234-020
234-020
    RUKO
234-020 数据手册
HSS M C M DIN 371 ISO2 6H Ø1 06 60° L2 HSSE Co 5 Machine taps M dIN 371 hSS and hSSE-Co 5, ground Machine taps with reinforced shank and 35° right-hand spiral flutes for bottoming. L1 Chamfer: type C / 35° right-hand spiral flutes, 2 - 3 threads Thread: metric, dIN ISO 13 flanks: relief-ground Packing unit: individual plastic pack To increase the service life - reduce speed! Cooling while countersinking! Ø2 Steel (N/mm2) < 800 Brass Steel (N/mm2) < 1000 Bronze Steel (N/mm2) < 1200 Plastics Rust-resistant steel Cast iron Aluminium Titanium alloyed Nominal thread size M 2 M 2,5 M 3 M 4 M 5 M 6 M 8 M 10 Nominal thread size M 2 M 2,5 M 3 M 4 M 5 M 6 M 8 M 10 Pitch mm Thread core hole Ø1 mm L1 mm L2 mm Ø2 mm 0,40 0,45 0,50 0,70 0,80 1,00 1,25 1,50 1,60 2,05 2,50 3,30 4,20 5,00 6,80 8,50 45,0 50,0 56,0 63,0 70,0 80,0 90,0 100,0 6,0 7,5 5,0 7,0 8,0 10,0 13,0 15,0 2,8 2,8 3,5 4,5 6,0 6,0 8,0 10,0 800 HSS N/mm² 234 020 234 025 234 030 234 040 234 050 234 060 234 080 234 100 HSSE Co 5 1000 N/mm² 234 020 E 234 025 E 234 030 E 234 040 E 234 050 E 234 060 E 234 080 E 234 100 E HSSE Co 5 1000 N/mm² 234 020 VA 234 025 VA 234 030 VA 234 040 VA 234 050 VA 234 060 VA 234 080 VA 234 100 VA HSS 900 N/mm² 234 020 T 234 025 T 234 030 T 234 040 T 234 050 T 234 060 T 234 080 T 234 100 T HSSE Co 5 1200 N/mm² 234 020 Ef 234 025 Ef 234 030 Ef 234 040 Ef 234 050 Ef 234 060 Ef 234 080 Ef 234 100 Ef PRECISION TOOLS 1 1 1 1 1 1 1 1 183
234-020 价格&库存
很抱歉,暂时无法提供与“234-020”相匹配的价格&库存,您可以联系我们找货
