90° HSS CBN ground 90° cylindrical 3 bright Because of the CBN deep-ground flutes the cutting edges are extremely sharp. Ideal for burr- and chatter-free deburring and countersinking. Applicable for steel, cast iron, nonferrous and light metals. Best results at low cutting speeds. Packing unit: in plastic tubes of 1 Countersinker nominal Ø d3 d1 mm mm Total length L mm 4,3 4,8 5,0 5,3 5,8 6,0 6,3 7,0 7,3 8,0 8,3 9,4 10,0 10,4 11,5 12,4 13,4 15,0 16,5 16,5 19,0 20,5 23,0 25,0 26,0 28,0 30,0 31,0 *37,0 *40,0 40,0 40,0 40,0 40,0 45,0 45,0 45,0 50,0 50,0 50,0 50,0 50,0 50,0 50,0 56,0 56,0 56,0 60,0 60,0 60,0 63,0 63,0 67,0 67,0 71,0 71,0 71,0 71,0 90,0 80,0 1,3 1,5 1,5 1,5 1,5 1,5 1,5 1,8 1,8 2,0 2,0 2,2 2,5 2,5 2,8 2,8 2,9 3,2 3,2 3,2 3,5 3,5 3,8 3,8 3,9 4,0 4,1 4,2 4,8 10,0 Shank Ø d2 mm 4,0 4,0 4,0 4,0 5,0 5,0 5,0 6,0 6,0 6,0 6,0 6,0 6,0 6,0 8,0 8,0 8,0 10,0 8,0 10,0 10,0 10,0 10,0 10,0 12,0 12,0 12,0 12,0 12,0 15,0 Countersinkings as per DIN 74 AF BF M 2,5 M3 M 3,5 M4 M5 M6 M8 M 10 M 12 M 14 M 16 M3 M4 M5 M6 M8 M8 M 10 M 12 M 14 M 16 Article no. 1.5 d2 Price each € 102 101 102 102 102 103 102 104 102 105 102 106 102 107 102 108 102 109 102 110 102 111 102 112 102 113 102 114 102 115 102 116 102 117 102 118 102 119 102 119-1 102 120 102 121 102 122 102 123 102 171 102 124 102 172 102 125 102 173 102 174 L Counters. angle: Shank: Cutting edges: Surface: Right-hand cutting d3 d1 *Work´s specification. Emphasised articles are new additions. d2 Taper and deburring countersinkers DIN 335 type C 90° HSS CBN ground, with long cylindrical shank Counters. angle: Shank: Cutting edges: Surface: Right-hand cutting 90° cylindrical 3 bright Because of the CBN deep-ground flutes the cutting edges are extremely sharp. Ideal for burr- and chatter-free deburring and countersinking. Applicable for steel, cast iron, nonferrous and light metals. Best results at low cutting speeds. Countersinker nominal Ø d3 d1 mm mm 6,3 8,3 10,4 12,4 15,0 16,5 20,5 25,0 1,5 2,0 2,5 2,8 3,2 3,2 3,5 3,8 L Packing unit: in plastic tubes of 1 NEW Total length L mm Shank Ø d2 mm 85 85 88 108 110 112 115 118 5,0 6,0 6,0 8,0 10,0 10,0 10,0 10,0 Countersinkings as per DIN 74 AF BF M8 M3 M4 M5 M6 M8 M 10 M 12 Article no. 102 271 102 272 102 273 102 274 102 275 102 276 102 277 102 278 - 67 - Price each € d3 d1
102-107 价格&库存
很抱歉,暂时无法提供与“102-107”相匹配的价格&库存,您可以联系我们找货
