214850
214850
    RUKO
214850 数据手册
» TwisT DRiLLs Page 1.01 Twist drills 22 25 28 31 33 36 38 42 44 48 50 52 54 58 60 61 64 66 68 70 71 DIN 338 type VA, HSSE-Co 8 DIN 338 type N, HSSE-Co 8 DIN 338 type UF-L, HSSE-Co 5 DIN 338 type FO, HSSE-Co 5 DIN 338 TL 3000, HSSE-Co 5 DIN 338 type VA, HSSE-Co 5 DIN 338 type VA, HSSE-Co 5 DIN 338 type UNI, HSSE-Co 5 DIN 338 TL 3000, HSS-G DIN 338 type TURBO, HSS-G DIN 338 type W, HSS-G DIN 338 type N, HSS-G DIN 338 type N, HSS-G DIN 338 type N, HSS-G - left hand cutting DIN 338 type N, with reduced shank DIN 338 type N, HSS-R DIN 338 type N, with brazed-on TC cutting inserts DIN 338 type N, Solid TC DIN 338 TL 3000, in fractional sizes DIN 338 type N, in fractional sizes DIN 338 type VA, in fractional sizes 72 74 76 78 80 82 84 DIN 340 TL 3000, HSSE-Co 5 DIN 340 type N, HSS-G DIN 1869 TL 3000, HSS-G - extra long DIN 345 type N, HSS and HSSE-Co 5 DIN 1897 type UF-L, HSSE-Co 5 - short DIN 1897 type N, HSSE-Co 5 - short DIN 1897 type N, HSS-G - short 86 87 88 89 90 91 92 93 Spot drills type N, HSS-G - extra short Double end drills type KV, HSS-G NC-spot drills 90º, HSSE-Co 5 NC-spot drills 90º, HSSE-Co 5 with weldon shank NC-spot drills 120º, HSSE-Co 5 NC-spot drills 120º, HSSE-Co 5 with weldon shank Centre drills DIN 333, HSS Hollow section twist drills type N, HSS-G 18 « www.ruko.de » Overview of symbols DIN 333 DIN 345 Centre drills 60º shape A and R DIN 338 Twist drills with morse taper shank DIN 1869 Short twist drills with straight shank DIN 340 Extra long twist drills with straight shank DIN 1897 Extra short twist drills with straight shank High-speed steel, ground HSSE Co 8 High-speed steel with 8 % Cobalt content, ground HSS-G HSS High-speed steel HSS-R High-speed steel rolled HSSE Co 5 High-speed steel with 5 % Cobalt content, ground Long twist drills with straight shank 1.01 TC Tungsten carbide bright Gold / black oxidized surface TiAlN coating Gold surface TiN coating AlTiN coating Black surface TiCN coating TECRONA coating bright / black surface left hand cutting right hand cutting 130° Point angle e.g. 130° 40° Helix angle e.g. 40° 5xD 60° Drilling depth e.g. 5 x diameter Centre angle e.g. 60º h8 ≥ Ø 4,0 mm Tolerance e.g. h8 Shank: cylindrical Shank: reduced Shank: 3-way clamping surface Shank: Weldon Shank: Morse taper NEW at RUKO Very suitable for all-purpose use in drilling machines and cordless drills 19 Overview of symbols TL 3000 Helix angle: Profile of flute: Core: Point angle: Point cut: 40º wide with rounded rear edges thick 130º shape C 38º wide with rounded rear edges very thick 130º shape C W Helix angle: Profile of flute: Core: Point angle: Point cut: 35-40º wide, for better chip removal normal 130º shape C Ti Helix angle: Profile of flute: Core: Point angle: Point cut: 36º normal thickened 130º shape C UNI Helix angle: Profile of flute: Core: Point angle: Point cut: 40º wide, for better chip removal normal 135º shape C UF-L Helix angle: Profile of flute: Core: Point angle: Point cut: 40º wide with rounded rear edges very thick 130º shape U VA Helix angle: Profile of flute: Core: Point angle: Point cut: 36º normal thickened 130º shape C TURBO Helix angle: Profile of flute: Core: Centre angle: Point cut: 36º normal thickened 130º shape C KV Helix angle: Profile of flute: Core: Point angle: Point cut: 25-30º normal normal 130º shape C NC 90 Helix angle: Profile of flute: Core: Point angle: Point cut: 25-30º normal normal 90º only the flute is grinded NC 120 Helix angle: Profile of flute: Core: Point angle: Point cut: 25-30º normal normal 120º only the flute is grinded N Helix angle: Profile of flute: Core: Point angle: Point cut: 25-30º normal normal 118º form C FO Helix angle: Profile of flute: Core: Point angle: Point cut: 1.01 Helix angle Point angle Core 20 Profile of flute Point cut « www.ruko.de » Point cuts in accordance with DiN 1412 N A B C D E Shape N: Helical point normal ground Applications: for all normal drilling work in steel, non-ferrous metal and plastic. The point angles depend on the ease with which the materials can be cut. Advantages: powerful main cut, resistant to impact and lateral forces. Simple manual grinding possible. Disadvantages: broad cutting edge requires considerable pressure. Shape A: Cut chisel edge Applications: for all normal drilling work using drills with a strong core, for drilling into solid materials with larger drill diameters. Advantages: good centring when starting to drill, as the length of the chisel edge is reduced to 1/10 of the drill diameter, and fewer pressure is required. Disadvantages: additional regrinding work. Shape B: Cut chisel edge with corrected major cutting edge Applications: for drilling high-density steel, for manganese steel with over 10 % Mn, for hard spring steel and for drilling out. Advantages: resistant to impact, one-way load and lateral forces. Does not catch in thin workpieces. Disadvantages: high pressure required, tendency to slip, extra work involved in regrinding. Shape C: Split point Applications: for drills with very strong cores, for particularly tough, hard materials and for deep-hole drills. Advantages: good centring, little pressure required. Chip spreading improves chip removal. Disadvantages: perfect grinding only possible by machine. Shape D: Ground for grey cast iron Applications: for drilling grey cast iron, malleable cast iron and forgings. Advantages: wear on cutting corners is reduced by extended major cutting edges, resistant to impact, good heat conductivity, all giving improved tool life. Disadvantages: extra work involved in regrinding. Shape E: Centre point Applications: for drilling sheet-metal and soft materials, for blind holes with flat bottoms. Advantages: good centring, minimal formation of burrs when through-drilling, precise drilling in thin sheets and pipes, does not catch. Available in diameters of 2.5 mm upwards. Disadvantages: sensitive to impact and one-way loading. Can only be ground to perfection by machine. Other point cuts U Shape U: Special ground Applications: for drills with sturdy profiles suitable for use in automated processing, with narrow grooves and strong cores. Advantages: extremely good self-centring behaviour when maximum cutting valuminiumes are employed. Concave cutting produces short metal chips. Disadvantages: extra work involved in regrinding. 21 1.01 Twist drills DiN 338 type VA, HssE-Co 8 ground Ø DIN 338 VA HSSE Co 8 C 5xD 130° ≥ Ø 2,0 mm h8 36° 1.01 L2 Powerful special drill that should ideally be used for titanium base alloys as well as stainless, acid-resistant and heat-resistant austenitic steels. It is also suitable for high strength steels with low ductility. Under certain conditions, these drills can be used for special alloys such as hastelloy, inconel and nimonic etc. L1 Packing unit: in plastic box HSSE Co 8 HSSE Co 8 steel (N/mm2) < 900 < 1100 < 1300 Main application 22 stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSSE-Co 8 Cont. pcs. Article no. HSSE-Co 8 TiAlN Cont. pcs. 1,00 1,10 1,20 1,30 1,40 1,50 1,60 1,70 1,80 1,90 2,00 2,10 2,20 2,30 2,40 2,50 2,60 2,70 2,80 2,90 3,00 3,10 3,20 3,30 3,40 3,50 3,60 3,70 3,80 3,90 4,00 4,10 4,20 4,30 4,40 34,0 36,0 38,0 38,0 40,0 40,0 43,0 43,0 46,0 46,0 49,0 49,0 53,0 53,0 57,0 57,0 57,0 61,0 61,0 61,0 61,0 65,0 65,0 65,0 70,0 70,0 70,0 70,0 75,0 75,0 75,0 75,0 75,0 80,0 80,0 12,0 14,0 16,0 16,0 18,0 18,0 20,0 20,0 22,0 22,0 24,0 24,0 27,0 27,0 30,0 30,0 30,0 33,0 33,0 33,0 33,0 36,0 36,0 36,0 39,0 39,0 39,0 39,0 43,0 43,0 43,0 43,0 43,0 47,0 47,0 281 010 E 281 011 E 281 012 E 281 013 E 281 014 E 281 015 E 281 016 E 281 017 E 281 018 E 281 019 E 281 020 E 281 021 E 281 022 E 281 023 E 281 024 E 281 025 E 281 026 E 281 027 E 281 028 E 281 029 E 281 030 E 281 031 E 281 032 E 281 033 E 281 034 E 281 035 E 281 036 E 281 037 E 281 038 E 281 039 E 281 040 E 281 041 E 281 042 E 281 043 E 281 044 E 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 281 010 EF 281 011 EF 281 012 EF 281 013 EF 281 014 EF 281 015 EF 281 016 EF 281 017 EF 281 018 EF 281 019 EF 281 020 EF 281 021 EF 281 022 EF 281 023 EF 281 024 EF 281 025 EF 281 026 EF 281 027 EF 281 028 EF 281 029 EF 281 030 EF 281 031 EF 281 032 EF 281 033 EF 281 034 EF 281 035 EF 281 036 EF 281 037 EF 281 038 EF 281 039 EF 281 040 EF 281 041 EF 281 042 EF 281 043 EF 281 044 EF 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » Ø mm L1 mm L2 mm Article no. HSSE-Co 8 Cont. pcs. Article no. HSSE-Co 8 TiAlN Cont. pcs. 4,50 4,60 4,70 4,80 4,90 5,00 5,10 5,20 5,30 5,40 5,50 5,60 5,70 5,80 5,90 6,00 6,10 6,20 6,30 6,40 6,50 6,60 6,70 6,80 6,90 7,00 7,10 7,20 7,30 7,40 7,50 7,60 7,70 7,80 7,90 8,00 8,10 8,20 8,30 8,40 8,50 8,60 8,70 8,80 8,90 9,00 9,10 9,20 9,30 9,40 9,50 9,60 9,70 9,80 9,90 10,00 10,20 10,50 11,00 11,50 12,00 12,50 13,00 13,50 14,00 14,50 15,00 15,50 16,00 80,0 80,0 80,0 86,0 86,0 86,0 86,0 86,0 86,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 142,0 142,0 151,0 151,0 151,0 160,0 160,0 169,0 169,0 178,0 178,0 47,0 47,0 47,0 52,0 52,0 52,0 52,0 52,0 52,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 94,0 94,0 101,0 101,0 101,0 108,0 108,0 114,0 114,0 120,0 120,0 281 045 E 281 046 E 281 047 E 281 048 E 281 049 E 281 050 E 281 051 E 281 052 E 281 053 E 281 054 E 281 055 E 281 056 E 281 057 E 281 058 E 281 059 E 281 060 E 281 061 E 281 062 E 281 063 E 281 064 E 281 065 E 281 066 E 281 067 E 281 068 E 281 069 E 281 070 E 281 071 E 281 072 E 281 073 E 281 074 E 281 075 E 281 076 E 281 077 E 281 078 E 281 079 E 281 080 E 281 081 E 281 082 E 281 083 E 281 084 E 281 085 E 281 086 E 281 087 E 281 088 E 281 089 E 281 090 E 281 091 E 281 092 E 281 093 E 281 094 E 281 095 E 281 096 E 281 097 E 281 098 E 281 099 E 281 100 E 281 102 E 281 105 E 281 110 E 281 115 E 281 120 E 281 125 E 281 130 E 281 135 E 281 140 E 281 145 E 281 150 E 281 155 E 281 160 E 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 281 045 EF 281 046 EF 281 047 EF 281 048 EF 281 049 EF 281 050 EF 281 051 EF 281 052 EF 281 053 EF 281 054 EF 281 055 EF 281 056 EF 281 057 EF 281 058 EF 281 059 EF 281 060 EF 281 061 EF 281 062 EF 281 063 EF 281 064 EF 281 065 EF 281 066 EF 281 067 EF 281 068 EF 281 069 EF 281 070 EF 281 071 EF 281 072 EF 281 073 EF 281 074 EF 281 075 EF 281 076 EF 281 077 EF 281 078 EF 281 079 EF 281 080 EF 281 081 EF 281 082 EF 281 083 EF 281 084 EF 281 085 EF 281 086 EF 281 087 EF 281 088 EF 281 089 EF 281 090 EF 281 091 EF 281 092 EF 281 093 EF 281 094 EF 281 095 EF 281 096 EF 281 097 EF 281 098 EF 281 099 EF 281 100 EF 281 102 EF 281 105 EF 281 110 EF 281 115 EF 281 120 EF 281 125 EF 281 130 EF 281 135 EF 281 140 EF 281 145 EF 281 150 EF 281 155 EF 281 160 EF 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 23 1.01 Twist drill sets DiN 338 type VA, HssE-Co 8 ground 1.01 281 214 E 281 214 EF 281 214 ERO 281 214 EFRO Description Article no. HSSE-Co 8 Article no. HSSE-Co 8 TiAlN 19-piece set of twist drills DIN 338 type VA Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 281 214 E 281 214 EF 25-piece set of twist drills DIN 338 type VA Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 281 215 E 281 215 EF 19-piece set of twist drills DIN 338 type VA Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 281 214 ERO 281 214 EFRO 25-piece set of twist drills DIN 338 type VA Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in plastic case 281 215 ERO 281 215 EFRO 24 « www.ruko.de » Twist drills DiN 338 type N, HssE-Co 8 ground Ø DIN 338 N HSSE Co 8 C 5xD 118° ≥ Ø 2,0 mm h8 25-30° 1.01 L2 Exceptionally high-performance twist drills made from high-alloyed CoMo steel (8 % Co, 10 % Mo) with extremely distinctive heat resistance. For processing high-strength alloys and stainless, acid-resistant and heat-resistant steel. L1 Packing unit: in plastic box HSSE Co 8 HSSE Co 8 steel (N/mm2) < 900 < 1100 < 1300 Main application stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSSE-Co 8 Cont. pcs. Article no. HSSE-Co 8 TiAlN Cont. pcs. 1,00 1,10 1,20 1,30 1,40 1,50 1,60 1,70 1,80 1,90 2,00 2,10 2,20 2,30 2,40 2,50 2,60 2,70 2,80 2,90 3,00 3,10 3,20 3,30 3,40 3,50 3,60 3,70 3,80 3,90 4,00 4,10 4,20 4,30 4,40 4,50 34,0 36,0 38,0 38,0 40,0 40,0 43,0 43,0 46,0 46,0 49,0 49,0 53,0 53,0 57,0 57,0 57,0 61,0 61,0 61,0 61,0 65,0 65,0 65,0 70,0 70,0 70,0 70,0 75,0 75,0 75,0 75,0 75,0 80,0 80,0 80,0 12,0 14,0 16,0 16,0 18,0 18,0 20,0 20,0 22,0 22,0 24,0 24,0 27,0 27,0 30,0 30,0 30,0 33,0 33,0 33,0 33,0 36,0 36,0 36,0 39,0 39,0 39,0 39,0 43,0 43,0 43,0 43,0 43,0 47,0 47,0 47,0 282 010 E 282 011 E 282 012 E 282 013 E 282 014 E 282 015 E 282 016 E 282 017 E 282 018 E 282 019 E 282 020 E 282 021 E 282 022 E 282 023 E 282 024 E 282 025 E 282 026 E 282 027 E 282 028 E 282 029 E 282 030 E 282 031 E 282 032 E 282 033 E 282 034 E 282 035 E 282 036 E 282 037 E 282 038 E 282 039 E 282 040 E 282 041 E 282 042 E 282 043 E 282 044 E 282 045 E 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 282 010 EF 282 011 EF 282 012 EF 282 013 EF 282 014 EF 282 015 EF 282 016 EF 282 017 EF 282 018 EF 282 019 EF 282 020 EF 282 021 EF 282 022 EF 282 023 EF 282 024 EF 282 025 EF 282 026 EF 282 027 EF 282 028 EF 282 029 EF 282 030 EF 282 031 EF 282 032 EF 282 033 EF 282 034 EF 282 035 EF 282 036 EF 282 037 EF 282 038 EF 282 039 EF 282 040 EF 282 041 EF 282 042 EF 282 043 EF 282 044 EF 282 045 EF 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 25 Twist drills DiN 338 type N, HssE-Co 8 ground 1.01 26 Ø mm L1 mm L2 mm Article no. HSSE-Co 8 Cont. pcs. Article no. HSSE-Co 8 TiAlN Cont. pcs. 4,60 4,70 4,80 4,90 5,00 5,10 5,20 5,30 5,40 5,50 5,60 5,70 5,80 5,90 6,00 6,10 6,20 6,30 6,40 6,50 6,60 6,70 6,80 6,90 7,00 7,10 7,20 7,30 7,40 7,50 7,60 7,70 7,80 7,90 8,00 8,10 8,20 8,30 8,40 8,50 8,60 8,70 8,80 8,90 9,00 9,10 9,20 9,30 9,40 9,50 9,60 9,70 9,80 9,90 10,00 10,20 10,50 11,00 11,50 12,00 12,50 13,00 13,50 14,00 14,50 15,00 15,50 16,00 80,0 80,0 86,0 86,0 86,0 86,0 86,0 86,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 142,0 142,0 151,0 151,0 151,0 160,0 160,0 169,0 169,0 178,0 178,0 47,0 47,0 52,0 52,0 52,0 52,0 52,0 52,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 94,0 94,0 101,0 101,0 101,0 108,0 108,0 114,0 114,0 120,0 120,0 282 046 E 282 047 E 282 048 E 282 049 E 282 050 E 282 051 E 282 052 E 282 053 E 282 054 E 282 055 E 282 056 E 282 057 E 282 058 E 282 059 E 282 060 E 282 061 E 282 062 E 282 063 E 282 064 E 282 065 E 282 066 E 282 067 E 282 068 E 282 069 E 282 070 E 282 071 E 282 072 E 282 073 E 282 074 E 282 075 E 282 076 E 282 077 E 282 078 E 282 079 E 282 080 E 282 081 E 282 082 E 282 083 E 282 084 E 282 085 E 282 086 E 282 087 E 282 088 E 282 089 E 282 090 E 282 091 E 282 092 E 282 093 E 282 094 E 282 095 E 282 096 E 282 097 E 282 098 E 282 099 E 282 100 E 282 102 E 282 105 E 282 110 E 282 115 E 282 120 E 282 125 E 282 130 E 282 135 E 282 140 E 282 145 E 282 150 E 282 155 E 282 160 E 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 282 046 EF 282 047 EF 282 048 EF 282 049 EF 282 050 EF 282 051 EF 282 052 EF 282 053 EF 282 054 EF 282 055 EF 282 056 EF 282 057 EF 282 058 EF 282 059 EF 282 060 EF 282 061 EF 282 062 EF 282 063 EF 282 064 EF 282 065 EF 282 066 EF 282 067 EF 282 068 EF 282 069 EF 282 070 EF 282 071 EF 282 072 EF 282 073 EF 282 074 EF 282 075 EF 282 076 EF 282 077 EF 282 078 EF 282 079 EF 282 080 EF 282 081 EF 282 082 EF 282 083 EF 282 084 EF 282 085 EF 282 086 EF 282 087 EF 282 088 EF 282 089 EF 282 090 EF 282 091 EF 282 092 EF 282 093 EF 282 094 EF 282 095 EF 282 096 EF 282 097 EF 282 098 EF 282 099 EF 282 100 EF 282 102 EF 282 105 EF 282 110 EF 282 115 EF 282 120 EF 282 125 EF 282 130 EF 282 135 EF 282 140 EF 282 145 EF 282 150 EF 282 155 EF 282 160 EF 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 « www.ruko.de » Twist drill sets DiN 338 type N, HssE-Co 8 ground 1.01 282 214 E 282 214 EF 282 214 ERO 282 214 EFRO Description Article no. HSSE-Co 8 Article no. HSSE-Co 8 TiAlN 19-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 282 214 E 282 214 EF 25-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 282 215 E 282 215 EF 19-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 282 214 ERO 282 214 EFRO 25-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in plastic case 282 215 ERO 282 215 EFRO 27 Twist drills DiN 338 type UF-L, HssE-Co 5 ground Ø DIN 338 UF-L HSSE Co 5 U 5xD 130° ≥ Ø 2,0 mm h8 40° 1.01 L2 Best multirange drill with distinctive heat resistance and universal deep-hole flute with special geometry for optimising chip formation and removal. Enables deeper holes to be drilled without cooling and ventilation. Particularly broad use for all middle and long-chipping materials. The extremely wide core and broad deep-hole flute with rounded rear edges also make this drill ideal for use as a type W, type H and type VA. L1 Packing unit: in plastic box HSSE Co 5 HSSE Co 5 steel (N/mm2) < 900 < 1100 < 1300 Main application 28 stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiAlN Cont. pcs. 1,00 1,10 1,20 1,30 1,40 1,50 1,60 1,70 1,80 1,90 2,00 2,10 2,20 2,30 2,40 2,50 2,60 2,70 2,80 2,90 3,00 3,10 3,20 3,30 3,40 3,50 3,60 3,70 3,80 3,90 4,00 4,10 4,20 4,30 4,40 34,0 36,0 38,0 38,0 40,0 40,0 43,0 43,0 46,0 46,0 49,0 49,0 53,0 53,0 57,0 57,0 57,0 61,0 61,0 61,0 61,0 65,0 65,0 65,0 70,0 70,0 70,0 70,0 75,0 75,0 75,0 75,0 75,0 80,0 80,0 12,0 14,0 16,0 16,0 18,0 18,0 20,0 20,0 22,0 22,0 24,0 24,0 27,0 27,0 30,0 30,0 30,0 33,0 33,0 33,0 33,0 36,0 36,0 36,0 39,0 39,0 39,0 39,0 43,0 43,0 43,0 43,0 43,0 47,0 47,0 283 010 E 283 011 E 283 012 E 283 013 E 283 014 E 283 015 E 283 016 E 283 017 E 283 018 E 283 019 E 283 020 E 283 021 E 283 022 E 283 023 E 283 024 E 283 025 E 283 026 E 283 027 E 283 028 E 283 029 E 283 030 E 283 031 E 283 032 E 283 033 E 283 034 E 283 035 E 283 036 E 283 037 E 283 038 E 283 039 E 283 040 E 283 041 E 283 042 E 283 043 E 283 044 E 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 283 010 EF 283 011 EF 283 012 EF 283 013 EF 283 014 EF 283 015 EF 283 016 EF 283 017 EF 283 018 EF 283 019 EF 283 020 EF 283 021 EF 283 022 EF 283 023 EF 283 024 EF 283 025 EF 283 026 EF 283 027 EF 283 028 EF 283 029 EF 283 030 EF 283 031 EF 283 032 EF 283 033 EF 283 034 EF 283 035 EF 283 036 EF 283 037 EF 283 038 EF 283 039 EF 283 040 EF 283 041 EF 283 042 EF 283 043 EF 283 044 EF 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiAlN Cont. pcs. 4,50 4,60 4,70 4,80 4,90 5,00 5,10 5,20 5,30 5,40 5,50 5,60 5,70 5,80 5,90 6,00 6,10 6,20 6,30 6,40 6,50 6,60 6,70 6,80 6,90 7,00 7,10 7,20 7,30 7,40 7,50 7,60 7,70 7,80 7,90 8,00 8,10 8,20 8,30 8,40 8,50 8,60 8,70 8,80 8,90 9,00 9,10 9,20 9,30 9,40 9,50 9,60 9,70 9,80 9,90 10,00 10,10 10,20 10,30 10,40 10,50 10,60 10,70 10,80 10,90 11,00 11,10 80,0 80,0 80,0 86,0 86,0 86,0 86,0 86,0 86,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 142,0 142,0 142,0 142,0 142,0 47,0 47,0 47,0 52,0 52,0 52,0 52,0 52,0 52,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 94,0 94,0 94,0 94,0 94,0 283 045 E 283 046 E 283 047 E 283 048 E 283 049 E 283 050 E 283 051 E 283 052 E 283 053 E 283 054 E 283 055 E 283 056 E 283 057 E 283 058 E 283 059 E 283 060 E 283 061 E 283 062 E 283 063 E 283 064 E 283 065 E 283 066 E 283 067 E 283 068 E 283 069 E 283 070 E 283 071 E 283 072 E 283 073 E 283 074 E 283 075 E 283 076 E 283 077 E 283 078 E 283 079 E 283 080 E 283 081 E 283 082 E 283 083 E 283 084 E 283 085 E 283 086 E 283 087 E 283 088 E 283 089 E 283 090 E 283 091 E 283 092 E 283 093 E 283 094 E 283 095 E 283 096 E 283 097 E 283 098 E 283 099 E 283 100 E 283 101 E 283 102 E 283 103 E 283 104 E 283 105 E 283 106 E 283 107 E 283 108 E 283 109 E 283 110 E 283 111 E 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 283 045 EF 283 046 EF 283 047 EF 283 048 EF 283 049 EF 283 050 EF 283 051 EF 283 052 EF 283 053 EF 283 054 EF 283 055 EF 283 056 EF 283 057 EF 283 058 EF 283 059 EF 283 060 EF 283 061 EF 283 062 EF 283 063 EF 283 064 EF 283 065 EF 283 066 EF 283 067 EF 283 068 EF 283 069 EF 283 070 EF 283 071 EF 283 072 EF 283 073 EF 283 074 EF 283 075 EF 283 076 EF 283 077 EF 283 078 EF 283 079 EF 283 080 EF 283 081 EF 283 082 EF 283 083 EF 283 084 EF 283 085 EF 283 086 EF 283 087 EF 283 088 EF 283 089 EF 283 090 EF 283 091 EF 283 092 EF 283 093 EF 283 094 EF 283 095 EF 283 096 EF 283 097 EF 283 098 EF 283 099 EF 283 100 EF 283 101 EF 283 102 EF 283 103 EF 283 104 EF 283 105 EF 283 106 EF 283 107 EF 283 108 EF 283 109 EF 283 110 EF 283 111 EF 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 29 1.01 Twist drills DiN 338 type UF-L, HssE-Co 5 ground 1.01 Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiAlN Cont. pcs. 11,20 11,30 11,40 11,50 11,60 11,70 11,80 11,90 12,00 12,10 12,20 12,30 12,40 12,50 12,60 12,70 12,80 12,90 13,00 13,50 14,00 14,50 15,00 15,50 16,00 142,0 142,0 142,0 142,0 142,0 142,0 142,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 160,0 160,0 169,0 169,0 178,0 178,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 108,0 108,0 114,0 114,0 120,0 120,0 283 112 E 283 113 E 283 114 E 283 115 E 283 116 E 283 117 E 283 118 E 283 119 E 283 120 E 283 121 E 283 122 E 283 123 E 283 124 E 283 125 E 283 126 E 283 127 E 283 128 E 283 129 E 283 130 E 283 135 E 283 140 E 283 145 E 283 150 E 283 155 E 283 160 E 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 283 112 EF 283 113 EF 283 114 EF 283 115 EF 283 116 EF 283 117 EF 283 118 EF 283 119 EF 283 120 EF 283 121 EF 283 122 EF 283 123 EF 283 124 EF 283 125 EF 283 126 EF 283 127 EF 283 128 EF 283 129 EF 283 130 EF 283 135 EF 283 140 EF 283 145 EF 283 150 EF 283 155 EF 283 160 EF 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 Twist drill sets DiN 338 type UF-L, HssE-Co 5 ground 283 214 E 283 214 EF 283 214 ERO 283 214 EFRO Description Article no. HSSE-Co 5 Article no. HSSE-Co 5 TiAlN 19-piece set of twist drills DIN 338 type UF-L Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 283 214 E 283 214 EF 25-piece set of twist drills DIN 338 type UF-L Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 283 215 E 283 215 EF 19-piece set of twist drills DIN 338 type UF-L Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 283 214 ERO 283 214 EFRO 25-piece set of twist drills DIN 338 type UF-L Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in plastic case 283 215 ERO 283 215 EFRO 30 « www.ruko.de » Twist drills DiN 338 type FO, HssE-Co 5 ground Ø DIN 338 FO C HSSE Co 5 5xD ≥ Ø 2,0 mm h8 130° 38° 1.01 L2 Highly stable multirange drill with excellent thermal resilience, a large chip space, a rounded rear edge and a very thick core. Ideal for drilling materials of low to high strength. L1 Packing unit: in plastic box steel (N/mm2) < 900 < 1100 < 1300 Main application stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. 1,00 1,10 1,20 1,30 1,40 1,50 1,60 1,70 1,80 1,90 2,00 2,10 2,20 2,30 2,40 2,50 2,60 2,70 2,80 2,90 3,00 3,10 3,20 3,30 3,40 3,50 3,60 3,70 3,80 3,90 4,00 4,10 4,20 4,30 4,40 34,0 36,0 38,0 38,0 40,0 40,0 43,0 43,0 46,0 46,0 49,0 49,0 53,0 53,0 57,0 57,0 57,0 61,0 61,0 61,0 61,0 65,0 65,0 65,0 70,0 70,0 70,0 70,0 75,0 75,0 75,0 75,0 75,0 80,0 80,0 12,0 14,0 16,0 16,0 18,0 18,0 20,0 20,0 22,0 22,0 24,0 24,0 27,0 27,0 30,0 30,0 30,0 33,0 33,0 33,0 33,0 36,0 36,0 36,0 39,0 39,0 39,0 39,0 43,0 43,0 43,0 43,0 43,0 47,0 47,0 280 010 E 280 011 E 280 012 E 280 013 E 280 014 E 280 015 E 280 016 E 280 017 E 280 018 E 280 019 E 280 020 E 280 021 E 280 022 E 280 023 E 280 024 E 280 025 E 280 026 E 280 027 E 280 028 E 280 029 E 280 030 E 280 031 E 280 032 E 280 033 E 280 034 E 280 035 E 280 036 E 280 037 E 280 038 E 280 039 E 280 040 E 280 041 E 280 042 E 280 043 E 280 044 E 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 4,50 4,60 4,70 4,80 4,90 5,00 5,10 5,20 5,30 5,40 5,50 5,60 5,70 5,80 5,90 6,00 6,10 6,20 6,30 6,40 6,50 6,60 6,70 6,80 6,90 7,00 7,10 7,20 7,30 7,40 7,50 7,60 7,70 7,80 7,90 80,0 80,0 80,0 86,0 86,0 86,0 86,0 86,0 86,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 117,0 117,0 117,0 117,0 47,0 47,0 47,0 52,0 52,0 52,0 52,0 52,0 52,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 75,0 75,0 75,0 75,0 280 045 E 280 046 E 280 047 E 280 048 E 280 049 E 280 050 E 280 051 E 280 052 E 280 053 E 280 054 E 280 055 E 280 056 E 280 057 E 280 058 E 280 059 E 280 060 E 280 061 E 280 062 E 280 063 E 280 064 E 280 065 E 280 066 E 280 067 E 280 068 E 280 069 E 280 070 E 280 071 E 280 072 E 280 073 E 280 074 E 280 075 E 280 076 E 280 077 E 280 078 E 280 079 E 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 31 Twist drills DiN 338 type FO, HssE-Co 5 ground 1.01 Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. 8,00 8,10 8,20 8,30 8,40 8,50 8,60 8,70 8,80 8,90 9,00 9,10 9,20 9,30 9,40 9,50 9,60 117,0 117,0 117,0 117,0 117,0 117,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 133,0 75,0 75,0 75,0 75,0 75,0 75,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 87,0 280 080 E 280 081 E 280 082 E 280 083 E 280 084 E 280 085 E 280 086 E 280 087 E 280 088 E 280 089 E 280 090 E 280 091 E 280 092 E 280 093 E 280 094 E 280 095 E 280 096 E 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. 9,70 9,80 9,90 10,00 10,20 10,50 11,00 11,50 12,00 12,50 13,00 13,50 14,00 14,50 15,00 15,50 16,00 133,0 133,0 133,0 133,0 133,0 133,0 142,0 142,0 151,0 151,0 151,0 160,0 160,0 169,0 169,0 178,0 178,0 87,0 87,0 87,0 87,0 87,0 87,0 94,0 94,0 101,0 101,0 101,0 108,0 108,0 114,0 114,0 120,0 120,0 280 097 E 280 098 E 280 099 E 280 100 E 280 102 E 280 105 E 280 110 E 280 115 E 280 120 E 280 125 E 280 130 E 280 135 E 280 140 E 280 145 E 280 150 E 280 155 E 280 160 E 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 Twist drill sets DiN 338 type FO, HssE-Co 5 ground Description Article no. HSSE-Co 5 19-piece set of twist drills DIN 338 type FO Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 280 214 E 25-piece set of twist drills DIN 338 type FO Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 280 215 E 19-piece set of twist drills DIN 338 type FO Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 280 214 ERO 25-piece set of twist drills DIN 338 type FO Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm plastic case 280 215 ERO 280 214 E 32 « www.ruko.de » Ø Twist drills DiN 338 TL 3000, HssE-Co 5 ground DIN 338 TL HSSE 3000 Co 5 C 5xD 130° ≥ Ø 2,0 mm h8 40° 1.01 L2 Highly stable multirange drill with outstanding heat resistance, a reinforced drill core and a parabolic flute for ideal chip removal. Ideal for drilling medium and long-chipping materials. Thanks to its thick core and the special flute with a rounded rear edge, this drill is best suited for high-performance use. It covers types N, H and W for a wide range of applications. L1 Packing unit: in plastic box HSSE Co 5 HSSE Co 5 steel (N/mm2) < 900 < 1100 < 1300 Main application stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiAlN Cont. pcs. 1,00 1,10 1,20 1,30 1,40 1,50 1,60 1,70 1,80 1,90 2,00 2,10 2,20 2,30 2,40 2,50 2,60 2,70 2,80 2,90 3,00 3,10 3,20 3,30 3,40 3,50 3,60 3,70 3,80 3,90 4,00 4,10 4,20 4,30 4,40 34,0 36,0 38,0 38,0 40,0 40,0 43,0 43,0 46,0 46,0 49,0 49,0 53,0 53,0 57,0 57,0 57,0 61,0 61,0 61,0 61,0 65,0 65,0 65,0 70,0 70,0 70,0 70,0 75,0 75,0 75,0 75,0 75,0 80,0 80,0 12,0 14,0 16,0 16,0 18,0 18,0 20,0 20,0 22,0 22,0 24,0 24,0 27,0 27,0 30,0 30,0 30,0 33,0 33,0 33,0 33,0 36,0 36,0 36,0 39,0 39,0 39,0 39,0 43,0 43,0 43,0 43,0 43,0 47,0 47,0 229 010 229 011 229 012 229 013 229 014 229 015 229 016 229 017 229 018 229 019 229 020 229 021 229 022 229 023 229 024 229 025 229 026 229 027 229 028 229 029 229 030 229 031 229 032 229 033 229 034 229 035 229 036 229 037 229 038 229 039 229 040 229 041 229 042 229 043 229 044 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 229 010 F 229 011 F 229 012 F 229 013 F 229 014 F 229 015 F 229 016 F 229 017 F 229 018 F 229 019 F 229 020 F 229 021 F 229 022 F 229 023 F 229 024 F 229 025 F 229 026 F 229 027 F 229 028 F 229 029 F 229 030 F 229 031 F 229 032 F 229 033 F 229 034 F 229 035 F 229 036 F 229 037 F 229 038 F 229 039 F 229 040 F 229 041 F 229 042 F 229 043 F 229 044 F 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 33 Twist drills DiN 338 TL 3000, HssE-Co 5 ground 1.01 34 Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiAlN Cont. pcs. 4,50 4,60 4,70 4,80 4,90 5,00 5,10 5,20 5,30 5,40 5,50 5,60 5,70 5,80 5,90 6,00 6,10 6,20 6,30 6,40 6,50 6,60 6,70 6,80 6,90 7,00 7,10 7,20 7,30 7,40 7,50 7,60 7,70 7,80 7,90 8,00 8,10 8,20 8,30 8,40 8,50 8,60 8,70 8,80 8,90 9,00 9,10 9,20 9,30 9,40 9,50 9,60 9,70 9,80 9,90 10,00 10,10 10,20 10,30 10,40 10,50 10,60 10,70 10,80 10,90 11,00 11,10 80,0 80,0 80,0 86,0 86,0 86,0 86,0 86,0 86,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 142,0 142,0 142,0 142,0 142,0 47,0 47,0 47,0 52,0 52,0 52,0 52,0 52,0 52,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 94,0 94,0 94,0 94,0 94,0 229 045 229 046 229 047 229 048 229 049 229 050 229 051 229 052 229 053 229 054 229 055 229 056 229 057 229 058 229 059 229 060 229 061 229 062 229 063 229 064 229 065 229 066 229 067 229 068 229 069 229 070 229 071 229 072 229 073 229 074 229 075 229 076 229 077 229 078 229 079 229 080 229 081 229 082 229 083 229 084 229 085 229 086 229 087 229 088 229 089 229 090 229 091 229 092 229 093 229 094 229 095 229 096 229 097 229 098 229 099 229 100 229 101 229 102 229 103 229 104 229 105 229 106 229 107 229 108 229 109 229 110 229 111 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 229 045 F 229 046 F 229 047 F 229 048 F 229 049 F 229 050 F 229 051 F 229 052 F 229 053 F 229 054 F 229 055 F 229 056 F 229 057 F 229 058 F 229 059 F 229 060 F 229 061 F 229 062 F 229 063 F 229 064 F 229 065 F 229 066 F 229 067 F 229 068 F 229 069 F 229 070 F 229 071 F 229 072 F 229 073 F 229 074 F 229 075 F 229 076 F 229 077 F 229 078 F 229 079 F 229 080 F 229 081 F 229 082 F 229 083 F 229 084 F 229 085 F 229 086 F 229 087 F 229 088 F 229 089 F 229 090 F 229 091 F 229 092 F 229 093 F 229 094 F 229 095 F 229 096 F 229 097 F 229 098 F 229 099 F 229 100 F 229 101 F 229 102 F 229 103 F 229 104 F 229 105 F 229 106 F 229 107 F 229 108 F 229 109 F 229 110 F 229 111 F 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 « www.ruko.de » Twist drills DiN 338 TL 3000, HssE-Co 5 ground Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiAlN Cont. pcs. 11,20 11,30 11,40 11,50 11,60 11,70 11,80 11,90 12,00 12,10 12,20 12,30 12,40 12,50 12,60 12,70 12,80 12,90 13,00 13,50 14,00 14,50 15,00 15,50 16,00 142,0 142,0 142,0 142,0 142,0 142,0 142,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 160,0 160,0 169,0 169,0 178,0 178,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 108,0 108,0 114,0 114,0 120,0 120,0 229 112 229 113 229 114 229 115 229 116 229 117 229 118 229 119 229 120 229 121 229 122 229 123 229 124 229 125 229 126 229 127 229 128 229 129 229 130 229 135 229 140 229 145 229 150 229 155 229 160 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 229 112 F 229 113 F 229 114 F 229 115 F 229 116 F 229 117 F 229 118 F 229 119 F 229 120 F 229 121 F 229 122 F 229 123 F 229 124 F 229 125 F 229 126 F 229 127 F 229 128 F 229 129 F 229 130 F 229 135 F 229 140 F 229 145 F 229 150 F 229 155 F 229 160 F 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 Twist drill sets DiN 338 TL 3000, HssE-Co 5 ground 229 214 229 214 F Description 229 214 RO 229 214 FRO Article no. HSSE-Co 5 Article no. HSSE-Co 5 TiAlN 19-piece set of twist drills DIN 338 type TL 3000 Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 229 214 229 214 F 25-piece set of twist drills DIN 338 type TL 3000 Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 229 215 229 215 F 19-piece set of twist drills DIN 338 type TL 3000 Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 229 214 RO 229 214 FRO 25-piece set of twist drills DIN 338 type TL 3000 Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in plastic case 229 215 RO 229 215 FRO 35 1.01 Twist drills DiN 338 type VA, HssE-Co 5 ground Ø DIN 338 VA C HSSE Co 5 5xD ≥ Ø 2,0 mm h8 130° 36° 1.01 L2 Powerful right-hand cutting high-performance drill with distinctive heat resistance. Ideal for drilling high-strength stainless, acid-resistant and heat-resistant steel. L1 Packing unit: in plastic box steel (N/mm2) < 900 < 1100 < 1300 Main application 36 stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. 1,00 1,10 1,20 1,25 1,30 1,40 1,50 1,60 1,70 1,75 1,80 1,90 2,00 2,10 2,20 2,25 2,30 2,40 2,50 2,60 2,70 2,75 2,80 2,90 3,00 3,10 3,20 3,25 3,30 3,40 3,50 3,60 3,70 3,75 3,80 3,90 4,00 34,0 36,0 38,0 38,0 38,0 40,0 40,0 43,0 43,0 46,0 46,0 46,0 49,0 49,0 53,0 53,0 53,0 57,0 57,0 57,0 61,0 61,0 61,0 61,0 61,0 65,0 65,0 65,0 65,0 70,0 70,0 70,0 70,0 70,0 75,0 75,0 75,0 12,0 14,0 16,0 16,0 16,0 18,0 18,0 20,0 20,0 22,0 22,0 22,0 24,0 24,0 27,0 27,0 27,0 30,0 30,0 30,0 33,0 33,0 33,0 33,0 33,0 36,0 36,0 36,0 36,0 39,0 39,0 39,0 39,0 39,0 43,0 43,0 43,0 215 010 215 011 215 012 215 0125 215 013 215 014 215 015 215 016 215 017 215 0175 215 018 215 019 215 020 215 021 215 022 215 0225 215 023 215 024 215 025 215 026 215 027 215 0275 215 028 215 029 215 030 215 031 215 032 215 0325 215 033 215 034 215 035 215 036 215 037 215 0375 215 038 215 039 215 040 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 4,10 4,20 4,25 4,30 4,40 4,50 4,60 4,70 4,75 4,80 4,90 5,00 5,10 5,20 5,25 5,30 5,40 5,50 5,60 5,70 5,75 5,80 5,90 6,00 6,10 6,20 6,25 6,30 6,40 6,50 6,60 6,70 6,75 6,80 6,90 7,00 7,10 75,0 75,0 75,0 80,0 80,0 80,0 80,0 80,0 80,0 86,0 86,0 86,0 86,0 86,0 86,0 86,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 109,0 109,0 109,0 109,0 43,0 43,0 43,0 47,0 47,0 47,0 47,0 47,0 47,0 52,0 52,0 52,0 52,0 52,0 52,0 52,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 69,0 69,0 69,0 69,0 215 041 215 042 215 0425 215 043 215 044 215 045 215 046 215 047 215 0475 215 048 215 049 215 050 215 051 215 052 215 0525 215 053 215 054 215 055 215 056 215 057 215 0575 215 058 215 059 215 060 215 061 215 062 215 0625 215 063 215 064 215 065 215 066 215 067 215 0675 215 068 215 069 215 070 215 071 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. 7,20 7,25 7,30 7,40 7,50 7,60 7,70 7,75 7,80 7,90 8,00 8,10 8,20 8,25 8,30 8,40 8,50 8,60 8,70 8,75 8,80 8,90 9,00 9,10 9,20 9,25 9,30 9,40 9,50 9,60 9,70 9,75 9,80 9,90 10,00 10,10 10,20 10,30 10,40 10,50 109,0 109,0 109,0 109,0 109,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 69,0 69,0 69,0 69,0 69,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 215 072 215 0725 215 073 215 074 215 075 215 076 215 077 215 0775 215 078 215 079 215 080 215 081 215 082 215 0825 215 083 215 084 215 085 215 086 215 087 215 0875 215 088 215 089 215 090 215 091 215 092 215 0925 215 093 215 094 215 095 215 096 215 097 215 0975 215 098 215 099 215 100 215 101 215 102 215 103 215 104 215 105 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 10,60 10,70 10,80 10,90 11,00 11,10 11,20 11,30 11,40 11,50 11,60 11,70 11,80 11,90 12,00 12,10 12,20 12,30 12,40 12,50 12,60 12,70 12,80 12,90 13,00 13,50 14,00 14,50 15,00 15,50 16,00 16,50 17,00 17,50 18,00 18,50 19,00 19,50 20,00 — 133,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 160,0 160,0 169,0 169,0 178,0 178,0 184,0 184,0 191,0 191,0 198,0 198,0 205,0 205,0 — 87,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 108,0 108,0 114,0 114,0 120,0 120,0 125,0 125,0 130,0 130,0 135,0 135,0 140,0 140,0 — 215 106 215 107 215 108 215 109 215 110 215 111 215 112 215 113 215 114 215 115 215 116 215 117 215 118 215 119 215 120 215 121 215 122 215 123 215 124 215 125 215 126 215 127 215 128 215 129 215 130 215 135 215 140 215 145 215 150 215 155 215 160 215 165 215 170 215 175 215 180 215 185 215 190 215 195 215 210 — 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 1 1 1 1 1 1 1 1 — Twist drill sets DiN 338 type VA, HssE-Co 5 ground Description Article no. HSSE-Co 5 19-piece set of twist drills DIN 338 type VA Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 215 214 25-piece set of twist drills DIN 338 type VA Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 215 215 41-piece set of twist drills DIN 338 type VA Ø 6,0 mm up to 10,0 mm in increments of 0,1 mm in steel case 215 218 50-piece set of twist drills DIN 338 type VA Ø 1,0 mm up to 5,9 mm in increments of 0,1 mm in steel case 215 217 19-piece set of twist drills DIN 338 type VA Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 215 214 RO 25-piece set of twist drills DIN 338 type VA Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in plastic case 215 215 RO 215 214 37 1.01 Twist drills DiN 338 type VA, HssE-Co 5 ground Ø DIN 338 VA HSSE Co 5 C 5xD 130° ≥ Ø 2,0 mm h8 36° 1.01 L2 Powerful right-hand cutting high-performance drill with distinctive heat resistance and reinforced drill core. Ideal for drilling high-strength stainless, acid-resistant and heat-resistant steel. L1 Packing unit: in plastic box HSSE Co 5 HSSE Co 5 steel (N/mm2) < 900 < 1100 < 1300 Main application 38 stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSSE-Co 5 1,00 1,10 1,20 1,25 1,30 1,40 1,50 1,60 1,70 1,75 1,80 1,90 2,00 2,10 2,20 2,25 2,30 2,40 2,50 2,60 2,70 2,75 2,80 2,90 3,00 3,10 3,20 3,25 3,30 3,40 3,50 3,60 3,70 3,75 3,80 34,0 36,0 38,0 38,0 38,0 40,0 40,0 43,0 43,0 46,0 46,0 46,0 49,0 49,0 53,0 53,0 53,0 57,0 57,0 57,0 61,0 61,0 61,0 61,0 61,0 65,0 65,0 65,0 65,0 70,0 70,0 70,0 70,0 70,0 75,0 12,0 14,0 16,0 16,0 16,0 18,0 18,0 20,0 20,0 22,0 22,0 22,0 24,0 24,0 27,0 27,0 27,0 30,0 30,0 30,0 33,0 33,0 33,0 33,0 33,0 36,0 36,0 36,0 36,0 39,0 39,0 39,0 39,0 39,0 43,0 215 010 Z 215 011 Z 215 012 Z 215 0125 Z 215 013 Z 215 014 Z 215 015 Z 215 016 Z 215 017 Z 215 0175 Z 215 018 Z 215 019 Z 215 020 Z 215 021 Z 215 022 Z 215 0225 Z 215 023 Z 215 024 Z 215 025 Z 215 026 Z 215 027 Z 215 0275 Z 215 028 Z 215 029 Z 215 030 Z 215 031 Z 215 032 Z 215 0325 Z 215 033 Z 215 034 Z 215 035 Z 215 036 Z 215 037 Z 215 0375 Z 215 038 Z Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Article no. HSSE-Co 5 TiAlN 215 010 F 215 011 F 215 012 F 215 0125 F 215 013 F 215 014 F 215 015 F 215 016 F 215 017 F 215 0175 F 215 018 F 215 019 F 215 020 F 215 021 F 215 022 F 215 0225 F 215 023 F 215 024 F 215 025 F 215 026 F 215 027 F 215 0275 F 215 028 F 215 029 F 215 030 F 215 031 F 215 032 F 215 0325 F 215 033 F 215 034 F 215 035 F 215 036 F 215 037 F 215 0375 F 215 038 F Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » Ø mm L1 mm L2 mm Article no. HSSE-Co 5 3,90 4,00 4,10 4,20 4,25 4,30 4,40 4,50 4,60 4,70 4,75 4,80 4,90 5,00 5,10 5,20 5,25 5,30 5,40 5,50 5,60 5,70 5,75 5,80 5,90 6,00 6,10 6,20 6,25 6,30 6,40 6,50 6,60 6,70 6,75 6,80 6,90 7,00 7,10 7,20 7,25 7,30 7,40 7,50 7,60 7,70 7,75 7,80 7,90 8,00 8,10 8,20 8,25 8,30 8,40 8,50 8,60 8,70 8,75 8,80 8,90 9,00 9,10 9,20 9,25 9,30 9,40 75,0 75,0 75,0 75,0 75,0 80,0 80,0 80,0 80,0 80,0 80,0 86,0 86,0 86,0 86,0 86,0 86,0 86,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 43,0 43,0 43,0 43,0 43,0 47,0 47,0 47,0 47,0 47,0 47,0 52,0 52,0 52,0 52,0 52,0 52,0 52,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 215 039 Z 215 040 Z 215 041 Z 215 042 Z 215 0425 Z 215 043 Z 215 044 Z 215 045 Z 215 046 Z 215 047 Z 215 0475 Z 215 048 Z 215 049 Z 215 050 Z 215 051 Z 215 052 Z 215 0525 Z 215 053 Z 215 054 Z 215 055 Z 215 056 Z 215 057 Z 215 0575 Z 215 058 Z 215 059 Z 215 060 Z 215 061 Z 215 062 Z 215 0625 Z 215 063 Z 215 064 Z 215 065 Z 215 066 Z 215 067 Z 215 0675 Z 215 068 Z 215 069 Z 215 070 Z 215 071 Z 215 072 Z 215 0725 Z 215 073 Z 215 074 Z 215 075 Z 215 076 Z 215 077 Z 215 0775 Z 215 078 Z 215 079 Z 215 080 Z 215 081 Z 215 082 Z 215 0825 Z 215 083 Z 215 084 Z 215 085 Z 215 086 Z 215 087 Z 215 0875 Z 215 088 Z 215 089 Z 215 090 Z 215 091 Z 215 092 Z 215 0925 Z 215 093 Z 215 094 Z Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Article no. HSSE-Co 5 TiAlN 215 039 F 215 040 F 215 041 F 215 042 F 215 0425 F 215 043 F 215 044 F 215 045 F 215 046 F 215 047 F 215 0475 F 215 048 F 215 049 F 215 050 F 215 051 F 215 052 F 215 0525 F 215 053 F 215 054 F 215 055 F 215 056 F 215 057 F 215 0575 F 215 058 F 215 059 F 215 060 F 215 061 F 215 062 F 215 0625 F 215 063 F 215 064 F 215 065 F 215 066 F 215 067 F 215 0675 F 215 068 F 215 069 F 215 070 F 215 071 F 215 072 F 215 0725 F 215 073 F 215 074 F 215 075 F 215 076 F 215 077 F 215 0775 F 215 078 F 215 079 F 215 080 F 215 081 F 215 082 F 215 0825 F 215 083 F 215 084 F 215 085 F 215 086 F 215 087 F 215 0875 F 215 088 F 215 089 F 215 090 F 215 091 F 215 092 F 215 0925 F 215 093 F 215 094 F Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 39 1.01 Twist drills DiN 338 type VA, HssE-Co 5 ground 1.01 40 Ø mm L1 mm L2 mm 9,50 9,60 9,70 9,75 9,80 9,90 10,00 10,10 10,20 10,30 10,40 10,50 10,60 10,70 10,80 10,90 11,00 11,10 11,20 11,30 11,40 11,50 11,60 11,70 11,80 11,90 12,00 12,10 12,20 12,30 12,40 12,50 12,60 12,70 12,80 12,90 13,00 13,50 14,00 14,50 15,00 15,50 16,00 125,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 160,0 160,0 169,0 169,0 178,0 178,0 81,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 108,0 108,0 114,0 114,0 120,0 120,0 Article no. HSSE-Co 5 215 095 Z 215 096 Z 215 097 Z 215 0975 Z 215 098 Z 215 099 Z 215 100 Z 215 101 Z 215 102 Z 215 103 Z 215 104 Z 215 105 Z 215 106 Z 215 107 Z 215 108 Z 215 109 Z 215 110 Z 215 111 Z 215 112 Z 215 113 Z 215 114 Z 215 115 Z 215 116 Z 215 117 Z 215 118 Z 215 119 Z 215 120 Z 215 121 Z 215 122 Z 215 123 Z 215 124 Z 215 125 Z 215 126 Z 215 127 Z 215 128 Z 215 129 Z 215 130 Z 215 135 Z 215 140 Z 215 145 Z 215 150 Z 215 155 Z 215 160 Z Cont. pcs. 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 Article no. HSSE-Co 5 TiAlN 215 095 F 215 096 F 215 097 F 215 0975 F 215 098 F 215 099 F 215 100 F 215 101 F 215 102 F 215 103 F 215 104 F 215 105 F 215 106 F 215 107 F 215 108 F 215 109 F 215 110 F 215 111 F 215 112 F 215 113 F 215 114 F 215 115 F 215 116 F 215 117 F 215 118 F 215 119 F 215 120 F 215 121 F 215 122 F 215 123 F 215 124 F 215 125 F 215 126 F 215 127 F 215 128 F 215 129 F 215 130 F 215 135 F 215 140 F 215 145 F 215 150 F 215 155 F 215 160 F Cont. pcs. 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 « www.ruko.de » Twist drill sets DiN 338 type VA, HssE-Co 5 ground 1.01 215 214 Z 215 214 F 215 214 ZRO 215 214 FRO Description Article no. HSSE-Co 5 Article no. HSSE-Co 5 TiAlN 19-piece set of twist drills DIN 338 type VA Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 215 214 Z 215 214 F 25-piece set of twist drills DIN 338 type VA Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 215 215 Z 215 215 F 41-piece set of twist drills DIN 338 type VA Ø 6,0 mm up to 10,0 mm in increments of 0,1 mm in steel case 215 218 Z — 50-piece set of twist drills DIN 338 type VA Ø 1,0 mm up to 5,9 mm in increments of 0,1 mm in steel case 215 217 Z — 19-piece set of twist drills DIN 338 type VA Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 215 214 ZRO 215 214 FRO 25-piece set of twist drills DIN 338 type VA Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in plastic case 215 215 ZRO 215 215 FRO 41 Twist drills DiN 338 type UNi, HssE-Co 5 ground Ø DIN 338 UNI C HSSE Co 5 5xD ≥ Ø 2,0 mm h8 135° ≥ Ø 4,0 mm 40° 1.01 L2 High performance twist drill for all-purpose use in drilling machines and cordless drills. (Materials up to 5,0 mm thickness) L1 » The 3-surface-shank provides an excellent fixing within the drill chuck with little effort. In addition, the shank ensures an ideal power transmission. No spinning of the drill! » The 135º high performance cutting edge ensures a very high aligned preciseness, particularly when hand-operated with a cordless drilling machine. The edge prevents sliding off corrugated surfaces whilst spot-drilling. » Increased wear resistance of the rechargeable battery due to reduction of cutting forces. » The black bevel increases the wear resistance and prevents cold welding and build-up edges. » The 40º helix angle enables a perfect and fast chip removal and provides a high cutting speed along with increased stability and accuracy. Packing unit: in plastic box steel (N/mm2) < 900 < 1100 < 1300 Main application 42 stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. 1,00 1,10 1,20 1,30 1,40 1,50 1,60 1,70 1,80 1,90 2,00 2,10 2,20 2,30 2,40 2,50 2,60 2,70 2,80 2,90 3,00 3,10 3,20 3,30 3,40 3,50 3,60 3,70 3,80 34,0 36,0 38,0 38,0 40,0 40,0 43,0 43,0 46,0 46,0 49,0 49,0 53,0 53,0 57,0 57,0 57,0 61,0 61,0 61,0 61,0 65,0 65,0 65,0 70,0 70,0 70,0 70,0 75,0 12,0 14,0 16,0 16,0 18,0 18,0 20,0 20,0 22,0 22,0 24,0 24,0 27,0 27,0 30,0 30,0 30,0 33,0 33,0 33,0 33,0 36,0 36,0 36,0 39,0 39,0 39,0 39,0 43,0 228 010 228 011 228 012 228 013 228 014 228 015 228 016 228 017 228 018 228 019 228 020 228 021 228 022 228 023 228 024 228 025 228 026 228 027 228 028 228 029 228 030 228 031 228 032 228 033 228 034 228 035 228 036 228 037 228 038 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 3,90 4,00 4,10 4,20 4,30 4,40 4,50 4,60 4,70 4,80 4,90 5,00 5,10 5,20 5,30 5,40 5,50 5,60 5,70 5,80 5,90 6,00 6,10 6,20 6,30 6,40 6,50 6,60 6,70 75,0 75,0 75,0 75,0 80,0 80,0 80,0 80,0 80,0 86,0 86,0 86,0 86,0 86,0 86,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 43,0 43,0 43,0 43,0 47,0 47,0 47,0 47,0 47,0 52,0 52,0 52,0 52,0 52,0 52,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 228 039 228 040 228 041 228 042 228 043 228 044 228 045 228 046 228 047 228 048 228 049 228 050 228 051 228 052 228 053 228 054 228 055 228 056 228 057 228 058 228 059 228 060 228 061 228 062 228 063 228 064 228 065 228 066 228 067 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » Twist drills DiN 338 type UNi, HssE-Co 5 ground Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. 6,80 6,90 7,00 7,10 7,20 7,30 7,40 7,50 7,60 7,70 7,80 7,90 8,00 8,10 8,20 8,30 8,40 8,50 8,60 8,70 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 125,0 125,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 81,0 81,0 228 068 228 069 228 070 228 071 228 072 228 073 228 074 228 075 228 076 228 077 228 078 228 079 228 080 228 081 228 082 228 083 228 084 228 085 228 086 228 087 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 8,80 8,90 9,00 9,10 9,20 9,30 9,40 9,50 9,60 9,70 9,80 9,90 10,00 10,20 10,50 11,00 11,50 12,00 12,50 13,00 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 142,0 142,0 151,0 151,0 151,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 94,0 94,0 101,0 101,0 101,0 228 088 228 089 228 090 228 091 228 092 228 093 228 094 228 095 228 096 228 097 228 098 228 099 228 100 228 102 228 105 228 110 228 115 228 120 228 125 228 130 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 Twist drill sets DiN 338 type UNi, HssE-Co5 ground Description Article no. HSSE-Co 5 19-piece set of twist drills DIN 338 type UNI Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 228 214 25-piece set of twist drills DIN 338 type UNI Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 228 215 19-piece set of twist drills DIN 338 type UNI Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 228 214 RO 25-piece set of twist drills DIN 338 type UNI Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in plastic case 228 215 RO 228 214 RO 43 1.01 Twist drills DiN 338 TL 3000, Hss ground Ø DIN 338 TL 3000 HSS G C 5xD 130° ≥ Ø 2,0 mm h8 40° 1.01 L2 Stable multirange drill with reinforced drill core and parabolic flute for ideal chip removal. Ideal for drilling medium and long-chipping materials. Thanks to its thick core and the special flute with a rounded rear edge, this drill is best suited for high-performance use. It covers types N, H and W for a wide range of applications. L1 Packing unit: in plastic box HSS-G HSS-G steel (N/mm2) < 900 < 1100 < 1300 stainless steel Main application 44 HSS-G aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. Article no. HSS-G TiN Cont. pcs. Article no. HSS-G TiAlN Cont. pcs. 1,00 1,10 1,20 1,30 1,40 1,50 1,60 1,70 1,80 1,90 2,00 2,10 2,20 2,30 2,40 2,50 2,60 2,70 2,80 2,90 3,00 3,10 3,20 3,30 3,40 3,50 3,60 3,70 3,80 3,90 4,00 4,10 4,20 4,30 4,40 34,0 36,0 38,0 38,0 40,0 40,0 43,0 43,0 46,0 46,0 49,0 49,0 53,0 53,0 57,0 57,0 57,0 61,0 61,0 61,0 61,0 65,0 65,0 65,0 70,0 70,0 70,0 70,0 75,0 75,0 75,0 75,0 75,0 80,0 80,0 12,0 14,0 16,0 16,0 18,0 18,0 20,0 20,0 22,0 22,0 24,0 24,0 27,0 27,0 30,0 30,0 30,0 33,0 33,0 33,0 33,0 36,0 36,0 36,0 39,0 39,0 39,0 39,0 43,0 43,0 43,0 43,0 43,0 47,0 47,0 258 010 258 011 258 012 258 013 258 014 258 015 258 016 258 017 258 018 258 019 258 020 258 021 258 022 258 023 258 024 258 025 258 026 258 027 258 028 258 029 258 030 258 031 258 032 258 033 258 034 258 035 258 036 258 037 258 038 258 039 258 040 258 041 258 042 258 043 258 044 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 258 010 T 258 011 T 258 012 T 258 013 T 258 014 T 258 015 T 258 016 T 258 017 T 258 018 T 258 019 T 258 020 T 258 021 T 258 022 T 258 023 T 258 024 T 258 025 T 258 026 T 258 027 T 258 028 T 258 029 T 258 030 T 258 031 T 258 032 T 258 033 T 258 034 T 258 035 T 258 036 T 258 037 T 258 038 T 258 039 T 258 040 T 258 041 T 258 042 T 258 043 T 258 044 T 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 258 010 F 258 011 F 258 012 F 258 013 F 258 014 F 258 015 F 258 016 F 258 017 F 258 018 F 258 019 F 258 020 F 258 021 F 258 022 F 258 023 F 258 024 F 258 025 F 258 026 F 258 027 F 258 028 F 258 029 F 258 030 F 258 031 F 258 032 F 258 033 F 258 034 F 258 035 F 258 036 F 258 037 F 258 038 F 258 039 F 258 040 F 258 041 F 258 042 F 258 043 F 258 044 F 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » Ø mm L1 mm 4,50 4,60 4,70 4,80 4,90 5,00 5,10 5,20 5,30 5,40 5,50 5,60 5,70 5,80 5,90 6,00 6,10 6,20 6,30 6,40 6,50 6,60 6,70 6,80 6,90 7,00 7,10 7,20 7,30 7,40 7,50 7,60 7,70 7,80 7,90 8,00 8,10 8,20 8,30 8,40 8,50 8,60 8,70 8,80 8,90 9,00 9,10 9,20 9,30 9,40 9,50 9,60 9,70 9,80 9,90 10,00 10,10 10,20 10,30 10,40 10,50 10,60 10,70 10,80 10,90 11,00 11,10 80,0 80,0 80,0 86,0 86,0 86,0 86,0 86,0 86,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 142,0 142,0 142,0 142,0 142,0 L2 mm Article no. HSS-G Cont. pcs. Article no. HSS-G TiN Cont. pcs. Article no. HSS-G TiAlN Cont. pcs. 47,0 47,0 47,0 52,0 52,0 52,0 52,0 52,0 52,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 94,0 94,0 94,0 94,0 94,0 258 045 258 046 258 047 258 048 258 049 258 050 258 051 258 052 258 053 258 054 258 055 258 056 258 057 258 058 258 059 258 060 258 061 258 062 258 063 258 064 258 065 258 066 258 067 258 068 258 069 258 070 258 071 258 072 258 073 258 074 258 075 258 076 258 077 258 078 258 079 258 080 258 081 258 082 258 083 258 084 258 085 258 086 258 087 258 088 258 089 258 090 258 091 258 092 258 093 258 094 258 095 258 096 258 097 258 098 258 099 258 100 258 101 258 102 258 103 258 104 258 105 258 106 258 107 258 108 258 109 258 110 258 111 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 258 045 T 258 046 T 258 047 T 258 048 T 258 049 T 258 050 T 258 051 T 258 052 T 258 053 T 258 054 T 258 055 T 258 056 T 258 057 T 258 058 T 258 059 T 258 060 T 258 061 T 258 062 T 258 063 T 258 064 T 258 065 T 258 066 T 258 067 T 258 068 T 258 069 T 258 070 T 258 071 T 258 072 T 258 073 T 258 074 T 258 075 T 258 076 T 258 077 T 258 078 T 258 079 T 258 080 T 258 081 T 258 082 T 258 083 T 258 084 T 258 085 T 258 086 T 258 087 T 258 088 T 258 089 T 258 090 T 258 091 T 258 092 T 258 093 T 258 094 T 258 095 T 258 096 T 258 097 T 258 098 T 258 099 T 258 100 T 258 101 T 258 102 T 258 103 T 258 104 T 258 105 T 258 106 T 258 107 T 258 108 T 258 109 T 258 110 T 258 111 T 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 258 045 F 258 046 F 258 047 F 258 048 F 258 049 F 258 050 F 258 051 F 258 052 F 258 053 F 258 054 F 258 055 F 258 056 F 258 057 F 258 058 F 258 059 F 258 060 F 258 061 F 258 062 F 258 063 F 258 064 F 258 065 F 258 066 F 258 067 F 258 068 F 258 069 F 258 070 F 258 071 F 258 072 F 258 073 F 258 074 F 258 075 F 258 076 F 258 077 F 258 078 F 258 079 F 258 080 F 258 081 F 258 082 F 258 083 F 258 084 F 258 085 F 258 086 F 258 087 F 258 088 F 258 089 F 258 090 F 258 091 F 258 092 F 258 093 F 258 094 F 258 095 F 258 096 F 258 097 F 258 098 F 258 099 F 258 100 F 258 101 F 258 102 F 258 103 F 258 104 F 258 105 F 258 106 F 258 107 F 258 108 F 258 109 F 258 110 F 258 111 F 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 45 1.01 Twist drills DiN 338 TL 3000, Hss ground 1.01 Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. Article no. HSS-G TiN Cont. pcs. Article no. HSS-G TiAlN Cont. pcs. 11,20 11,30 11,40 11,50 11,60 11,70 11,80 11,90 12,00 12,10 12,20 12,30 12,40 12,50 12,60 12,70 12,80 12,90 13,00 13,50 14,00 14,50 15,00 15,50 16,00 142,0 142,0 142,0 142,0 142,0 142,0 142,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 160,0 160,0 169,0 169,0 178,0 178,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 108,0 108,0 114,0 114,0 120,0 120,0 258 112 258 113 258 114 258 115 258 116 258 117 258 118 258 119 258 120 258 121 258 122 258 123 258 124 258 125 258 126 258 127 258 128 258 129 258 130 258 135 258 140 258 145 258 150 258 155 258 160 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 258 112 T 258 113 T 258 114 T 258 115 T 258 116 T 258 117 T 258 118 T 258 119 T 258 120 T 258 121 T 258 122 T 258 123 T 258 124 T 258 125 T 258 126 T 258 127 T 258 128 T 258 129 T 258 130 T 258 135 T 258 140 T 258 145 T 258 150 T 258 155 T 258 160 T 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 258 112 F 258 113 F 258 114 F 258 115 F 258 116 F 258 117 F 258 118 F 258 119 F 258 120 F 258 121 F 258 122 F 258 123 F 258 124 F 258 125 F 258 126 F 258 127 F 258 128 F 258 129 F 258 130 F 258 135 F 258 140 F 258 145 F 258 150 F 258 155 F 258 160 F 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 Twist drill sets DiN 338 TL 3000, Hss ground 258 214 258 214 T 258 214 RO 258 214 FRO Description Article no. HSS-G Article no. HSS-G TiN Article no. HSS-G TiAlN 19-piece set of twist drills DIN 338 type TL 3000 Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 258 214 258 214 T 258 214 F 25-piece set of twist drills DIN 338 type TL 3000 Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 258 215 258 215 T 258 215 F 19-piece set of twist drills DIN 338 type TL 3000 Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 258 214 RO 258 214 TRO 258 214 FRO 25-piece set of twist drills DIN 338 type TL 3000 Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in plastic case 258 215 RO 258 215 TRO 258 215 FRO 46 « www.ruko.de » 1.01 47 Ø Twist drills DiN 338 type TURBO, Hss ground DIN TURBO HSS-G 338 N h8 3xD ≥ Ø 4,0 mm 36° 1.01 L1 L2 High-performance twist drill, particularly suited for handheld drilling of thin-walled materials. Ground twist drill in high-performance high-speed steel. Drills very cleanly with burr-free hole edges. Immediate drilling start after insertion as no prepunching is necessary. Shatter stability is increased by up to 50 % as the core diameter increases constantly in the direction of the shank (from Ø 3,2 mm). Triple milled clamping areas prevent the drill from spinning in the machine (from Ø 5,0 mm). For use on: non-alloy and alloy steel (up to grade of approx. 900 N/mm² ), for drilling thin-walled profiles and sheeting up to 5,0 mm, plastics and wood. Packing unit: in plastic box steel (N/mm2) < 900 < 1100 < 1300 stainless steel Main application 48 aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm 1,00 1,50 2,00 2,50 3,00 3,20 3,30 3,50 4,00 4,10 4,20 4,50 4,80 5,00 5,10 5,20 5,40 5,50 6,00 6,50 6,80 7,00 7,50 8,00 8,50 9,00 9,50 10,00 10,50 11,00 11,50 12,00 12,50 13,00 34,0 40,0 49,0 57,0 61,0 65,0 65,0 70,0 75,0 75,0 75,0 80,0 86,0 86,0 86,0 86,0 93,0 93,0 93,0 101,0 109,0 109,0 109,0 117,0 117,0 125,0 125,0 133,0 133,0 142,0 142,0 151,0 151,0 151,0 L2 mm Article no. HSS-G Cont. pcs. 12,0 18,0 24,0 30,0 33,0 36,0 36,0 39,0 43,0 43,0 43,0 46,0 46,0 46,0 46,0 46,0 52,0 52,0 57,0 58,0 66,0 66,0 66,0 72,0 72,0 78,0 78,0 84,0 84,0 91,0 91,0 98,0 98,0 98,0 2146 010 2146 015 2146 020 2146 025 2146 030 2146 032 2146 033 2146 035 2146 040 2146 041 2146 042 2146 045 2146 048 2146 050 2146 051 2146 052 2146 054 2146 055 2146 060 2146 065 2146 068 2146 070 2146 075 2146 080 2146 085 2146 090 2146 095 2146 100 2146 105 2146 110 2146 115 2146 120 2146 125 2146 130 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 « www.ruko.de » Twist drill sets DiN 338 type TURBO, Hss ground 1.01 214 614 214 615 214 614 RO 214 615 RO Description Article no. HSS-G 19-piece set of twist drills DIN 338 type TURBO Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 214 614 25-piece set of twist drills DIN 338 type TURBO Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 214 615 19-piece set of twist drills DIN 338 type TURBO Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 214 614 RO 19-piece set of twist drills DIN 338 type TURBO Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 214 615 RO 49 Ø Twist drills DiN 338 type w, Hss ground DIN 338 W C HSS-G 5xD ≥ Ø 2,0 mm 130° h8 35-40° 1.01 L2 For drilling soft and long-chipping materials such as aluminiumminium, zinc, copper, plastic and wood. L1 Packing unit: in plastic box steel (N/mm2) < 900 < 1100 < 1300 stainless steel Main application 50 aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. 1,00 1,50 2,00 2,50 3,00 3,20 3,30 3,50 4,00 4,20 4,50 4,80 5,00 5,50 6,00 6,40 6,50 6,80 7,00 7,50 8,00 8,50 8,70 9,00 9,50 10,00 10,20 10,50 11,00 11,50 12,00 12,50 13,00 34,0 40,0 49,0 57,0 61,0 65,0 65,0 70,0 75,0 75,0 80,0 86,0 86,0 93,0 93,0 101,0 101,0 109,0 109,0 109,0 117,0 117,0 125,0 125,0 125,0 133,0 133,0 133,0 142,0 142,0 151,0 151,0 151,0 12,0 18,0 24,0 30,0 33,0 36,0 36,0 39,0 43,0 43,0 47,0 52,0 52,0 57,0 57,0 63,0 63,0 69,0 69,0 69,0 75,0 75,0 81,0 81,0 81,0 87,0 87,0 87,0 94,0 94,0 101,0 101,0 101,0 280 010 280 015 280 020 280 025 280 030 280 032 280 033 280 035 280 040 280 042 280 045 280 048 280 050 280 055 280 060 280 064 280 065 280 068 280 070 280 075 280 080 280 085 280 087 280 090 280 095 280 100 280 102 280 105 280 110 280 115 280 120 280 125 280 130 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 « www.ruko.de » Twist drill sets DiN 338 type w, Hss ground 1.01 280 214 280 215 280 214 RO 280 215 RO Description Article no. HSS-G 19-piece set of twist drills DIN 338 type W Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 280 214 25-piece set of twist drills DIN 338 type W Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 280 215 19-piece set of twist drills DIN 338 type W Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 280 214 RO 25-piece set of twist drills DIN 338 type W Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in plastic case 280 215 RO 51 Twist drills DiN 338 type N, Hss ground Ø DIN 338 N C HSS-G 5xD ≥ Ø 2,0 mm h8 118° 25-30° 1.01 L2 High-performance ground standard twist drill made from heavy-duty high speed steel. The fully ground twist drill has a precise concentricity. Thanks to the split point, this drill has good centring properties and requires little pressure. L1 Packing unit: in plastic box steel (N/mm2) < 900 < 1100 < 1300 Main application 52 stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. 0,30 0,40 0,50 0,60 0,70 0,80 0,90 1,00 1,10 1,20 1,25 1,30 1,40 1,50 1,60 1,70 1,75 1,80 1,90 2,00 2,10 2,20 2,25 2,30 2,40 2,50 2,60 2,70 2,75 2,80 2,90 3,00 3,10 3,20 3,25 19,0 20,0 22,0 24,0 28,0 30,0 32,0 34,0 36,0 38,0 38,0 38,0 40,0 40,0 43,0 43,0 46,0 46,0 46,0 49,0 49,0 53,0 53,0 53,0 57,0 57,0 57,0 61,0 61,0 61,0 61,0 61,0 65,0 65,0 65,0 3,0 5,0 6,0 7,0 9,0 10,0 11,0 12,0 14,0 16,0 16,0 16,0 18,0 18,0 20,0 20,0 20,0 22,0 22,0 24,0 24,0 27,0 27,0 27,0 30,0 30,0 30,0 33,0 33,0 33,0 33,0 33,0 36,0 36,0 36,0 287 003 287 004 287 005 287 006 287 007 287 008 287 009 287 010 287 011 287 012 287 0125 287 013 287 014 287 015 287 016 287 017 287 0175 287 018 287 019 287 020 287 021 287 022 287 0225 287 023 287 024 287 025 287 026 287 027 287 0275 287 028 287 029 287 030 287 031 287 032 287 0325 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 3,30 3,40 3,50 3,60 3,70 3,75 3,80 3,90 4,00 4,10 4,20 4,25 4,30 4,40 4,50 4,60 4,70 4,75 4,80 4,90 5,00 5,10 5,20 5,25 5,30 5,40 5,50 5,60 6,25 6,30 6,40 6,50 6,60 6,70 6,75 65,0 70,0 70,0 70,0 70,0 70,0 75,0 75,0 75,0 75,0 75,0 75,0 80,0 80,0 80,0 80,0 80,0 80,0 86,0 86,0 86,0 86,0 86,0 86,0 86,0 93,0 93,0 93,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 36,0 39,0 39,0 39,0 39,0 39,0 43,0 43,0 43,0 43,0 43,0 43,0 47,0 47,0 47,0 47,0 47,0 47,0 52,0 52,0 52,0 52,0 52,0 52,0 52,0 57,0 57,0 57,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 287 033 287 034 287 035 287 036 287 037 287 0375 287 038 287 039 287 040 287 041 287 042 287 0425 287 043 287 044 287 045 287 046 287 047 287 0475 287 048 287 049 287 050 287 051 287 052 287 0525 287 053 287 054 287 055 287 056 287 0625 287 063 287 064 287 065 287 066 287 067 287 0675 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » Twist drills DiN 338 type N, Hss ground Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. 6,80 6,90 7,00 7,10 7,20 7,25 7,30 7,40 7,50 7,60 7,70 7,75 7,80 7,90 8,00 8,10 8,20 8,25 8,30 8,40 8,50 8,60 8,70 8,75 8,80 8,90 9,00 9,10 9,20 9,25 9,30 9,40 9,50 9,60 9,70 9,75 9,80 9,90 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 133,0 133,0 133,0 133,0 133,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 87,0 87,0 87,0 87,0 87,0 287 068 287 069 287 070 287 071 287 072 287 0725 287 073 287 074 287 075 287 076 287 077 287 0775 287 078 287 079 287 080 287 081 287 082 287 0825 287 083 287 084 287 085 287 086 287 087 287 0875 287 088 287 089 287 090 287 091 287 092 287 0925 287 093 287 094 287 095 287 096 287 097 287 0975 287 098 287 099 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10,00 10,10 10,20 10,30 10,40 10,50 10,60 10,70 10,80 10,90 11,00 11,10 11,20 11,30 11,40 11,50 11,60 11,70 11,80 11,90 12,00 12,10 12,20 12,30 12,40 12,50 12,60 12,70 12,80 12,90 13,00 13,50 14,00 14,50 15,00 15,50 16,00 — 133,0 133,0 133,0 133,0 133,0 133,0 133,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 160,0 160,0 169,0 169,0 178,0 178,0 — 87,0 87,0 87,0 87,0 87,0 87,0 87,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 108,0 108,0 114,0 114,0 120,0 120,0 — 287 100 287 101 287 102 287 103 287 104 287 105 287 106 287 107 287 108 287 109 287 110 287 111 287 112 287 113 287 114 287 115 287 116 287 117 287 118 287 119 287 120 287 121 287 122 287 123 287 124 287 125 287 126 287 127 287 128 287 129 287 130 287 135 287 140 287 145 287 150 287 155 287 160 — 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 — Twist drill sets DiN 338 type N, Hss ground Description Article no. HSS-G 19-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 287 214 25-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 287 215 19-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 287 214 RO 25-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in plastic case 287 215 RO 287 214 53 1.01 Twist drills DiN 338 type N, Hss ground Ø DIN 338 N C HSS-G 5xD h8 118° ≥ Ø 2,0 mm 25-30° 1.01 L2 High-performance ground standard twist drill made from heavy-duty high speed steel. The fully ground twist drill has a precise concentricity. Thanks to the split point, this drill has good centring properties and requires little pressure. L1 Packing unit: in plastic box HSS-G HSS-G steel (N/mm2) < 900 < 1100 < 1300 stainless steel Main application 54 Ø mm L1 mm L2 mm 0,30 0,40 0,50 0,60 0,70 0,80 0,90 1,00 1,10 1,20 1,25 1,30 1,40 1,50 1,60 1,70 1,75 1,80 1,90 2,00 2,10 2,20 2,25 2,30 2,40 2,50 2,60 2,70 2,75 2,80 2,90 3,00 3,10 3,20 3,25 19,0 20,0 22,0 24,0 28,0 30,0 32,0 34,0 36,0 38,0 38,0 38,0 40,0 40,0 43,0 43,0 46,0 46,0 46,0 49,0 49,0 53,0 53,0 53,0 57,0 57,0 57,0 61,0 61,0 61,0 61,0 61,0 65,0 65,0 65,0 3,0 5,0 6,0 7,0 9,0 10,0 11,0 12,0 14,0 16,0 16,0 16,0 18,0 18,0 20,0 20,0 20,0 22,0 22,0 24,0 24,0 27,0 27,0 27,0 30,0 30,0 30,0 33,0 33,0 33,0 33,0 33,0 36,0 36,0 36,0 aluminium HSS-G brass bronze plastics cast iron titanium alloyed Other application Article no. HSS-G 214 003 214 004 214 005 214 006 214 007 214 008 214 009 214 010 214 011 214 012 214 0125 214 013 214 014 214 015 214 016 214 017 214 0175 214 018 214 019 214 020 214 021 214 022 214 0225 214 023 214 024 214 025 214 026 214 027 214 0275 214 028 214 029 214 030 214 031 214 032 214 0325 Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Article no. HSS-G Black 214 003 S 214 004 S 214 005 S 214 006 S 214 007 S 214 008 S 214 009 S 214 010 S 214 011 S 214 012 S 214 0125 S 214 013 S 214 014 S 214 015 S 214 016 S 214 017 S 214 0175 S 214 018 S 214 019 S 214 020 S 214 021 S 214 022 S 214 0225 S 214 023 S 214 024 S 214 025 S 214 026 S 214 027 S 214 0275 S 214 028 S 214 029 S 214 030 S 214 031 S 214 032 S 214 0325 S Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Article no. HSS-G TiN 250 003 T 250 004 T 250 005 T 250 006 T 250 007 T 250 008 T 250 009 T 250 010 T 250 011 T 250 012 T 250 0125 T 250 013 T 250 014 T 250 015 T 250 016 T 250 017 T 250 0175 T 250 018 T 250 019 T 250 020 T 250 021 T 250 022 T 250 0225 T 250 023 T 250 024 T 250 025 T 250 026 T 250 027 T 250 0275 T 250 028 T 250 029 T 250 030 T 250 031 T 250 032 T 250 0325 T Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » Ø mm L1 mm L2 mm 3,30 3,40 3,50 3,60 3,70 3,75 3,80 3,90 4,00 4,10 4,20 4,25 4,30 4,40 4,50 4,60 4,70 4,75 4,80 4,90 5,00 5,10 5,20 5,25 5,30 5,40 5,50 5,60 5,70 5,75 5,80 5,90 6,00 6,10 6,20 6,25 6,30 6,40 6,50 6,60 6,70 6,75 6,80 6,90 7,00 7,10 7,20 7,25 7,30 7,40 7,50 7,60 7,70 7,75 7,80 7,90 8,00 8,10 8,20 8,25 8,30 8,40 8,50 8,60 8,70 8,75 8,80 65,0 70,0 70,0 70,0 70,0 70,0 75,0 75,0 75,0 75,0 75,0 75,0 80,0 80,0 80,0 80,0 80,0 80,0 86,0 86,0 86,0 86,0 86,0 86,0 86,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 125,0 125,0 125,0 125,0 36,0 39,0 39,0 39,0 39,0 39,0 43,0 43,0 43,0 43,0 43,0 43,0 47,0 47,0 47,0 47,0 47,0 47,0 52,0 52,0 52,0 52,0 52,0 52,0 52,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 81,0 81,0 81,0 81,0 Article no. HSS-G 214 033 214 034 214 035 214 036 214 037 214 0375 214 038 214 039 214 040 214 041 214 042 214 0425 214 043 214 044 214 045 214 046 214 047 214 0475 214 048 214 049 214 050 214 051 214 052 214 0525 214 053 214 054 214 055 214 056 214 057 214 0575 214 058 214 059 214 060 214 061 214 062 214 0625 214 063 214 064 214 065 214 066 214 067 214 0675 214 068 214 069 214 070 214 071 214 072 214 0725 214 073 214 074 214 075 214 076 214 077 214 0775 214 078 214 079 214 080 214 081 214 082 214 0825 214 083 214 084 214 085 214 086 214 087 214 0875 214 088 Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Article no. HSS-G 214 033 S 214 034 S 214 035 S 214 036 S 214 037 S 214 0375 S 214 038 S 214 039 S 214 040 S 214 041 S 214 042 S 214 0425 S 214 043 S 214 044 S 214 045 S 214 046 S 214 047 S 214 0475 S 214 048 S 214 049 S 214 050 S 214 051 S 214 052 S 214 0525 S 214 053 S 214 054 S 214 055 S 214 056 S 214 057 S 214 0575 S 214 058 S 214 059 S 214 060 S 214 061 S 214 062 S 214 0625 S 214 063 S 214 064 S 214 065 S 214 066 S 214 067 S 214 0675 S 214 068 S 214 069 S 214 070 S 214 071 S 214 072 S 214 0725 S 214 073 S 214 074 S 214 075 S 214 076 S 214 077 S 214 0775 S 214 078 S 214 079 S 214 080 S 214 081 S 214 082 S 214 0825 S 214 083 S 214 084 S 214 085 S 214 086 S 214 087 S 214 0875 S 214 088 S Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Article no. HSS-G TiN 250 033 T 250 034 T 250 035 T 250 036 T 250 037 T 250 0375 T 250 038 T 250 039 T 250 040 T 250 041 T 250 042 T 250 0425 T 250 043 T 250 044 T 250 045 T 250 046 T 250 047 T 250 0475 T 250 048 T 250 049 T 250 050 T 250 051 T 250 052 T 250 0525 T 250 053 T 250 054 T 250 055 T 250 056 T 250 057 T 250 0575 T 250 058 T 250 059 T 250 060 T 250 061 T 250 062 T 250 0625 T 250 063 T 250 064 T 250 065 T 250 066 T 250 067 T 250 0675 T 250 068 T 250 069 T 250 070 T 250 071 T 250 072 T 250 0725 T 250 073 T 250 074 T 250 075 T 250 076 T 250 077 T 250 0775 T 250 078 T 250 079 T 250 080 T 250 081 T 250 082 T 250 0825 T 250 083 T 250 084 T 250 085 T 250 086 T 250 087 T 250 0875 T 250 088 T Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 55 1.01 Twist drills DiN 338 type N, Hss ground Ø mm 1.01 8,90 9,00 9,10 9,20 9,25 9,30 9,40 9,50 9,60 9,70 9,75 9,80 9,90 10,00 10,10 10,20 10,30 10,40 10,50 10,60 10,70 10,80 10,90 11,00 11,10 11,20 11,30 11,40 11,50 11,60 11,70 11,80 11,90 12,00 12,10 12,20 12,30 12,40 12,50 12,60 12,70 12,80 12,90 13,00 13,50 14,00 14,50 15,00 15,50 16,00 16,50 17,00 17,50 18,00 18,50 19,00 19,50 20,00 56 L1 mm L2 mm 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 160,0 160,0 169,0 169,0 178,0 178,0 184,0 184,0 191,0 191,0 198,0 198,0 205,0 205,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 108,0 108,0 114,0 114,0 120,0 120,0 125,0 125,0 130,0 130,0 135,0 135,0 140,0 140,0 Article no. HSS-G 214 089 214 090 214 091 214 092 214 0925 214 093 214 094 214 095 214 096 214 097 214 0975 214 098 214 099 214 100 214 101 214 102 214 103 214 104 214 105 214 106 214 107 214 108 214 109 214 110 214 111 214 112 214 113 214 114 214 115 214 116 214 117 214 118 214 119 214 120 214 121 214 122 214 123 214 124 214 125 214 126 214 127 214 128 214 129 214 130 214 135 214 140 214 145 214 150 214 155 214 160 214 165 214 170 214 175 214 180 214 185 214 190 214 195 214 200 Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 1 1 1 1 1 1 1 1 Article no. HSS-G 214 089 S 214 090 S 214 091 S 214 092 S 214 0925 S 214 093 S 214 094 S 214 095 S 214 096 S 214 097 S 214 0975 S 214 098 S 214 099 S 214 100 S 214 101 S 214 102 S 214 103 S 214 104 S 214 105 S 214 106 S 214 107 S 214 108 S 214 109 S 214 110 S 214 111 S 214 112 S 214 113 S 214 114 S 214 115 S 214 116 S 214 117 S 214 118 S 214 119 S 214 120 S 214 121 S 214 122 S 214 123 S 214 124 S 214 125 S 214 126 S 214 127 S 214 128 S 214 129 S 214 130 S 214 135 S 214 140 S 214 145 S 214 150 S 214 155 S 214 160 S — — — — — — — — Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 — — — — — — — — Article no. HSS-G TiN 250 089 T 250 090 T 250 091 T 250 092 T 250 0925 T 250 093 T 250 094 T 250 095 T 250 096 T 250 097 T 250 0975 T 250 098 T 250 099 T 250 100 T 250 101 T 250 102 T 250 103 T 250 104 T 250 105 T 250 106 T 250 107 T 250 108 T 250 109 T 250 110 T 250 111 T 250 112 T 250 113 T 250 114 T 250 115 T 250 116 T 250 117 T 250 118 T 250 119 T 250 120 T 250 121 T 250 122 T 250 123 T 250 124 T 250 125 T 250 126 T 250 127 T 250 128 T 250 129 T 250 130 T 250 135 T 250 140 T 250 145 T 250 150 T 250 155 T 250 160 T — — — — — — — — Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 — — — — — — — — « www.ruko.de » Twist drill sets DiN 338 type N, Hss ground 1.01 214 214 214 214 S 214 214 RO 250 214 TRO Description Article no. HSS-G Article no. HSS-G Article no. HSS-G TiN 19-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 214 214 214 214 S 250 214 T 25-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 214 215 214 215 S 250 215 T 41-piece set of twist drills DIN 338 type N Ø 6,0 mm up to 10,0 mm in increments of 0,1 mm in steel case 214 218 — — 50-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 5,9 mm in increments of 0,1 mm in steel case 214 217 — — 19-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 214 214 RO 214 214 SRO 250 214 TRO 25-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in plastic case 214 215 RO 214 215 SRO 250 215 TRO 57 Twist drills DiN 338 type N, Hss ground - left hand cutting Ø DIN 338 1.01 N HSS-G N 118° 5xD h8 25-30° L2 High-performance ground twist drill made from heavy-duty high speed steel. The fully ground twist drill has a precise concentricity. L1 Packing unit: in plastic box HSS-G HSS-G steel (N/mm2) < 900 < 1100 < 1300 Main application 58 stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. Article no. HSS-G TiN Cont. pcs. 1,00 1,50 2,00 2,50 3,00 3,20 3,30 3,50 4,00 4,20 4,50 4,80 5,00 5,50 6,00 6,40 6,50 6,80 7,00 7,50 8,00 8,50 8,70 9,00 9,50 10,00 10,20 10,50 11,00 11,50 12,00 12,50 13,00 34,0 40,0 49,0 57,0 61,0 65,0 65,0 70,0 75,0 75,0 80,0 86,0 86,0 93,0 93,0 101,0 101,0 109,0 109,0 109,0 117,0 117,0 125,0 125,0 125,0 133,0 133,0 133,0 142,0 142,0 151,0 151,0 151,0 12,0 18,0 24,0 30,0 33,0 36,0 36,0 39,0 43,0 43,0 47,0 52,0 52,0 57,0 57,0 63,0 63,0 69,0 69,0 69,0 75,0 75,0 81,0 81,0 81,0 87,0 87,0 87,0 94,0 94,0 101,0 101,0 101,0 214 010 Li 214 015 Li 214 020 Li 214 025 Li 214 030 Li 214 032 Li 214 033 Li 214 035 Li 214 040 Li 214 042 Li 214 045 Li 214 048 Li 214 050 Li 214 055 Li 214 060 Li 214 064 Li 214 065 Li 214 068 Li 214 070 Li 214 075 Li 214 080 Li 214 085 Li 214 087 Li 214 090 Li 214 095 Li 214 100 Li 214 102 Li 214 105 Li 214 110 Li 214 115 Li 214 120 Li 214 125 Li 214 130 Li 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 214 010 Li T 214 015 Li T 214 020 Li T 214 025 Li T 214 030 Li T 214 032 Li T 214 033 Li T 214 035 Li T 214 040 Li T 214 042 Li T 214 045 Li T 214 048 Li T 214 050 Li T 214 055 Li T 214 060 Li T 214 064 Li T 214 065 Li T 214 068 Li T 214 070 Li T 214 075 Li T 214 080 Li T 214 085 Li T 214 087 Li T 214 090 Li T 214 095 Li T 214 100 Li T 214 102 Li T 214 105 Li T 214 110 Li T 214 115 Li T 214 120 Li T 214 125 Li T 214 130 Li T 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 « www.ruko.de » Twist drill sets DiN 338 type N, Hss ground - left hand cutting 1.01 214 214 Li 214 214 Li T Description 214 214 Li RO 214 214 Li TRO Article no. HSS-G Article no. HSS-G TiN 19-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 214 214 Li 214 214 Li T 25-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 214 215 Li 214 215 Li T 19-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 214 214 Li RO 214 214 Li TRO 25-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in plastic case 214 215 Li RO 214 215 Li TRO 59 Twist drills DiN 338 type N, with reduced shank Ø1 DIN 338 1.01 N N h8 5xD 20-30° Ideally suitable for drilling larger drilling diameters on all commonly-used drilling machines with a clamping chuck up to 13,0 mm. Packing unit: in plastic box N HSS-R L1 118° steel (N/mm2) < 900 < 1100 aluminium brass bronze plastics cast iron titanium alloyed stainless steel aluminium brass bronze plastics cast iron titanium alloyed stainless steel aluminium brass bronze plastics cast iron titanium alloyed 118° steel (N/mm2) < 900 stainless steel C HSS-G L2 < 1300 < 1100 < 1300 Ø2 C HSSE Co 5 130° steel (N/mm2) < 900 < 1100 < 1300 Main application 60 Ø1 mm L1 mm 10,50 11,00 11,50 12,00 12,50 13,00 13,50 14,00 14,50 15,00 15,50 16,00 16,50 17,00 17,50 18,00 18,50 19,00 19,50 20,00 22,00 24,00 25,00 133,0 142,0 142,0 151,0 151,0 151,0 160,0 160,0 169,0 169,0 178,0 178,0 184,0 184,0 191,0 191,0 198,0 198,0 205,0 205,0 205,0 205,0 205,0 Other application Ø2 mm L2 mm Article no. HSS-R Article no. HSS-G Article no. HSSE-Co 5 Cont. pcs. 10,0 10,0 10,0 10,0 10,0 10,0 10,0 10,0 10,0 10,0 10,0 10,0 13,0 13,0 13,0 13,0 13,0 13,0 13,0 13,0 13,0 13,0 13,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 35,0 35,0 35,0 35,0 35,0 35,0 35,0 35,0 35,0 35,0 35,0 200 105 200 110 200 115 200 120 200 125 200 130 200 135 200 140 200 145 200 150 200 155 200 160 200 165 200 170 200 175 200 180 200 185 200 190 200 195 200 200 200 220 200 240 200 250 200 4 105 200 4 110 200 4 115 200 4 120 200 4 125 200 4 130 200 4 135 200 4 140 200 4 145 200 4 150 200 4 155 200 4 160 200 4 165 200 4 170 200 4 175 200 4 180 200 4 185 200 4 190 200 4 195 200 4 200 — — — 200 5 105 200 5 110 200 5 115 200 5 120 200 5 125 200 5 130 200 5 135 200 5 140 200 5 145 200 5 150 200 5 155 200 5 160 200 5 165 200 5 170 200 5 175 200 5 180 200 5 185 200 5 190 200 5 195 200 5 200 — — — 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 « www.ruko.de » Twist drills DiN 338 type N, Hss rolled Ø DIN 338 N N HSS-R h8 118° 5xD 25-30° 1.01 L2 High-performance rolled, steam-treated twist drill made from heavy-duty high speed steel. The manufacturing procedure (no structural disruption) solidifies the material making it more elasticated. This makes it more resistant to fracture and suitable for robust drilling units (e.g. hand-held drilling machines). L1 Packing unit: in plastic box steel (N/mm2) < 900 < 1100 < 1300 Main application Ø mm L1 mm L2 mm 0,30 0,40 0,50 0,60 0,70 0,80 0,90 1,00 1,10 1,20 1,25 1,30 1,40 1,50 1,60 1,70 1,75 1,80 1,90 2,00 2,10 2,20 2,25 2,30 2,40 2,50 2,60 2,70 2,75 2,80 2,90 3,00 3,10 3,20 3,25 19,0 20,0 22,0 24,0 28,0 30,0 32,0 34,0 36,0 38,0 38,0 38,0 40,0 40,0 43,0 43,0 46,0 46,0 46,0 49,0 49,0 53,0 53,0 53,0 57,0 57,0 57,0 61,0 61,0 61,0 61,0 61,0 65,0 65,0 65,0 3,0 5,0 6,0 7,0 9,0 10,0 11,0 12,0 14,0 16,0 16,0 16,0 18,0 18,0 20,0 20,0 20,0 22,0 22,0 24,0 24,0 27,0 27,0 27,0 30,0 30,0 30,0 33,0 33,0 33,0 33,0 33,0 36,0 36,0 36,0 Article no. HSS-R 201 003 201 004 201 005 201 006 201 007 201 008 201 009 201 010 201 011 201 012 201 0125 201 013 201 014 201 015 201 016 201 017 201 0175 201 018 201 019 201 020 201 021 201 022 201 0225 201 023 201 024 201 025 201 026 201 027 201 0275 201 028 201 029 201 030 201 031 201 032 201 0325 stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Cont. pcs. Ø mm L1 mm L2 mm 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 3,30 3,40 3,50 3,60 3,70 3,75 3,80 3,90 4,00 4,10 4,20 4,25 4,30 4,40 4,50 4,60 4,70 4,75 4,80 4,90 5,00 5,10 5,20 5,25 5,30 5,40 5,50 5,60 5,70 5,75 5,80 5,90 6,00 6,10 6,20 65,0 70,0 70,0 70,0 70,0 70,0 75,0 75,0 75,0 75,0 75,0 75,0 80,0 80,0 80,0 80,0 80,0 80,0 86,0 86,0 86,0 86,0 86,0 86,0 86,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 101,0 101,0 36,0 39,0 39,0 39,0 39,0 39,0 43,0 43,0 43,0 43,0 43,0 43,0 47,0 47,0 47,0 47,0 47,0 47,0 52,0 52,0 52,0 52,0 52,0 52,0 52,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 63,0 63,0 Article no. HSS-R 201 033 201 034 201 035 201 036 201 037 201 0375 201 038 201 039 201 040 201 041 201 042 201 0425 201 043 201 044 201 045 201 046 201 047 201 0475 201 048 201 049 201 050 201 051 201 052 201 0525 201 053 201 054 201 055 201 056 201 057 201 0575 201 058 201 059 201 060 201 061 201 062 Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 61 Twist drills DiN 338 type N, Hss rolled 1.01 62 Ø mm L1 mm L2 mm Article no. HSS-R 6,25 6,30 6,40 6,50 6,60 6,70 6,75 6,80 6,90 7,00 7,10 7,20 7,25 7,30 7,40 7,50 7,60 7,70 7,75 7,80 7,90 8,00 8,10 8,20 8,25 8,30 8,40 8,50 8,60 8,70 8,75 8,80 8,90 9,00 9,10 9,20 9,25 9,30 9,40 9,50 9,60 9,70 9,75 9,80 9,90 101,0 101,0 101,0 101,0 101,0 101,0 101,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 133,0 133,0 133,0 133,0 133,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 87,0 87,0 87,0 87,0 87,0 201 0625 201 063 201 064 201 065 201 066 201 067 201 0675 201 068 201 069 201 070 201 071 201 072 201 0725 201 073 201 074 201 075 201 076 201 077 201 0775 201 078 201 079 201 080 201 081 201 082 201 0825 201 083 201 084 201 085 201 086 201 087 201 0875 201 088 201 089 201 090 201 091 201 092 201 0925 201 093 201 094 201 095 201 096 201 097 201 0975 201 098 201 099 Cont. pcs. Ø mm L1 mm L2 mm Article no. HSS-R Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10,00 10,10 10,20 10,30 10,40 10,50 10,60 10,70 10,80 10,90 11,00 11,10 11,20 11,30 11,40 11,50 11,60 11,70 11,80 11,90 12,00 12,10 12,20 12,30 12,40 12,50 12,60 12,70 12,80 12,90 13,00 13,50 14,00 14,50 15,00 15,50 16,00 16,50 17,00 17,50 18,00 18,50 19,00 19,50 20,00 133,0 133,0 133,0 133,0 133,0 133,0 133,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 160,0 160,0 169,0 169,0 178,0 178,0 184,0 184,0 191,0 191,0 198,0 198,0 205,0 205,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 108,0 108,0 114,0 114,0 120,0 120,0 125,0 125,0 130,0 130,0 135,0 135,0 140,0 140,0 201 100 201 101 201 102 201 103 201 104 201 105 201 106 201 107 201 108 201 109 201 110 201 111 201 112 201 113 201 114 201 115 201 116 201 117 201 118 201 119 201 120 201 121 201 122 201 123 201 124 201 125 201 126 201 127 201 128 201 129 201 130 201 135 201 140 201 145 201 150 201 155 201 160 201 165 201 170 201 175 201 180 201 185 201 190 201 195 201 200 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 1 1 1 1 1 1 1 1 « www.ruko.de » Twist drill sets DiN 338 type N, Hss rolled Description Article no. HSS-R 19-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 205 212 25-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 205 213 41-piece set of twist drills DIN 338 type N Ø 6,0 mm up to 10,0 mm in increments of 0,1 mm in steel case 205 218 50-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 5,9 mm in increments of 0,1 mm in steel case 205 217 19-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 205 212 RO 25-piece set of twist drills DIN 338 type N Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm in plastic case 205 213 RO 1.01 205 212 RO 63 Ø Twist drill DiN 338 Type N, with brazed-on TC cutting inserts DIN 338 L1 L2 1.01 N HSS-G C TC 5xD h8 18-30° High-performance HSS-G twist drill with brazed-on HM cutting inserts made from K20 fine grained material. It is suited for universal applications and for high-strength steel. Continuous cooling is required when drilling into high-strength steel. With stepped shank starting at 13,5 mm drill diameter (10,0 mm shank Ø, 30,0 mm shank length). Packing unit: in plastic box TC HSS-G TC HSS-G steel (N/mm2) < 900 < 1100 < 1300 Main application 64 118° ≥ Ø 3,0 mm stainless steel aluminium brass Other application bronze plastics cast iron titanium alloyed « www.ruko.de » Ø mm L1 mm L2 mm Article no. HSS-G / TC Cont. pcs. Article no. HSS-G / TC Tecrona Cont. pcs. 2,00 2,50 3,00 3,10 3,20 3,30 3,50 3,60 4,00 4,20 4,30 4,50 5,00 5,10 5,20 5,30 5,50 5,80 6,00 6,50 6,70 6,80 7,00 7,10 7,50 8,00 8,50 9,00 9,50 10,00 10,20 10,50 11,00 11,50 12,00 12,50 13,00 13,50 14,00 15,00 16,00 49,0 57,0 61,0 65,0 65,0 65,0 70,0 70,0 75,0 75,0 80,0 80,0 86,0 86,0 86,0 86,0 93,0 93,0 93,0 101,0 101,0 109,0 109,0 109,0 109,0 117,0 117,0 125,0 125,0 133,0 133,0 133,0 142,0 142,0 151,0 151,0 151,0 160,0 160,0 169,0 178,0 24,0 30,0 33,0 36,0 36,0 36,0 39,0 39,0 43,0 43,0 47,0 47,0 52,0 52,0 52,0 52,0 57,0 57,0 57,0 63,0 63,0 69,0 69,0 69,0 69,0 75,0 75,0 81,0 81,0 87,0 87,0 87,0 94,0 94,0 101,0 101,0 101,0 108,0 108,0 114,0 120,0 815 020 815 025 815 030 815 031 815 032 815 033 815 035 815 036 815 040 815 042 815 043 815 045 815 050 815 051 815 052 815 053 815 055 815 058 815 060 815 065 815 067 815 068 815 070 815 071 815 075 815 080 815 085 815 090 815 095 815 100 815 102 815 105 815 110 815 115 815 120 815 125 815 130 815 135 815 140 815 150 815 160 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 815 020 C 815 025 C 815 030 C 815 031 C 815 032 C 815 033 C 815 035 C 815 036 C 815 040 C 815 042 C 815 043 C 815 045 C 815 050 C 815 051 C 815 052 C 815 053 C 815 055 C 815 058 C 815 060 C 815 065 C 815 067 C 815 068 C 815 070 C 815 071 C 815 075 C 815 080 C 815 085 C 815 090 C 815 095 C 815 100 C 815 102 C 815 105 C 815 110 C 815 115 C 815 120 C 815 125 C 815 130 C 815 135 C 815 140 C 815 150 C 815 160 C 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 Twist drill sets DiN 338 Type N, with brazed-on TC cutting inserts Description Article no. HSS-G / TC Article no. HSS-G / TC Tecrona 17-piece set of twist drills DIN 338 type N Ø 2,0 mm up to 10,0 mm in increments of 0,5 mm in steel case 815 214 815 214 C 23-piece set of twist drills DIN 338 type N Ø 2,0 mm up to 13,0 mm in increments of 0,5 mm in steel case 815 215 815 215 C 17-piece set of twist drills DIN 338 type N Ø 2,0 mm up to 10,0 mm in increments of 0,5 mm in plastic case 815 214 RO 815 214 CRO 23-piece set of twist drills DIN 338 type N Ø 2,0 mm up to 13,0 mm in increments of 0,5 mm in plastic case 815 215 RO 815 215 CRO 815 214 RO 65 1.01 Ø solid TC twist drills DiN 338 type N DIN 338 N C TC 118° 5xD h8 20-30° 1.01 Packing unit: in plastic box L1 L2 High performance solid carbide K 20 twist drill, especially well suited for high strength steels at high cutting speeds. steel (N/mm2) < 900 < 1100 < 1300 stainless steel Main application 66 aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. Cont. pcs. 3,00 3,50 4,00 4,50 5,00 5,50 6,00 6,50 7,00 7,50 8,00 8,50 9,00 9,50 10,00 10,50 11,00 11,50 12,00 12,50 13,00 61,0 70,0 75,0 80,0 86,0 93,0 93,0 101,0 109,0 109,0 117,0 117,0 125,0 125,0 133,0 133,0 142,0 142,0 151,0 151,0 151,0 33,0 39,0 43,0 47,0 52,0 57,0 57,0 63,0 69,0 69,0 75,0 75,0 81,0 81,0 87,0 87,0 94,0 94,0 101,0 101,0 101,0 814 030 814 035 814 040 814 045 814 050 814 055 814 060 814 065 814 070 814 075 814 080 814 085 814 090 814 095 814 100 814 105 814 110 814 115 814 120 814 125 814 130 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 « www.ruko.de » Twist drill sets, DiN 338 type N and type VA in bench stand Description Article no. 91-piece set of twist drills DIN 338 type N HSS rolled Ø 1,0 mm up to 10,0 mm in increments of 0,1 mm 205 223 91-piece set of twist drills DIN 338 type N HSS ground Ø 1,0 mm up to 10,0 mm in increments of 0,1 mm 214 223 91-piece set of twist drills DIN 338 type VA HSSE-Co 5 ground Ø 1,0 mm up to 10,0 mm in increments of 0,1 mm 215 223 1.01 214 223 Twist drill sets, DiN 338 type N and type VA in magazine Description Article no. Consisting of 170 twist drills DIN 338 type N HSS ground 10 pcs, Ø 1,0 - 8,0 mm in increments of 0,5 mm 5 pcs, Ø 8,5 - 10,0 mm in increments of 0,5 mm 214 200 Consisting of 170 twist drills DIN 338 type VA HSS-Co 5 ground 10 pcs, Ø 1,0 - 8,0 mm in increments of 0,5 mm 5 pcs, Ø 8,5 - 10,0 mm in increments of 0,5 mm 215 200 214 200 Drill cabinet, DiN 338 type N and type VA Description Article no. Drill cabinet empty Ø 1,0 mm up to 10,0 mm in increments of 0,1 mm + Ø 10,5 mm up to 13,0 mm in increments of 0,5 mm 205 2081 L Drill cabinet empty Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm 205 208 L Drill cabinet consisting of 570 twist drills DIN 338 type N HSS rolled contents list see below 205 208 Drill cabinet consisting of 570 twist drills DIN 338 type N HSS ground contents list see below 214 208 Drill cabinet consisting of 570 twist drills DIN 338 type VA HSSE-Co 5 ground contents list see below 215 208 205 208 L Contents list: Ø mm x pcs. Ø mm x pcs. Ø mm x pcs. 1,0 x 50 1,5 x 50 2,0 x 50 2,5 x 50 3,0 x 30 3,5 x 30 4,0 x 30 4,5 x 30 5,0 x 30 5,5 x 30 6,0 x 20 6,5 x 20 7,0 x 20 7,5 x 20 8,0 x 10 Ø mm x pcs. 8,5 x 10 9,0 x 10 9,5 x 10 10,0 x 10 10,5 x 10 Ø mm x pcs. 11,0 x 10 11,5 x 10 12,0 x 10 12,5 x 10 13,0 x 10 205 2081 L 67 Ø Twist drills DiN 338 TL 3000, in fractional sizes DIN 338 TL - HSSE 3000 HSS G Co 5 C 5xD ≥ Ø 2,0 mm 130° h8 40° L1 L2 1.01 Highly stable multirange drill with outstanding heat resistance, a reinforced drill core and a parabolic flute for ideal chip removal. Ideal for drilling medium and long-chipping materials. Thanks to its thick core and the special flute with a rounded rear edge, this drill is best suited for high-performance use. It covers types N, H and W for a wide range of applications. Packing unit: in plastic box HSS-G HSS-G steel (N/mm2) < 900 < 1100 HSS-G stainless steel aluminium brass bronze plastics < 1300 cast iron titanium alloyed stainless steel aluminium brass bronze plastics < 1300 cast iron titanium alloyed HSSE Co 5 steel (N/mm2) < 900 < 1100 Main application 68 Other application « www.ruko.de » Twist drills DiN 338 TL 3000, in fractional sizes Ø inch Ø mm L1 inch L2 inch Article no. HSS-G Cont. pcs. Article no. HSS-G TiN Cont. pcs. Article no. HSS-G TiAlN Cont. pcs. Article no. HSSE-Co 5 Cont. pcs. 1/16 1,59 1,98 2,38 2,78 3,18 3,57 3,97 4,37 4,76 5,16 5,56 5,95 6,35 6,75 7,14 7,54 7,94 8,33 8,73 9,13 9,53 9,92 10,32 10,72 11,11 11,51 11,91 12,30 12,70 1 7/8 2 2 1/4 2 5/8 2 3/4 2 7/8 3 1/8 3 1/4 3 1/2 3 5/8 3 3/4 3 7/8 4 4 1/8 4 1/4 4 3/8 4 1/2 4 5/8 4 3/4 4 7/8 5 5 1/8 5 1/4 5 3/8 5 1/2 5 5/8 5 3/4 5 7/8 6 7/8 258 801 258 802 258 803 258 804 258 805 258 806 258 807 258 808 258 809 258 810 258 811 258 812 258 813 258 814 258 815 258 816 258 817 258 818 258 819 258 820 258 821 258 822 258 823 258 824 258 825 258 826 258 827 258 828 258 829 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 258 801 T 258 802 T 258 803 T 258 804 T 258 805 T 258 806 T 258 807 T 258 808 T 258 809 T 258 810 T 258 811 T 258 812 T 258 813 T 258 814 T 258 815 T 258 816 T 258 817 T 258 818 T 258 819 T 258 820 T 258 821 T 258 822 T 258 823 T 258 824 T 258 825 T 258 826 T 258 827 T 258 828 T 258 829 T 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 258 801 F 258 802 F 258 803 F 258 804 F 258 805 F 258 806 F 258 807 F 258 808 F 258 809 F 258 810 F 258 811 F 258 812 F 258 813 F 258 814 F 258 815 F 258 816 F 258 817 F 258 818 F 258 819 F 258 820 F 258 821 F 258 822 F 258 823 F 258 824 F 258 825 F 258 826 F 258 827 F 258 828 F 258 829 F 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 229 801 229 802 229 803 229 804 229 805 229 806 229 807 229 808 229 809 229 810 229 811 229 812 229 813 229 814 229 815 229 816 229 817 229 818 229 819 229 820 229 821 229 822 229 823 229 824 229 825 229 826 229 827 229 828 229 829 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5/64 3/32 7/64 1/8 9/64 5/32 11/64 3/16 13/64 7/32 15/64 1/4 17/64 9/32 19/64 5/16 21/64 11/32 23/64 3/8 25/64 13/32 27/64 7/16 29/64 15/32 31/64 1/2 1 1 1/4 1 1/2 1 5/8 1 3/4 2 2 1/8 2 5/16 2 7/16 2 1/2 2 5/8 2 3/4 2 7/8 2 15/16 3 1/16 3 3/16 3 5/16 3 7/16 3 1/2 3 5/8 3 3/4 3 7/8 3 15/16 4 1/16 4 3/16 4 5/16 4 3/8 4 1/2 Twist drill sets DiN 338 TL 3000, in fractional sizes 258 850 258 850 T 258 850 F 229 850 Description Article no. HSS-G Article no. HSS-G TiN Article no. HSS-G TiAlN Article no. HSSE-Co 5 21-piece set of twist drills DIN 338 TL 3000, in fractional sizes Ø 1/16" up to 3/8" in increments of 1/64" in steel case 258 850 258 850 T 258 850 F 229 850 29-piece set of twist drills DIN 338 TL 3000, in fractional sizes Ø 1/16" up to 1/2" in increments of 1/64" in steel case 258 851 258 851 T 258 851 F 229 851 69 1.01 Ø Twist drills DiN 338 type N, in fractional sizes DIN 338 N HSS-G C 5xD 118° ≥ Ø 2,0 mm h8 25-30° L2 1.01 High-performance ground standard twist drill made from heavy-duty high speed steel. The fully ground twist drill has a precise concentricity. Thanks to the split point, this drill has good centring properties and requires little pressure. L1 Packing unit: in plastic box HSS-G HSS-G steel (N/mm2) < 900 < 1100 < 1300 Main application aluminium brass bronze plastics cast iron titanium alloyed Other application Ø inch Ø mm L1 in inch L2 in inch Article no. HSS-G Cont. pcs. Article no. HSS-G TiN Cont. pcs. 1/16 1,59 1,98 2,38 2,78 3,18 3,57 3,97 4,37 4,76 5,16 5,56 5,95 6,35 6,75 7,14 7,54 7,94 8,33 8,73 9,13 9,53 9,92 10,32 10,72 11,11 11,51 11,91 12,30 12,70 1 7/8 2 2 1/4 2 5/8 2 3/4 2 7/8 3 1/8 3 1/4 3 1/2 3 5/8 3 3/4 3 7/8 4 4 1/8 4 1/4 4 3/8 4 1/2 4 5/8 4 3/4 4 7/8 5 5 1/8 5 1/4 5 3/8 5 1/2 5 5/8 5 3/4 5 7/8 6 7/8 214 801 214 802 214 803 214 804 214 805 214 806 214 807 214 808 214 809 214 810 214 811 214 812 214 813 214 814 214 815 214 816 214 817 214 818 214 819 214 820 214 821 214 822 214 823 214 824 214 825 214 826 214 827 214 828 214 829 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 250 801 T 250 802 T 250 803 T 250 804 T 250 805 T 250 806 T 250 807 T 250 808 T 250 809 T 250 810 T 250 811 T 250 812 T 250 813 T 250 814 T 250 815 T 250 816 T 250 817 T 250 818 T 250 819 T 250 820 T 250 821 T 250 822 T 250 823 T 250 824 T 250 825 T 250 826 T 250 827 T 250 828 T 250 829 T 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5/64 3/32 7/64 1/8 9/64 5/32 11/64 3/16 13/64 7/32 15/64 1/4 17/64 9/32 19/64 5/16 21/64 11/32 23/64 3/8 25/64 13/32 27/64 7/16 29/64 15/32 31/64 1/2 70 stainless steel 1 1 1/4 1 1/2 1 5/8 1 3/4 2 2 1/8 2 5/16 2 7/16 2 1/2 2 5/8 2 3/4 2 7/8 2 15/16 3 1/16 3 3/16 3 5/16 3 7/16 3 1/2 3 5/8 3 3/4 3 7/8 3 15/16 4 1/16 4 3/16 4 5/16 4 3/8 4 1/2 Description Article no. HSS-G Article no. HSS-G TiN 21-piece set of twist drills DIN 338 type N, in fractional sizes Ø 1/16" up to 3/8" in increments of 1/64" in steel case 214 850 250 850 T 29-piece set of twist drills DIN 338 type N, in fractional sizes Ø 1/16" up to 1/2" in increments of 1/64" in steel case 214 851 250 851 T « www.ruko.de » Ø Twist drills DiN 338 type VA, in fractional sizes DIN 338 VA HSSE Co 5 C 5xD 130° ≥ Ø 2,0 mm h8 36° 1.01 L2 Powerful right-hand cutting high-performance drill with distinctive heat resistance and reinforced drill core. Ideal for drilling high-strength stainless, acid-resistant and heat-resistant steel. L1 Packing unit: in plastic box HSSE Co 5 HSSE Co 5 steel (N/mm2) < 900 < 1100 < 1300 Main application stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Ø inch Ø mm L1 in inch L2 in inch Article no. HSSE-Co5 Cont. pcs. Article no. HSSE-Co 5 Cont. pcs. 1/16 1,59 1,98 2,38 2,78 3,18 3,57 3,97 4,37 4,76 5,16 5,56 5,95 6,35 6,75 7,14 7,54 7,94 8,33 8,73 9,13 9,53 9,92 10,32 10,72 11,11 11,51 11,91 12,30 12,70 1 7/8 2 2 1/4 2 5/8 2 3/4 2 7/8 3 1/8 3 1/4 3 1/2 3 5/8 3 3/4 3 7/8 4 4 1/8 4 1/4 4 3/8 4 1/2 4 5/8 4 3/4 4 7/8 5 5 1/8 5 1/4 5 3/8 5 1/2 5 5/8 5 3/4 5 7/8 6 7/8 215 801 215 802 215 803 215 804 215 805 215 806 215 807 215 808 215 809 215 810 215 811 215 812 215 813 215 814 215 815 215 816 215 817 215 818 215 819 215 820 215 821 215 822 215 823 215 824 215 825 215 826 215 827 215 828 215 829 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 215 801 Z 215 802 Z 215 803 Z 215 804 Z 215 805 Z 215 806 Z 215 807 Z 215 808 Z 215 809 Z 215 810 Z 215 811 Z 215 812 Z 215 813 Z 215 814 Z 215 815 Z 215 816 Z 215 817 Z 215 818 Z 215 819 Z 215 820 Z 215 821 Z 215 822 Z 215 823 Z 215 824 Z 215 825 Z 215 826 Z 215 827 Z 215 828 Z 215 829 Z 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5/64 3/32 7/64 1/8 9/64 5/32 11/64 3/16 13/64 7/32 15/64 1/4 17/64 9/32 19/64 5/16 21/64 11/32 23/64 3/8 25/64 13/32 27/64 7/16 29/64 15/32 31/64 1/2 1 1 1/4 1 1/2 1 5/8 1 3/4 2 2 1/8 2 5/16 2 7/16 2 1/2 2 5/8 2 3/4 2 7/8 2 15/16 3 1/16 3 3/16 3 5/16 3 7/16 3 1/2 3 5/8 3 3/4 3 7/8 3 15/16 4 1/16 4 3/16 4 5/16 4 3/8 4 1/2 Description Article no. HSSE-Co5 Article no. HSSE-Co 5 21-piece set of twist drills DIN 338 type VA, in fractional sizes Ø 1/16" up to 3/8" in increments of 1/64" in steel case 215 850 215 850 Z 29-piece set of twist drills DIN 338 type VA, in fractional sizes Ø 1/16" up to 1/2" in increments of 1/64" in steel case 215 851 215 851 Z 71 Ø Twist drills DiN 340 TL 3000, HssE-Co 5 ground DIN 340 TL HSSE 3000 Co 5 C 130° 10 x D h8 40° 1.01 L1 L2 Highly stable multirange drill with outstanding heat resistance, a reinforced drill core and a parabolic flute for ideal chip removal. Ideal for drilling medium and long-chipping materials. Thanks to its thick core and the special flute with a rounded rear edge, this drill is best suited for high-performance use. It covers types N, H and W for a wide range of applications. Packing unit: in plastic box HSSE Co 5 HSSE Co 5 steel (N/mm2) < 900 < 1100 < 1300 Main application 72 stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiAlN Cont. pcs. 2,50 3,00 3,10 3,20 3,30 3,40 3,50 3,60 3,70 3,80 3,90 4,00 4,10 4,20 4,30 4,40 4,50 4,60 4,70 4,80 4,90 5,00 5,10 5,20 5,30 5,40 5,50 5,60 5,70 5,80 5,90 6,00 6,10 6,20 6,30 95,0 100,0 106,0 106,0 106,0 112,0 112,0 112,0 112,0 119,0 119,0 119,0 119,0 119,0 126,0 126,0 126,0 126,0 126,0 132,0 132,0 132,0 132,0 132,0 132,0 139,0 139,0 139,0 139,0 139,0 139,0 139,0 148,0 148,0 148,0 62,0 66,0 69,0 69,0 69,0 73,0 73,0 73,0 73,0 78,0 78,0 78,0 78,0 78,0 82,0 82,0 82,0 82,0 82,0 87,0 87,0 87,0 87,0 87,0 87,0 91,0 91,0 91,0 91,0 91,0 91,0 91,0 97,0 97,0 97,0 253 025 253 030 253 031 253 032 253 033 253 034 253 035 253 036 253 037 253 038 253 039 253 040 253 041 253 042 253 043 253 044 253 045 253 046 253 047 253 048 253 049 253 050 253 051 253 052 253 053 253 054 253 055 253 056 253 057 253 058 253 059 253 060 253 061 253 062 253 063 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 253 025 F 253 030 F 253 031 F 253 032 F 253 033 F 253 034 F 253 035 F 253 036 F 253 037 F 253 038 F 253 039 F 253 040 F 253 041 F 253 042 F 253 043 F 253 044 F 253 045 F 253 046 F 253 047 F 253 048 F 253 049 F 253 050 F 253 051 F 253 052 F 253 053 F 253 054 F 253 055 F 253 056 F 253 057 F 253 058 F 253 059 F 253 060 F 253 061 F 253 062 F 253 063 F 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiAlN Cont. pcs. 6,40 6,50 6,60 6,70 6,80 6,90 7,00 7,10 7,20 7,30 7,40 7,50 7,60 7,70 7,80 7,90 8,00 8,10 8,20 8,30 8,40 8,50 8,60 8,70 8,80 8,90 9,00 9,10 9,20 9,30 9,40 9,50 9,60 9,70 9,80 9,90 10,00 10,50 11,00 11,50 12,00 12,50 13,00 148,0 148,0 148,0 148,0 156,0 156,0 156,0 156,0 156,0 156,0 156,0 156,0 165,0 165,0 165,0 165,0 165,0 165,0 165,0 165,0 165,0 165,0 175,0 175,0 175,0 175,0 175,0 175,0 175,0 175,0 175,0 175,0 184,0 184,0 184,0 184,0 184,0 184,0 195,0 195,0 205,0 205,0 205,0 97,0 97,0 97,0 97,0 102,0 102,0 102,0 102,0 102,0 102,0 102,0 102,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 115,0 115,0 115,0 115,0 115,0 115,0 115,0 115,0 115,0 115,0 121,0 121,0 121,0 121,0 121,0 121,0 128,0 128,0 134,0 134,0 134,0 253 064 253 065 253 066 253 067 253 068 253 069 253 070 253 071 253 072 253 073 253 074 253 075 253 076 253 077 253 078 253 079 253 080 253 081 253 082 253 083 253 084 253 085 253 086 253 087 253 088 253 089 253 090 253 091 253 092 253 093 253 094 253 095 253 096 253 097 253 098 253 099 253 100 253 105 253 110 253 115 253 120 253 125 253 130 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 253 064 F 253 065 F 253 066 F 253 067 F 253 068 F 253 069 F 253 070 F 253 071 F 253 072 F 253 073 F 253 074 F 253 075 F 253 076 F 253 077 F 253 078 F 253 079 F 253 080 F 253 081 F 253 082 F 253 083 F 253 084 F 253 085 F 253 086 F 253 087 F 253 088 F 253 089 F 253 090 F 253 091 F 253 092 F 253 093 F 253 094 F 253 095 F 253 096 F 253 097 F 253 098 F 253 099 F 253 100 F 253 105 F 253 110 F 253 115 F 253 120 F 253 125 F 253 130 F 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 73 1.01 Ø Twist drills DiN 340 type N, Hss ground DIN 340 N HSS-G N 118° 10 x D h8 25-30° 1.01 High-performance ground standard twist drill made from heavy-duty high speed steel. The fully ground twist drill has a precise concentricity. L1 L2 Packing unit: in plastic box HSS-G HSS-G steel (N/mm2) < 900 < 1100 < 1300 Main application 74 stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. Article no. HSS-G TiN Cont. pcs. 2,50 3,00 3,10 3,20 3,30 3,40 3,50 3,60 3,70 3,80 3,90 4,00 4,10 4,20 4,30 4,40 4,50 4,60 4,70 4,80 4,90 5,00 5,10 5,20 5,30 5,40 5,50 5,60 5,70 5,80 5,90 6,00 6,10 6,20 6,30 95,0 100,0 106,0 106,0 106,0 112,0 112,0 112,0 112,0 119,0 119,0 119,0 119,0 119,0 126,0 126,0 126,0 126,0 126,0 132,0 132,0 132,0 132,0 132,0 132,0 139,0 139,0 139,0 139,0 139,0 139,0 139,0 148,0 148,0 148,0 62,0 66,0 69,0 69,0 69,0 73,0 73,0 73,0 73,0 78,0 78,0 78,0 78,0 78,0 82,0 82,0 82,0 82,0 82,0 87,0 87,0 87,0 87,0 87,0 87,0 91,0 91,0 91,0 91,0 91,0 91,0 91,0 97,0 97,0 97,0 203 025 203 030 203 031 203 032 203 033 203 034 203 035 203 036 203 037 203 038 203 039 203 040 203 041 203 042 203 043 203 044 203 045 203 046 203 047 203 048 203 049 203 050 203 051 203 052 203 053 203 054 203 055 203 056 203 057 203 058 203 059 203 060 203 061 203 062 203 063 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 203 025 T 203 030 T 203 031 T 203 032 T 203 033 T 203 034 T 203 035 T 203 036 T 203 037 T 203 038 T 203 039 T 203 040 T 203 041 T 203 042 T 203 043 T 203 044 T 203 045 T 203 046 T 203 047 T 203 048 T 203 049 T 203 050 T 203 051 T 203 052 T 203 053 T 203 054 T 203 055 T 203 056 T 203 057 T 203 058 T 203 059 T 203 060 T 203 061 T 203 062 T 203 063 T 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. Article no. HSS-G TiN Cont. pcs. 6,40 6,50 6,60 6,70 6,80 6,90 7,00 7,10 7,20 7,30 7,40 7,50 7,60 7,70 7,80 7,90 8,00 8,10 8,20 8,30 8,40 8,50 8,60 8,70 8,80 8,90 9,00 9,10 9,20 9,30 9,40 9,50 9,60 9,70 9,80 9,90 10,00 10,50 11,00 11,50 12,00 12,50 13,00 148,0 148,0 148,0 148,0 156,0 156,0 156,0 156,0 156,0 156,0 156,0 156,0 165,0 165,0 165,0 165,0 165,0 165,0 165,0 165,0 165,0 165,0 175,0 175,0 175,0 175,0 175,0 175,0 175,0 175,0 175,0 175,0 184,0 184,0 184,0 184,0 184,0 184,0 195,0 195,0 205,0 205,0 205,0 97,0 97,0 97,0 97,0 102,0 102,0 102,0 102,0 102,0 102,0 102,0 102,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 115,0 115,0 115,0 115,0 115,0 115,0 115,0 115,0 115,0 115,0 121,0 121,0 121,0 121,0 121,0 121,0 128,0 128,0 134,0 134,0 134,0 203 064 203 065 203 066 203 067 203 068 203 069 203 070 203 071 203 072 203 073 203 074 203 075 203 076 203 077 203 078 203 079 203 080 203 081 203 082 203 083 203 084 203 085 203 086 203 087 203 088 203 089 203 090 203 091 203 092 203 093 203 094 203 095 203 096 203 097 203 098 203 099 203 100 203 105 203 110 203 115 203 120 203 125 203 130 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 203 064 T 203 065 T 203 066 T 203 067 T 203 068 T 203 069 T 203 070 T 203 071 T 203 072 T 203 073 T 203 074 T 203 075 T 203 076 T 203 077 T 203 078 T 203 079 T 203 080 T 203 081 T 203 082 T 203 083 T 203 084 T 203 085 T 203 086 T 203 087 T 203 088 T 203 089 T 203 090 T 203 091 T 203 092 T 203 093 T 203 094 T 203 095 T 203 096 T 203 097 T 203 098 T 203 099 T 203 100 T 203 105 T 203 110 T 203 115 T 203 120 T 203 125 T 203 130 T 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 75 1.01 Ø Twist drills DiN 1869 TL 3000, Hss ground - extra long DIN 1869 TL 3000 HSS G C 130° 15 x D h8 40° 1.01 Stable special drill. Ideally suitable for deep holes under difficult conditions, e.g. bad chipping materials. Suitable for all usual drilling work in all normal materials. High rotational precision. For drilling deep holes please use small feed and remove chips frequently. L2 Packing unit: in plastic box steel (N/mm2) < 900 < 1100 < 1300 L1 Main application 76 stainless steel aluminium brass Other application bronze plastics cast iron titanium alloyed « www.ruko.de » Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. 2,00 2,50 3,00 3,20 3,30 3,50 4,00 4,20 4,50 5,00 5,50 6,00 6,50 125,0 140,0 150,0 155,0 155,0 165,0 175,0 175,0 185,0 195,0 205,0 205,0 215,0 85,0 95,0 100,0 105,0 105,0 115,0 120,0 120,0 125,0 135,0 140,0 140,0 150,0 254 020 254 025 254 030 254 032 254 033 254 035 254 040 254 042 254 045 254 050 254 055 254 060 254 065 1 1 1 1 1 1 1 1 1 1 1 1 1 7,00 7,50 8,00 8,50 9,00 9,50 10,00 10,50 11,00 11,50 12,00 12,50 13,00 225,0 225,0 240,0 240,0 250,0 250,0 265,0 265,0 280,0 280,0 295,0 295,0 295,0 155,0 155,0 165,0 165,0 175,0 175,0 185,0 185,0 195,0 195,0 205,0 205,0 205,0 254 070 254 075 254 080 254 085 254 090 254 095 254 100 254 105 254 110 254 115 254 120 254 125 254 130 1 1 1 1 1 1 1 1 1 1 1 1 1 Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. 3,00 3,20 3,30 3,50 4,00 4,20 4,50 5,00 5,50 6,00 6,50 7,00 190,0 200,0 200,0 210,0 220,0 220,0 235,0 245,0 260,0 260,0 275,0 290,0 130,0 135,0 135,0 145,0 150,0 150,0 160,0 170,0 180,0 180,0 190,0 200,0 255 030 255 032 255 033 255 035 255 040 255 042 255 045 255 050 255 055 255 060 255 065 255 070 1 1 1 1 1 1 1 1 1 1 1 1 7,50 8,00 8,50 9,00 9,50 10,00 10,50 11,00 11,50 12,00 12,50 13,00 290,0 305,0 305,0 320,0 320,0 340,0 340,0 365,0 365,0 375,0 375,0 375,0 200,0 210,0 210,0 220,0 220,0 235,0 235,0 250,0 250,0 260,0 260,0 260,0 255 075 255 080 255 085 255 090 255 095 255 100 255 105 255 110 255 115 255 120 255 125 255 130 1 1 1 1 1 1 1 1 1 1 1 1 Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. 3,50 4,00 4,20 4,50 5,00 5,50 6,00 6,50 7,00 7,50 8,00 265,0 280,0 280,0 295,0 315,0 330,0 330,0 350,0 370,0 370,0 390,0 180,0 190,0 190,0 200,0 210,0 225,0 225,0 235,0 250,0 250,0 265,0 256 035 256 040 256 042 256 045 256 050 256 055 256 060 256 065 256 070 256 075 256 080 1 1 1 1 1 1 1 1 1 1 1 8,50 9,00 9,50 10,00 10,50 11,00 11,50 12,00 12,50 13,00 — 390,0 410,0 410,0 430,0 430,0 455,0 455,0 480,0 480,0 480,0 — 265,0 280,0 280,0 295,0 295,0 310,0 310,0 330,0 330,0 330,0 — 256 085 256 090 256 095 256 100 256 105 256 110 256 115 256 120 256 125 256 130 — 1 1 1 1 1 1 1 1 1 1 — 77 1.01 Twist drills DiN 345 type N, Hss and HssE-Co 5 Ø1 DIN 345 1.01 N A HSSE Co 5 HSS 118° 6xD h8 20-30° L2 Highly efficient standard drill with morse taper. For drilling steel, cast steel and cast iron – alloyed and unalloyed. Highly secure against fracture. Packing unit: in plastic box L1 HSS steel (N/mm2) < 900 < 1100 stainless steel aluminium brass bronze plastics < 1300 cast iron titanium alloyed stainless steel aluminium brass bronze plastics < 1300 cast iron titanium alloyed stainless steel aluminium brass bronze plastics < 1300 cast iron titanium alloyed HSSE Co 5 steel (N/mm2) < 900 < 1100 HSSE Co 5 steel (N/mm2) < 900 < 1100 Main application 78 Other application Ø mm L1 mm L2 mm Morse taper no. Article no. HSS Cont. pcs. Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiN Cont. pcs. 10,00 10,50 11,00 11,50 12,00 12,50 13,00 13,50 14,00 14,50 15,00 15,50 16,00 16,50 17,00 17,50 18,00 18,50 19,00 19,50 20,00 168,0 168,0 175,0 175,0 182,0 182,0 182,0 189,0 189,0 212,0 212,0 218,0 218,0 223,0 223,0 228,0 228,0 233,0 233,0 238,0 238,0 87,0 87,0 94,0 94,0 101,0 101,0 101,0 108,0 108,0 114,0 114,0 120,0 120,0 125,0 125,0 130,0 130,0 135,0 135,0 140,0 140,0 1 1 1 1 1 1 1 1 1 2 2 2 2 2 2 2 2 2 2 2 2 204 100 204 105 204 110 204 115 204 120 204 125 204 130 204 135 204 140 204 145 204 150 204 155 204 160 204 165 204 170 204 175 204 180 204 185 204 190 204 195 204 200 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 204 100 E 204 105 E 204 110 E 204 115 E 204 120 E 204 125 E 204 130 E 204 135 E 204 140 E 204 145 E 204 150 E 204 155 E 204 160 E 204 165 E 204 170 E 204 175 E 204 180 E 204 185 E 204 190 E 204 195 E 204 200 E 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 204 100 T 204 105 T 204 110 T 204 115 T 204 120 T 204 125 T 204 130 T 204 135 T 204 140 T 204 145 T 204 150 T 204 155 T 204 160 T 204 165 T 204 170 T 204 175 T 204 180 T 204 185 T 204 190 T 204 195 T 204 200 T 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 « www.ruko.de » Ø mm L1 mm L2 mm Morse taper no. Article no. HSS Cont. pcs. Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiN Cont. pcs. 20,50 21,00 21,50 22,00 22,50 23,00 23,50 24,00 24,50 25,00 25,50 26,00 26,50 27,00 27,50 28,00 28,50 29,00 29,50 30,00 30,50 31,00 31,50 32,00 32,50 33,00 33,50 34,00 34,50 35,00 35,50 36,00 36,50 37,00 37,50 38,00 38,50 39,00 39,50 40,00 40,50 41,00 41,50 42,00 42,50 43,00 43,50 44,00 44,50 45,00 45,50 46,00 46,50 47,00 47,50 48,00 48,50 49,00 49,50 50,00 51,00 52,00 53,00 54,00 55,00 56,00 57,00 58,00 59,00 60,00 243,0 243,0 248,0 248,0 253,0 253,0 276,0 281,0 281,0 281,0 286,0 286,0 286,0 291,0 291,0 291,0 296,0 296,0 296,0 296,0 301,0 301,0 301,0 334,0 334,0 334,0 334,0 339,0 339,0 339,0 339,0 344,0 344,0 344,0 344,0 349,0 349,0 349,0 349,0 349,0 354,0 354,0 354,0 354,0 354,0 359,0 359,0 359,0 359,0 359,0 364,0 364,0 364,0 364,0 364,0 369,0 369,0 369,0 369,0 369,0 412,0 412,0 412,0 417,0 417,0 417,0 422,0 422,0 422,0 422,0 145,0 145,0 150,0 150,0 155,0 155,0 155,0 160,0 160,0 160,0 165,0 165,0 165,0 170,0 170,0 170,0 175,0 175,0 175,0 175,0 180,0 180,0 180,0 185,0 185,0 185,0 185,0 190,0 190,0 190,0 190,0 195,0 195,0 195,0 195,0 200,0 200,0 200,0 200,0 200,0 205,0 205,0 205,0 205,0 205,0 210,0 210,0 210,0 210,0 210,0 215,0 215,0 215,0 215,0 215,0 220,0 220,0 220,0 220,0 220,0 225,0 225,0 225,0 230,0 230,0 230,0 235,0 235,0 235,0 235,0 2 2 2 2 2 2 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 5 5 5 5 5 5 5 5 5 5 204 205 204 210 204 215 204 220 204 225 204 230 204 235 204 240 204 245 204 250 204 255 204 260 204 265 204 270 204 275 204 280 204 285 204 290 204 295 204 300 204 305 204 310 204 315 204 320 204 325 204 330 204 335 204 340 204 345 204 350 204 355 204 360 204 365 204 370 204 375 204 380 204 385 204 390 204 395 204 400 204 405 204 410 204 415 204 420 204 425 204 430 204 435 204 440 204 445 204 450 204 455 204 460 204 465 204 470 204 475 204 480 204 485 204 490 204 495 204 500 204 510 204 520 204 530 204 540 204 550 204 560 204 570 204 580 204 590 204 600 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 204 205 E 204 210 E 204 215 E 204 220 E 204 225 E 204 230 E 204 235 E 204 240 E 204 245 E 204 250 E 204 255 E 204 260 E 204 265 E 204 270 E 204 275 E 204 280 E 204 285 E 204 290 E 204 295 E 204 300 E — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — 204 205 T 204 210 T 204 215 T 204 220 T 204 225 T 204 230 T 204 235 T 204 240 T 204 245 T 204 250 T 204 255 T 204 260 T 204 265 T 204 270 T 204 275 T 204 280 T 204 285 T 204 290 T 204 295 T 204 300 T — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — 79 1.01 Twist drills DiN 1897 type UF-L, HssE-Co 5 ground - short Ø DIN 1897 HSSE Co 5 U 3xD 130° ≥ Ø 2,5 mm h8 40° L2 1.01 UF-L L1 Short and highly stable multirange drill with outstanding heat resistance and special geometry for optimising chip formation and removal. Ideally suited for assembly work in thin-walled materials such as sheet steels, flat steel and profile steel comprising of medium and long-chipping materials. Packing unit: in plastic box HSSE Co 5 HSSE Co 5 steel (N/mm2) < 900 < 1100 < 1300 Main application 80 stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiAlN Cont. pcs. 2,00 2,50 2,80 3,00 3,10 3,20 3,30 3,40 3,50 3,60 3,70 3,80 3,90 4,00 4,10 4,20 4,30 4,40 4,50 4,60 4,70 4,80 4,90 5,00 5,10 5,20 5,30 5,40 5,50 5,60 5,70 5,80 5,90 38,0 43,0 46,0 46,0 49,0 49,0 49,0 52,0 52,0 52,0 52,0 55,0 55,0 55,0 55,0 55,0 58,0 58,0 58,0 58,0 58,0 62,0 62,0 62,0 62,0 62,0 62,0 66,0 66,0 66,0 66,0 66,0 66,0 12,0 14,0 16,0 16,0 18,0 18,0 18,0 20,0 20,0 20,0 20,0 22,0 22,0 22,0 22,0 22,0 24,0 24,0 24,0 24,0 24,0 26,0 26,0 26,0 26,0 26,0 26,0 28,0 28,0 28,0 28,0 28,0 28,0 284 020 E 284 025 E 284 028 E 284 030 E 284 031 E 284 032 E 284 033 E 284 034 E 284 035 E 284 036 E 284 037 E 284 038 E 284 039 E 284 040 E 284 041 E 284 042 E 284 043 E 284 044 E 284 045 E 284 046 E 284 047 E 284 048 E 284 049 E 284 050 E 284 051 E 284 052 E 284 053 E 284 054 E 284 055 E 284 056 E 284 057 E 284 058 E 284 059 E 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 284 020 EF 284 025 EF 284 028 EF 284 030 EF 284 031 EF 284 032 EF 284 033 EF 284 034 EF 284 035 EF 284 036 EF 284 037 EF 284 038 EF 284 039 EF 284 040 EF 284 041 EF 284 042 EF 284 043 EF 284 044 EF 284 045 EF 284 046 EF 284 047 EF 284 048 EF 284 049 EF 284 050 EF 284 051 EF 284 052 EF 284 053 EF 284 054 EF 284 055 EF 284 056 EF 284 057 EF 284 058 EF 284 059 EF 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiAlN Cont. pcs. 6,00 6,10 6,20 6,50 6,80 7,00 7,20 7,50 7,80 8,00 8,20 8,50 8,80 9,00 9,20 9,50 9,80 10,00 10,20 10,50 10,80 11,00 11,20 11,50 11,80 12,00 12,50 12,80 13,00 13,50 14,00 14,50 15,00 15,50 16,00 66,0 70,0 70,0 70,0 74,0 74,0 74,0 74,0 79,0 79,0 79,0 79,0 84,0 84,0 84,0 84,0 89,0 89,0 89,0 89,0 95,0 95,0 95,0 95,0 95,0 102,0 102,0 102,0 102,0 107,0 107,0 111,0 111,0 115,0 115,0 28,0 31,0 31,0 31,0 34,0 34,0 34,0 34,0 37,0 37,0 37,0 37,0 40,0 40,0 40,0 40,0 43,0 43,0 43,0 43,0 47,0 47,0 47,0 47,0 47,0 51,0 51,0 51,0 51,0 54,0 54,0 56,0 56,0 58,0 58,0 284 060 E 284 061 E 284 062 E 284 065 E 284 068 E 284 070 E 284 072 E 284 075 E 284 078 E 284 080 E 284 082 E 284 085 E 284 088 E 284 090 E 284 092 E 284 095 E 284 098 E 284 100 E 284 102 E 284 105 E 284 108 E 284 110 E 284 112 E 284 115 E 284 118 E 284 120 E 284 125 E 284 128 E 284 130 E 284 135 E 284 140 E 284 145 E 284 150 E 284 155 E 284 160 E 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 284 060 EF 284 061 EF 284 062 EF 284 065 EF 284 068 EF 284 070 EF 284 072 EF 284 075 EF 284 078 EF 284 080 EF 284 082 EF 284 085 EF 284 088 EF 284 090 EF 284 092 EF 284 095 EF 284 098 EF 284 100 EF 284 102 EF 284 105 EF 284 108 EF 284 110 EF 284 112 EF 284 115 EF 284 118 EF 284 120 EF 284 125 EF 284 128 EF 284 130 EF 284 135 EF 284 140 EF 284 145 EF 284 150 EF 284 155 EF 284 160 EF 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 81 1.01 Ø Twist drills DiN 1897 type N, HssE-Co 5 ground - short DIN 1897 HSSE Co 5 C 3xD 130° ≥ Ø 2,5 mm h8 25-30° L2 1.01 N L1 Short and stable twist drill with distinctive heat resistance. Ideally suited for assembly work with thin-walled materials such as sheet steels, flat steels and profile steel in bodyshell construction. Use in hand-held drilling machines, with automatic machines and with turret lathes. Packing unit: in plastic box HSSE Co 5 HSSE Co 5 steel (N/mm2) < 900 < 1100 < 1300 Main application 82 stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiAlN Cont. pcs. 2,00 2,10 2,20 2,30 2,40 2,50 2,60 2,70 2,80 2,90 3,00 3,10 3,20 3,30 3,40 3,50 3,60 3,70 3,80 3,90 4,00 4,10 4,20 4,30 4,40 4,50 4,60 4,70 4,80 4,90 5,00 5,10 5,20 5,30 5,40 5,50 5,60 5,70 5,80 38,0 38,0 40,0 40,0 43,0 43,0 43,0 46,0 46,0 46,0 46,0 49,0 49,0 49,0 52,0 52,0 52,0 52,0 55,0 55,0 55,0 55,0 55,0 58,0 58,0 58,0 58,0 58,0 62,0 62,0 62,0 62,0 62,0 62,0 66,0 66,0 66,0 66,0 66,0 12,0 12,0 13,0 13,0 14,0 14,0 14,0 16,0 16,0 16,0 16,0 18,0 18,0 18,0 20,0 20,0 20,0 20,0 22,0 22,0 22,0 22,0 22,0 24,0 24,0 24,0 24,0 24,0 26,0 26,0 26,0 26,0 26,0 26,0 28,0 28,0 28,0 28,0 28,0 202 020 E 202 021 E 202 022 E 202 023 E 202 024 E 202 025 E 202 026 E 202 027 E 202 028 E 202 029 E 202 030 E 202 031 E 202 032 E 202 033 E 202 034 E 202 035 E 202 036 E 202 037 E 202 038 E 202 039 E 202 040 E 202 041 E 202 042 E 202 043 E 202 044 E 202 045 E 202 046 E 202 047 E 202 048 E 202 049 E 202 050 E 202 051 E 202 052 E 202 053 E 202 054 E 202 055 E 202 056 E 202 057 E 202 058 E 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 202 020 EF 202 021 EF 202 022 EF 202 023 EF 202 024 EF 202 025 EF 202 026 EF 202 027 EF 202 028 EF 202 029 EF 202 030 EF 202 031 EF 202 032 EF 202 033 EF 202 034 EF 202 035 EF 202 036 EF 202 037 EF 202 038 EF 202 039 EF 202 040 EF 202 041 EF 202 042 EF 202 043 EF 202 044 EF 202 045 EF 202 046 EF 202 047 EF 202 048 EF 202 049 EF 202 050 EF 202 051 EF 202 052 EF 202 053 EF 202 054 EF 202 055 EF 202 056 EF 202 057 EF 202 058 EF 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiAlN Cont. pcs. 5,90 6,00 6,10 6,20 6,30 6,40 6,50 6,60 6,70 6,80 6,90 7,00 7,10 7,20 7,30 7,40 7,50 7,60 7,70 7,80 7,90 8,00 8,10 8,20 8,30 8,40 8,50 8,60 8,70 8,80 8,90 9,00 9,10 9,20 9,30 9,40 9,50 9,60 9,70 9,80 9,90 10,00 10,10 10,20 10,30 10,40 10,50 10,60 10,70 10,80 10,90 11,00 11,10 11,20 11,30 11,40 11,50 11,60 11,70 11,80 11,90 12,00 12,10 12,20 12,30 12,40 12,50 12,60 12,70 12,80 12,90 13,00 66,0 66,0 70,0 70,0 70,0 70,0 70,0 70,0 70,0 74,0 74,0 74,0 74,0 74,0 74,0 74,0 74,0 79,0 79,0 79,0 79,0 79,0 79,0 79,0 79,0 79,0 79,0 84,0 84,0 84,0 84,0 84,0 84,0 84,0 84,0 84,0 84,0 89,0 89,0 89,0 89,0 89,0 89,0 89,0 89,0 89,0 89,0 89,0 95,0 95,0 95,0 95,0 95,0 95,0 95,0 95,0 95,0 95,0 95,0 95,0 102,0 102,0 102,0 102,0 102,0 102,0 102,0 102,0 102,0 102,0 102,0 102,0 28,0 28,0 31,0 31,0 31,0 31,0 31,0 31,0 31,0 34,0 34,0 34,0 34,0 34,0 34,0 34,0 34,0 37,0 37,0 37,0 37,0 37,0 37,0 37,0 37,0 37,0 37,0 40,0 40,0 40,0 40,0 40,0 40,0 40,0 40,0 40,0 40,0 43,0 43,0 43,0 43,0 43,0 43,0 43,0 43,0 43,0 43,0 43,0 47,0 47,0 47,0 47,0 47,0 47,0 47,0 47,0 47,0 47,0 47,0 47,0 51,0 51,0 51,0 51,0 51,0 51,0 51,0 51,0 51,0 51,0 51,0 51,0 202 059 E 202 060 E 202 061 E 202 062 E 202 063 E 202 064 E 202 065 E 202 066 E 202 067 E 202 068 E 202 069 E 202 070 E 202 071 E 202 072 E 202 073 E 202 074 E 202 075 E 202 076 E 202 077 E 202 078 E 202 079 E 202 080 E 202 081 E 202 082 E 202 083 E 202 084 E 202 085 E 202 086 E 202 087 E 202 088 E 202 089 E 202 090 E 202 091 E 202 092 E 202 093 E 202 094 E 202 095 E 202 096 E 202 097 E 202 098 E 202 099 E 202 100 E 202 101 E 202 102 E 202 103 E 202 104 E 202 105 E 202 106 E 202 107 E 202 108 E 202 109 E 202 110 E 202 111 E 202 112 E 202 113 E 202 114 E 202 115 E 202 116 E 202 117 E 202 118 E 202 119 E 202 120 E 202 121 E 202 122 E 202 123 E 202 124 E 202 125 E 202 126 E 202 127 E 202 128 E 202 129 E 202 130 E 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 202 059 EF 202 060 EF 202 061 EF 202 062 EF 202 063 EF 202 064 EF 202 065 EF 202 066 EF 202 067 EF 202 068 EF 202 069 EF 202 070 EF 202 071 EF 202 072 EF 202 073 EF 202 074 EF 202 075 EF 202 076 EF 202 077 EF 202 078 EF 202 079 EF 202 080 EF 202 081 EF 202 082 EF 202 083 EF 202 084 EF 202 085 EF 202 086 EF 202 087 EF 202 088 EF 202 089 EF 202 090 EF 202 091 EF 202 092 EF 202 093 EF 202 094 EF 202 095 EF 202 096 EF 202 097 EF 202 098 EF 202 099 EF 202 100 EF 202 101 EF 202 102 EF 202 103 EF 202 104 EF 202 105 EF 202 106 EF 202 107 EF 202 108 EF 202 109 EF 202 110 EF 202 111 EF 202 112 EF 202 113 EF 202 114 EF 202 115 EF 202 116 EF 202 117 EF 202 118 EF 202 119 EF 202 120 EF 202 121 EF 202 122 EF 202 123 EF 202 124 EF 202 125 EF 202 126 EF 202 127 EF 202 128 EF 202 129 EF 202 130 EF 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 83 1.01 Twist drills DiN 1897 type N, Hss-G ground - short Ø DIN 1897 HSS-G C 3xD 118° ≥ Ø 2,5 mm h8 25-30° L2 1.01 N L1 Short and stable twist drill with distinctive heat resistance. Ideally suited for assembly work with thin-walled materials such as sheet steels, flat steels and profile steel in bodyshell construction. Use in hand-held drilling machines, with automatic machines and with turret lathes. Packing unit: in plastic box HSS-G HSS-G steel (N/mm2) < 900 < 1100 < 1300 Main application 84 stainless steel aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. Article no. HSS-G TiN Cont. pcs. 2,00 2,10 2,20 2,30 2,40 2,50 2,60 2,70 2,80 2,90 3,00 3,10 3,20 3,30 3,40 3,50 3,60 3,70 3,80 3,90 4,00 4,10 4,20 4,30 4,40 4,50 4,60 4,70 4,80 4,90 38,0 38,0 40,0 40,0 43,0 43,0 43,0 46,0 46,0 46,0 46,0 49,0 49,0 49,0 52,0 52,0 52,0 52,0 55,0 55,0 55,0 55,0 55,0 58,0 58,0 58,0 58,0 58,0 62,0 62,0 12,0 12,0 13,0 13,0 14,0 14,0 14,0 16,0 16,0 16,0 16,0 18,0 18,0 18,0 20,0 20,0 20,0 20,0 22,0 22,0 22,0 22,0 22,0 24,0 24,0 24,0 24,0 24,0 26,0 26,0 202 020 202 021 202 022 202 023 202 024 202 025 202 026 202 027 202 028 202 029 202 030 202 031 202 032 202 033 202 034 202 035 202 036 202 037 202 038 202 039 202 040 202 041 202 042 202 043 202 044 202 045 202 046 202 047 202 048 202 049 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 202 020 T 202 021 T 202 022 T 202 023 T 202 024 T 202 025 T 202 026 T 202 027 T 202 028 T 202 029 T 202 030 T 202 031 T 202 032 T 202 033 T 202 034 T 202 035 T 202 036 T 202 037 T 202 038 T 202 039 T 202 040 T 202 041 T 202 042 T 202 043 T 202 044 T 202 045 T 202 046 T 202 047 T 202 048 T 202 049 T 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » Ø mm L1 mm L2 mm Article no. HSS-G Cont. pcs. Article no. HSS-G TiN Cont. pcs. 5,00 5,10 5,20 5,30 5,40 5,50 5,60 5,70 5,80 5,90 6,00 6,50 6,80 7,00 7,20 7,50 7,80 8,00 8,50 9,00 9,50 10,00 10,20 10,50 11,00 11,50 12,00 12,50 13,00 14,00 15,00 16,00 62,0 62,0 62,0 62,0 66,0 66,0 66,0 66,0 66,0 66,0 66,0 70,0 74,0 74,0 74,0 74,0 79,0 79,0 79,0 84,0 84,0 89,0 89,0 89,0 95,0 95,0 102,0 102,0 102,0 107,0 111,0 115,0 26,0 26,0 26,0 26,0 28,0 28,0 28,0 28,0 28,0 28,0 28,0 31,0 34,0 34,0 34,0 34,0 37,0 37,0 37,0 40,0 40,0 43,0 43,0 43,0 47,0 47,0 51,0 51,0 51,0 54,0 56,0 58,0 202 050 202 051 202 052 202 053 202 054 202 055 202 056 202 057 202 058 202 059 202 060 202 065 202 068 202 070 202 072 202 075 202 078 202 080 202 085 202 090 202 095 202 100 202 102 202 105 202 110 202 115 202 120 202 125 202 130 202 140 202 150 202 160 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 202 050 T 202 051 T 202 052 T 202 053 T 202 054 T 202 055 T 202 056 T 202 057 T 202 058 T 202 059 T 202 060 T 202 065 T 202 068 T 202 070 T 202 072 T 202 075 T 202 078 T 202 080 T 202 085 T 202 090 T 202 095 T 202 100 T 202 102 T 202 105 T 202 110 T 202 115 T 202 120 T 202 125 T 202 130 T 202 140 T 202 150 T 202 160 T 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 85 1.01 Ø spot drills type N, Hss ground - extra short N ≥ Ø 3,0 mm h8 130° 25-30° L1 L2 1.01 C HSS-G Extra short and stable standard drill. Shorter than DIN 1897. Ideally suitable for assembly work in thin-walled materials such as sheet steels, flat steels and profile steels. Highly secure against fracture. For use in all hand-held drilling machines. Advantages DIN 1412 C: good centring, little pressure required. Chip spreading improves chip removal. Packing unit: in plastic box steel (N/mm2) < 900 < 1100 < 1300 stainless steel Main application 86 aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. Cont. pcs. 2,50 2,80 3,00 3,10 3,20 3,25 3,30 3,40 3,50 4,00 4,10 4,20 4,30 4,50 4,70 4,80 4,90 5,00 5,10 5,20 5,50 6,00 6,50 38,0 40,0 40,0 40,0 40,0 41,0 41,0 42,0 42,0 42,0 44,0 44,0 44,0 48,0 48,0 48,0 50,0 52,0 52,0 52,0 52,0 55,0 60,0 14,0 16,0 16,0 16,0 16,0 16,0 16,0 16,0 16,0 16,0 18,0 18,0 18,0 20,0 20,0 20,0 22,0 24,0 24,0 24,0 24,0 26,0 26,0 251 025 251 028 251 030 251 031 251 032 251 0325 251 033 251 034 251 035 251 040 251 041 251 042 251 043 251 045 251 047 251 048 251 049 251 050 251 051 251 052 251 055 251 060 251 065 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » L1 L2 Ø Double end drills type KV, Hss ground N C HSS-G ≥ Ø 3,0 mm h8 130° 25-30° 1.01 Extra short and stable standard drill. Shorter than DIN 1897. Ideally suitable for assembly work in thin-walled materials such as sheet steels, flat steels and profile steels. High security against fracture. For use in handheld drilling machines. Usable at both ends. Advantages DIN 1412 C: good centring, little pressure required. Chip distribution improves chip removal. Packing unit: in plastic box steel (N/mm2) < 900 < 1100 < 1300 stainless steel Main application aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm 2,50 2,80 3,00 3,10 3,20 3,25 3,30 3,40 3,50 4,00 4,10 4,20 4,30 4,50 4,80 4,90 5,00 5,10 5,20 5,50 6,00 6,50 7,00 8,00 43,0 46,0 46,0 49,0 49,0 49,0 49,0 52,0 52,0 55,0 55,0 55,0 58,0 58,0 62,0 62,0 62,0 62,0 62,0 66,0 66,0 70,0 74,0 79,0 10,0 11,0 11,0 11,0 11,0 11,0 11,0 14,0 14,0 14,0 14,0 14,0 17,0 17,0 17,0 17,0 17,0 17,0 17,0 20,0 20,0 20,0 22,0 24,0 Article no. 252 025 252 028 252 030 252 031 252 032 252 0325 252 033 252 034 252 035 252 040 252 041 252 042 252 043 252 045 252 048 252 049 252 050 252 051 252 052 252 055 252 060 252 065 252 070 252 080 Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 87 Ø NC-spot drills 90º, HssE-Co 5 ground NC HSSE 90 Co 5 25-30° h8 90° L2 1.01 N L1 Special drill for highly accurate drilling, chamfering and centring on NC machines, milling machines and drilling machines. Faster drilling than with a centre drill. Packing unit: in plastic box HSSE Co 5 HSSE Co 5 steel (N/mm2) < 900 < 1100 < 1300 Main application 88 stainless steel HSSE Co 5 aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiN 3,0 4,0 5,0 6,0 8,0 10,0 12,0 14,0 16,0 20,0 46,0 55,0 62,0 66,0 79,0 89,0 102,0 107,0 115,0 131,0 12,0 12,0 14,0 16,0 21,0 25,0 30,0 34,0 38,0 45,0 286 030 E 286 040 E 286 050 E 286 060 E 286 080 E 286 100 E 286 120 E 286 140 E 286 160 E 286 200 E 10 10 10 10 10 10 10 10 10 10 286 030 ET 286 040 ET 286 050 ET 286 060 ET 286 080 ET 286 100 ET 286 120 ET 286 140 ET 286 160 ET 286 200 ET Cont. Article no. Cont. pcs. HSSE-Co 5 TiAlN pcs. 10 10 10 10 10 10 10 10 10 10 286 030 EF 286 040 EF 286 050 EF 286 060 EF 286 080 EF 286 100 EF 286 120 EF 286 140 EF 286 160 EF 286 200 EF 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » Ø NC-spot drills 90º, HssE-Co 5 ground with weldon shank NC HSSE 90 Co 5 N 25-30° h8 90° L2 1.01 L1 Special drill for highly accurate drilling, chamfering and centring on NC machines, milling machines and drilling machines. Faster drilling than with a centre drill. Packing unit: in plastic box HSSE Co 5 HSSE Co 5 steel (N/mm2) < 900 < 1100 < 1300 Main application stainless steel HSSE Co 5 aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiN 6,0 8,0 10,0 12,0 14,0 16,0 20,0 66,0 79,0 89,0 102,0 107,0 115,0 131,0 16,0 21,0 25,0 30,0 34,0 38,0 45,0 286 060 EW 286 080 EW 286 100 EW 286 120 EW 286 140 EW 286 160 EW 286 200 EW 10 10 10 10 10 10 10 286 060 EWT 286 080 EWT 286 100 EWT 286 120 EWT 286 140 EWT 286 160 EWT 286 200 EWT Cont. Article no. Cont. pcs. HSSE-Co 5 TiAlN pcs. 10 10 10 10 10 10 10 286 060 EWF 286 080 EWF 286 100 EWF 286 120 EWF 286 140 EWF 286 160 EWF 286 200 EWF 10 10 10 10 10 10 10 89 Ø NC-spot drills 120º, HssE-Co 5 ground NC HSSE 120 Co 5 25-30° h8 120° L2 1.01 N L1 Special drill for highly accurate drilling, chamfering and centring on NC machines, milling machines and drilling machines. Faster drilling than with a centre drill. Packing unit: in plastic box HSSE Co 5 HSSE Co 5 steel (N/mm2) < 900 < 1100 < 1300 Main application 90 stainless steel HSSE Co 5 aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiN 3,0 4,0 5,0 6,0 8,0 10,0 12,0 14,0 16,0 20,0 46,0 55,0 62,0 66,0 79,0 89,0 102,0 107,0 115,0 131,0 12,0 12,0 14,0 16,0 21,0 25,0 30,0 34,0 38,0 45,0 285 030 E 285 040 E 285 050 E 285 060 E 285 080 E 285 100 E 285 120 E 285 140 E 285 160 E 285 200 E 10 10 10 10 10 10 10 10 10 10 285 030 ET 285 040 ET 285 050 ET 285 060 ET 285 080 ET 285 100 ET 285 120 ET 285 140 ET 285 160 ET 285 200 ET Cont. Article no. Cont. pcs. HSSE-Co 5 TiAlN pcs. 10 10 10 10 10 10 10 10 10 10 285 030 EF 285 040 EF 285 050 EF 285 060 EF 285 080 EF 285 100 EF 285 120 EF 285 140 EF 285 160 EF 285 200 EF 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » Ø NC-spot drills 120º, HssE-Co 5 ground with weldon shank NC HSSE 120 Co 5 N 25-30° h8 120° L2 1.01 L1 Special drill for highly accurate drilling, chamfering and centring on NC machines, milling machines and drilling machines. Faster drilling than with a centre drill. Packing unit: in plastic box HSSE Co 5 HSSE Co 5 steel (N/mm2) < 900 < 1100 < 1300 Main application stainless steel aluminium HSSE Co 5 brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm L2 mm Article no. HSSE-Co 5 Cont. pcs. Article no. HSSE-Co 5 TiN 6,0 8,0 10,0 12,0 14,0 16,0 20,0 66,0 79,0 89,0 102,0 107,0 115,0 131,0 16,0 21,0 25,0 30,0 34,0 38,0 45,0 285 060 EW 285 080 EW 285 100 EW 285 120 EW 285 140 EW 285 160 EW 285 200 EW 10 10 10 10 10 10 10 285 060 EWT 285 080 EWT 285 100 EWT 285 120 EWT 285 140 EWT 285 160 EWT 285 200 EWT Cont. Article no. Cont. pcs. HSSE-Co 5 TiAlN pcs. 10 10 10 10 10 10 10 285 060 EWF 285 080 EWF 285 100 EWF 285 120 EWF 285 140 EWF 285 160 EWF 285 200 EWF 10 10 10 10 10 10 10 91 Ø Centre drills DiN 333, Hss ground DIN 333 HSS 60° 120° h8 1.01 Centre drills for making centre holes according to shape A, shape A with reinforcing bead and shape R. L1 Packing unit: in plastic box (1) shape A (2) shape A with reinforcing bead HSS HSS steel (N/mm2) Ø2 < 900 < 1100 < 1300 Main application 92 shape R stainless steel HSS aluminium brass bronze plastics cast iron titanium alloyed Other application Ø mm L1 mm Ø2 mm Article no. (1) shape A Article no. (2) shape A Article no. shape R Cont. pcs. 0,80 1,00 1,60 2,00 2,50 3,15 4,00 5,00 6,30 20,0 31,5 35,5 40,0 45,0 50,0 56,0 63,0 71,0 3,15 3,15 4,00 5,00 6,30 8,00 10,00 12,50 16,00 217 008 217 010 217 016 217 020 217 025 217 315 217 040 217 050 217 063 — 217 1 010 217 1 016 217 1 020 217 1 025 217 1 315 217 1 040 217 1 050 217 1 063 217 2 008 217 2 010 217 2 016 217 2 020 217 2 025 217 2 315 217 2 040 217 2 050 217 2 063 1 1 1 1 1 1 1 1 1 « www.ruko.de » Ø Hollow section twist drills type N, Hss ground C HSS-G ≥ Ø 3,0 mm 118° 25-30° h8 L2 N 1.01 Due to the short spiral shape the drill is particularly suitable for the working and fitting of hollow sections. The reduction of the cross cutting edge guarantees an optimized centring and long tool life. Packing unit: in plastic box steel (N/mm2) < 1100 < 1300 stainless steel aluminium brass bronze plastics cast iron titanium alloyed L1 < 900 Main application Other application Ø mm L1 mm L2 mm Article no. Cont. pcs. 3,00 4,90 4,90 4,90 4,90 5,00 5,00 5,00 5,00 5,00 5,00 5,10 5,10 5,10 5,10 5,10 5,10 5,30 5,30 5,30 5,30 5,30 5,30 5,50 5,50 5,50 5,50 5,50 5,50 5,70 5,70 5,70 5,70 5,70 5,70 5,80 5,80 5,80 5,80 5,80 5,80 100,0 70,0 100,0 120,0 150,0 70,0 100,0 120,0 150,0 180,0 210,0 70,0 100,0 120,0 150,0 180,0 210,0 70,0 100,0 120,0 150,0 180,0 210,0 70,0 100,0 120,0 150,0 180,0 210,0 70,0 100,0 120,0 150,0 180,0 210,0 70,0 100,0 120,0 150,0 180,0 210,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 257 514 257 515 257 491 257 516 257 492 257 501 257 502 257 517 257 503 257 518 257 504 257 519 257 511 257520 257 512 257 518 257 513 257 522 257 531 257 523 257 532 257 524 257 533 257 525 257 551 257 526 257 552 257 527 257 553 257 571 257 572 257 528 257 573 257 529 257 574 257 530 257 581 257 534 257 582 257 535 257 583 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 93 Application of drills and cutting conditions Material Recommended for use Cooling Cutting speed v [m/min] 1.01 Drill diameter d [mm] 2 Main suggestion Other suggestion 4 6 9 12 Feed rate f [mm/rotation Free cutting steel 350-500 N/mm2 214 ... 258 ... / 202 ... E 30-40 0,05 0,1 0,125 0,16 0,2 Free cutting steel 500-900 N/mm2 214 ... 228 ... / 202 ... E 25-30 0,04 0,08 0,1 0,125 0,16 Structural steel up to 500 N/mm2 214 ... 258 ... / 202 ... E 30-40 0,04 0,08 0,1 0,125 0,16 Structural steel 500-900 N/mm2 214 ... 228 ... / 202 ... E 20-25 0,032 0,063 0,08 0,1 0,125 214 ... 258 ... / 202 ... E 25-35 0,05 0,1 0,125 0,16 0,2 214 ... 228 ... / 202 ... E 20-25 0,4 0,08 0,1 0,125 0,16 282 ... E 281 ... E / 202 ... E E, O 10-15 0,025 0,05 0,063 0,08 0,1 Plain carbon case hardening steel up to 600 N/mm2 Alloyed case hardening steel 500-900 N/mm2 Alloyed case hardening steel 900-1000 N/mm2 282 ... E 228 ... / 202 ... E Heat treated nitriding steel 800-1250 N/mm2 282 ... E 228 ... E 15-20 0,032 0,063 0,08 0,1 0,125 E, O 8-12 0,025 0,05 0,063 0,08 0,1 Mild steel for heat treatment 500-750 N/mm2 214 ... 228 ... / 202 ... E 25-35 0,04 0,08 0,1 0,125 0,16 Plain carbon steel for heat treatment 700-1000 N/mm2 282 ... E 228 ... / 284 ... E E 15-20 0,04 0,08 0,1 0,125 0,16 Alloyed steel heat treatment 900-1250 N/mm2 282 ... E 228 ... / 284 ... E E, O 10-15 0,032 0,063 0,08 0,1 0,125 Maganese steel with content over 10 % Mn 282 ... E 281 ... E / 202 ... E E, O 3-6 0,2 0,04 0,063 0,08 0,1 Nitriding steel 700-900 N/mm2 282 ... E 228 ... / 202 ... E Alloyed tool steel 850-1250 N/mm2 282 ... E 228 ... E 14-18 0,032 0,063 0,08 0,1 0,12 E, O 8-12 0,025 0,05 0,063 0,08 0,1 Heat resistant steel 450-600 N/mm2 281 ... E 281 ... EF O 15-20 0,032 0,063 0,08 0,1 0,125 Stainless steel 215 ... 281 ... E E, O 6-10 0,02 0,032 0,05 0,08 0,1 Alloys hastelloy, inconel, nimonic 281 ... E 281 ... EF O 3-6 0,02 0,04 0,063 0,08 0,125 Grey cast iron HB 180-240 214 ... 228 ... E, CA 30-40 0,05 0,1 0,125 0,16 0,2 Grey cast iron HB 240-300 214 ... 228 ... E, CA 20-30 0,05 0,1 0,125 0,16 0,2 Malleable cast iron HB 180-240 214 ... 228 ... CA 20-30 0,05 0,1 0,125 0,16 0,2 Aluminium 280 ... 258 ... E 50-80 0,05 0,1 0,125 0,16 0,2 Aluminium alloys with content up to 10 % Si and 180 N/mm2 280 ... 258 ... E 40-65 0,063 0,1255 0,16 0,2 0,25 Aluminium alloys with content up to 10 % Si and 150-250 N/mm2 214 ... 202 ... E 30-50 0,063 0,1255 0,16 0,2 0,25 Copper 200-400 N/mm2 280 ... 228 ... E, O 30-40 0,05 0,1 0,16 0,2 281 ... E 281 ... EF E, O 60-80 0,063 0,1255 0,16 0,2 0,25 Plain carbon tool steel 700-900 N/mm2 Fragile brass with short chip 350-550 N/mm2 0,125 280 ... 280 ... E, O 30-50 0,063 0,1 0,125 0,16 0,2 Bronze 200-500 N/mm2 280 ... 280 ... E, O 20-40 0,05 0,08 0,125 0,16 0,2 Bronze 500-800 N/mm2 214 ... 258 ... E, O 15-30 0,05 0,08 0,125 0,16 0,2 Magnesium alloys-electron 281 ... E 281 ... EF - 60-100 0,08 0,125 0,016 0,02 0,25 Zinc, zinc alloys 214 ... 258 ... E 35-45 0,05 0,1 0,125 0,16 0,2 Titanium alloys up to 700 N/mm2 281 ... E 281 ... EF O 3-6 0,03 0,05 0,063 0,08 0,1 N/mm2 281 ... E 281 ... EF O 3-6 0,02 0,04 0,05 0,063 0,08 Tough brass with long chip 250-550 Titanium alloys 700-1000 N/mm2 Silver 214 ... 258 ... Duroplastics 281 ... E 281 ... EF E 30-40 0,05 0,08 0,1 0,125 0,16 CA 10-20 0,04 0,08 0,1 0,125 0,16 Thermoplastics 280 ... 280 ... W, CA 20-40 0,05 0,1 0,125 0,16 0,2 Plerspex 280 ... 280 ... W 15-25 0,05 0,08 0,125 0,16 0,2 Laminated materials (paper, wood) across layer 280 ... 280 ... CA 15-25 0,05 0,08 0,125 0,16 0,2 E = emulsion / O = cutting oil / CA = compressed air / W = water 94 « www.ruko.de » Drills Ø mm Cutting speed Vc = m/min 4 6 8 10 12 15 18 20 25 30 35 7962 5308 3981 3185 2654 2275 1990 1769 1592 1448 1327 1225 1137 1062 995 937 885 838 796 724 663 612 569 531 498 468 442 419 398 379 362 346 332 318 306 295 284 275 265 257 249 241 234 227 221 215 210 204 199 194 190 185 181 177 173 169 166 162 159 9554 6369 4777 3822 3185 2730 2389 2123 1911 1737 1592 1470 1365 1274 1194 1124 1062 1006 955 869 796 735 682 637 597 562 531 503 478 455 434 415 398 382 367 354 341 329 318 308 299 290 281 273 265 258 251 245 239 233 227 222 217 212 208 203 199 195 191 11146 7431 5573 4459 3715 3185 2787 2477 2229 2027 1858 1715 1592 1486 1393 1311 1238 1173 1115 1013 929 857 796 743 697 656 619 587 557 531 507 485 464 446 429 413 398 384 372 360 348 338 328 318 310 301 293 286 279 272 265 259 253 248 242 237 232 227 223 40 50 60 80 100 r.p.m. 1,0 1,5 2,0 2,5 3,0 3,5 4,0 4,5 5,0 5,5 6,0 6,5 7,0 7,5 8,0 8,5 9,0 9,5 10,0 11,0 12,0 13,0 14,0 15,0 16,0 17,0 18,0 19,0 20,0 21,0 22,0 23,0 24,0 25,0 26,0 27,0 28,0 29,0 30,0 31,0 32,0 33,0 34,0 35,0 36,0 37,0 38,0 39,0 40,0 41,0 42,0 43,0 44,0 45,0 46,0 47,0 48,0 49,0 50,0 1274 849 637 510 425 364 318 283 255 232 212 196 182 170 159 150 142 134 127 116 106 98 91 85 80 75 71 67 64 61 58 55 53 51 49 47 45 44 42 41 40 39 37 36 35 34 34 33 32 31 30 30 29 28 28 27 27 26 25 1911 1274 955 764 637 546 478 425 382 347 318 294 273 255 239 225 212 201 191 174 159 147 136 127 119 112 106 101 96 91 87 83 80 76 73 71 68 66 64 62 60 58 56 55 53 52 50 49 48 47 45 44 43 42 42 41 40 39 38 2548 1699 1274 1019 849 728 637 566 510 463 425 392 364 340 318 300 283 268 255 232 212 196 182 170 159 150 142 134 127 121 116 111 106 102 98 94 91 88 85 82 80 77 75 73 71 69 67 65 64 62 61 59 58 57 55 54 53 52 51 3185 2123 1592 1274 1062 910 796 708 637 579 531 490 455 425 398 375 354 335 318 290 265 245 227 212 199 187 177 168 159 152 145 138 133 127 122 118 114 110 106 103 100 97 94 91 88 86 84 82 80 78 76 74 72 71 69 68 66 65 64 Material High carbon struc. steel < 700 N/mm² High carbon struc. steel > 700 N/mm² Alloyed steel < 1000 N/mm² Cast iron < 250 N/mm² Cast iron > 250 N/mm² CuZn alloy brittle 3822 2548 1911 1529 1274 1092 955 849 764 695 637 588 546 510 478 450 425 402 382 347 318 294 273 255 239 225 212 201 191 182 174 166 159 153 147 142 136 132 127 123 119 116 112 109 106 103 101 98 96 93 91 89 87 85 83 81 80 78 76 4777 3185 2389 1911 1592 1365 1194 1062 955 869 796 735 682 637 597 562 531 503 478 434 398 367 341 318 299 281 265 251 239 227 217 208 199 191 184 177 171 165 159 154 149 145 141 136 133 129 126 122 119 117 114 111 109 106 104 102 100 97 96 5732 3822 2866 2293 1911 1638 1433 1274 1146 1042 955 882 819 764 717 674 637 603 573 521 478 441 409 382 358 337 318 302 287 273 261 249 239 229 220 212 205 198 191 185 179 174 169 164 159 155 151 147 143 140 136 133 130 127 125 122 119 117 115 6369 4246 3185 2548 2123 1820 1592 1415 1274 1158 1062 980 910 849 796 749 708 670 637 579 531 490 455 425 398 375 354 335 318 303 290 277 265 255 245 236 227 220 212 205 199 193 187 182 177 172 168 163 159 155 152 148 145 142 138 136 133 130 127 Cutting speed Vc m/min Coolant 30 - 35 20 - 25 20 - 25 15 - 25 10 - 20 60 - 100 cutting spray cutting spray cutting spray compressed air compressed air compressed air 12739 15924 19108 25478 31847 8493 10616 12739 16985 21231 6369 7962 9554 12739 15924 5096 6369 7643 10191 12739 4246 5308 6369 8493 10616 3640 4550 5460 7279 9099 3185 3981 4777 6369 7962 2831 3539 4246 5662 7077 2548 3185 3822 5096 6369 2316 2895 3474 4632 5790 2123 2654 3185 4246 5308 1960 2450 2940 3920 4900 1820 2275 2730 3640 4550 1699 2123 2548 3397 4246 1592 1990 2389 3185 3981 1499 1873 2248 2997 3747 1415 1769 2123 2831 3539 1341 1676 2011 2682 3352 1274 1592 1911 2548 3185 1158 1448 1737 2316 2895 1062 1327 1592 2123 2654 980 1225 1470 1960 2450 910 1137 1365 1820 2275 849 1062 1274 1699 2123 796 995 1194 1592 1990 749 937 1124 1499 1873 708 885 1062 1415 1769 670 838 1006 1341 1676 637 796 955 1274 1592 607 758 910 1213 1517 579 724 869 1158 1448 554 692 831 1108 1385 531 663 796 1062 1327 510 637 764 1019 1274 490 612 735 980 1225 472 590 708 944 1180 455 569 682 910 1137 439 549 659 879 1098 425 531 637 849 1062 411 514 616 822 1027 398 498 597 796 995 386 483 579 772 965 375 468 562 749 937 364 455 546 728 910 354 442 531 708 885 344 430 516 689 861 335 419 503 670 838 327 408 490 653 817 318 398 478 637 796 311 388 466 621 777 303 379 455 607 758 296 370 444 593 741 290 362 434 579 724 283 354 425 566 708 277 346 415 554 692 271 339 407 542 678 265 332 398 531 663 260 325 390 520 650 255 318 382 510 637 Material CuZn alloy tough Al alloy 11% Si Thermoplastics Duroplastics with inorganic filling Duroplastics with organic filling Cutting speed Vc m/min Coolant 35 - 60 30 - 50 20 - 40 15 - 25 15 - 35 compressed air cutting spray water compressed air compressed air 95 1.01 Drills Ø inch Cutting speed Vc = m/min 4 6 8 10 12 15 18 20 25 30 35 40 50 60 4980 3980 3320 2840 2490 2210 1990 1810 1660 1530 1420 1330 1240 1190 1120 1060 1010 960 920 870 840 800 770 740 720 690 670 650 630 5970 4780 3980 3410 2990 2650 2390 2170 1990 1840 1710 1590 1490 1430 1350 1270 1210 1150 1100 1050 1010 970 930 890 860 830 800 780 750 6970 5570 4640 3980 3480 3100 2790 2530 2320 2140 1990 1860 1740 1660 1570 1490 1410 1340 1280 1220 1170 1130 1080 1040 1000 970 940 910 880 7960 6370 5310 4550 3980 3540 3180 2900 2650 2450 2270 2120 1990 1900 1790 1700 1610 1530 1460 1400 1340 1290 1240 1190 1150 1110 1070 1040 1000 9950 7960 6630 5690 4980 4420 3980 3620 3320 3060 2840 2650 2490 2380 2240 2120 2020 1920 1830 1750 1680 1610 1550 1490 1430 1380 1340 1290 1250 80 100 r.p.m. 1/16 5/64 1.01 3/32 7/64 1/8 9/64 5/32 11/64 3/16 13/64 7/32 15/64 1/4 17/64 9/32 19/64 5/16 21/64 11/32 23/64 3/8 25/64 13/32 27/64 7/16 29/64 15/32 31/64 1/2 800 640 530 450 400 350 320 290 270 240 230 210 200 190 180 170 160 150 150 140 130 130 120 120 110 110 110 110 110 1190 960 800 680 600 530 480 430 400 370 340 320 300 290 270 250 240 230 220 210 200 190 190 180 170 170 160 160 150 1590 1270 1060 910 800 710 640 580 530 490 450 420 400 380 360 340 320 310 290 280 270 260 250 240 230 220 210 210 200 1990 1590 1330 1140 1000 880 800 720 660 610 570 530 500 480 450 420 400 380 370 350 340 320 310 300 290 280 270 260 250 Material High carbon struc. steel < 700 N/mm² High carbon struc. steel > 700 N/mm² Alloyed steel < 1000 N/mm² Cast iron < 250 N/mm² Cast iron > 250 N/mm² CuZn alloy brittle 96 2390 1910 1590 1360 1190 1060 960 870 800 730 680 640 600 570 540 510 480 460 440 420 400 390 370 360 340 330 320 310 300 2990 2390 1990 1710 1490 1330 1190 1090 1000 920 850 800 750 710 670 640 600 580 550 520 500 480 460 450 430 420 400 390 380 3580 2870 2390 2050 1790 1590 1430 1300 1190 1100 1020 960 900 860 810 760 730 690 660 630 600 580 560 540 520 500 480 470 450 3980 3180 2650 2270 1990 1770 1590 1450 1330 1220 1140 1060 1000 950 900 850 810 770 730 700 670 640 620 600 570 550 540 520 500 Cutting speed Vc m/min Coolant 30 - 35 20 - 25 20 - 25 15 - 25 10 - 20 60 - 100 cutting spray cutting spray cutting spray compressed air compressed air compressed air Material CuZn alloy tough Al alloy 11% Si Thermoplastics Duroplastics with inorganic filling Duroplastics with organic filling 11940 15920 19900 9550 12740 15920 7960 10620 13270 6820 9100 11370 5970 7960 9950 5310 7080 8850 4780 6370 7960 4340 5790 7240 3980 5310 6630 3670 4900 6120 3410 4550 5690 3180 4250 5310 2990 3980 4980 2850 3800 4750 2690 3590 4490 2550 3400 4250 2420 3230 4030 2300 3070 3840 2200 2930 3660 2100 2800 3500 2010 2680 3350 1930 2570 3220 1860 2470 3090 1790 2380 2980 1720 2300 2870 1660 2220 2770 1610 2140 2680 1550 2070 2590 1500 2010 2510 Cutting speed Vc m/min Coolant 35 - 60 30 - 50 20 - 40 15 - 25 15 - 35 compressed air cutting spray water compressed air compressed air
214850 价格&库存
很抱歉,暂时无法提供与“214850”相匹配的价格&库存,您可以联系我们找货
