202031E
202031E
    RUKO
202031E 数据手册
NEW Twist drills Twist drills DIN 1897 type N HSS Co 5 ground, with split point - short Point cut: helical point from Ø 3,0 mm with split point DIN 1412 C Point angle: 135° Helix angle: 20-30° Ø tolerance: h8 Surface: golden brown Right-hand cutting Short and stable standard drill consisting of cobalt alloyed heavy-duty high-speed steel with higher heat-resistance. Ideally suitable for assembly work in thin-walled materials such as sheet steels, flat steels and profile steels. High security against fracture. For use in all handheld drilling machines. Applications: for steel and alloyed cast steel over 900 N/mm² strength, grey cast, malleable cast, high-alloyed chromium steel such as stainless and acid resistant steel. Packing unit: Ø 2,00 mm up to 10,20 mm in plastic box of 10 Ø 10,50 mm up to 13,00 mm in plastic box of 5 Ø mm Total length mm Flute length mm Article no. 2,00 2,50 3,00 3,10 3,20 3,25 3,30 3,40 3,50 3,60 3,70 3,80 4,00 4,10 4,20 4,25 4,40 4,50 4,70 4,80 4,90 5,00 5,10 38 43 46 49 49 49 49 52 52 52 52 55 55 55 55 55 58 58 58 62 62 62 62 12 14 16 18 18 18 18 20 20 20 20 22 22 22 22 22 24 24 24 26 26 26 26 202 020 E 202 025 E 202 030 E 202 031 E 202 032 E 202 0325 E 202 033 E 202 034 E 202 035 E 202 036 E 202 037 E 202 038 E 202 040 E 202 041 E 202 042 E 202 0425 E 202 044 E 202 045 E 202 047 E 202 048 E 202 049 E 202 050 E 202 051 E Price each € - 29 - Ø mm Total length mm Flute length mm Article no. 5,20 5,50 5,70 5,80 5,90 6,00 6,50 6,80 7,00 7,50 8,00 8,50 9,00 9,50 10,00 10,20 10,50 11,00 11,50 12,00 12,50 13,00 62 66 66 66 66 66 70 74 74 74 79 79 84 84 89 89 89 95 95 102 102 102 26 28 28 28 28 28 31 34 34 34 36 36 40 40 43 43 43 47 47 51 51 51 202 052 E 202 055 E 202 057 E 202 058 E 202 059 E 202 060 E 202 065 E 202 068 E 202 070 E 202 075 E 202 080 E 202 085 E 202 090 E 202 095 E 202 100 E 202 102 E 202 105 E 202 110 E 202 115 E 202 120 E 202 125 E 202 130 E Price each € 1.1
202031E 价格&库存
很抱歉,暂时无法提供与“202031E”相匹配的价格&库存,您可以联系我们找货
