231-040
231-040
    RUKO
231-040 数据手册
Thread-cutting tools Single-cut taps M ≈ DIN 352 HSS, ground Chamfer: Type B, 4 - 5 threads with progressive tap Thread: metric, DIN ISO 13 Flanks: relief-ground Tolerance: ISO 2 / 6H Surface: bright Right-hand cutting For through threads in unalloyed or low-alloyed steels up to 800 N/mm² strength, malleable cast iron and non-ferrous metals. The thread can be cut in one operation by hand or machine. 1.6 Packing unit: Individual plastic pack Nominal thread size Pitch mm Thread core hole mm Total length mm Thread length mm Article no. M 3 M 4 M 5 M 6 M 8 M 10 M 12 0,50 0,70 0,80 1,00 1,25 1,50 1,75 2,50 3,30 4,20 5,00 6,80 8,50 10,20 40,0 45,0 50,0 50,0 56,0 70,0 75,0 10,0 12,0 13,0 15,0 18,0 24,0 29,0 231 030 231 040 231 050 231 060 231 080 231 100 231 120 Price each € Single-cut taps M ≈ DIN 352 HSS Co 5, ground Chamfer: Type B, 4 - 5 threads with progressive tap Thread: metric, DIN ISO 13 Flanks: relief-ground Tolerance: ISO 2 / 6H Surface: bright Right-hand cutting For through threads in unalloyed or alloyed steels up to 900 N/mm² strength, malleable cast iron and non-ferrous metals. The thread can be cut in one operation by hand or machine. The machine tap consists of cobalt alloyed heavy-duty high-speed steel with higher heat-resistance for a longer tool life. Packing unit: Individual plastic pack Nominal thread size Pitch mm Thread core hole mm Total length mm Thread length mm Article no. M 3 M 4 M 5 M 6 M 8 M 10 M 12 0,50 0,70 0,80 1,00 1,25 1,50 1,75 2,50 3,30 4,20 5,00 6,80 8,50 10,20 40,0 45,0 50,0 50,0 56,0 70,0 75,0 10,0 12,0 13,0 15,0 18,0 24,0 29,0 231 030 E 231 040 E 231 050 E 231 060 E 231 080 E 231 100 E 231 120 E - 95 - Price each €
231-040 价格&库存
很抱歉,暂时无法提供与“231-040”相匹配的价格&库存,您可以联系我们找货
