101026RO
101026RO
    RUKO
    RUKO - 101026RO - Drill Bit Set, Step, Spiral Fluted, HSS, 0.9 ", 1 ", 2 ", 3 Piece - Drill Bit Set,...
101026RO 数据手册
Step drillS the next generation SMooth run. preciSe cut. long life. + up to 4 times longer service life + improved centring with quicker hole drilling + extremely smooth run eliminates 'grabbing' material + Significantly reduced cutting forces + highly efficient chip removal, reduces heat build up + reduced 'feathering' in the hole + Drilling productivity significantly increased + optimal performance in all drilling machines including hand-held drills helix angle point cut the helix angle optimisation leads to reduced axial feed forces, enabling the drilling cycle to be performed significantly faster in less time. the improved point cut geometry facilitates easier centring whilst supporting faster drilling in the workpiece. the new point cut geometry dramatically reduces lateral forces. improved centring / drilling Very smooth run considerably reduced feathering 3-edge Shank cutting edgeS the optimised cutting geometry enables very smooth operating performance. hole roundness and surface finish quality of the hole is significantly improved, avoiding any feathering on the edges. chip Space geoMetry the optimised chip geometry ensures ideal chip and heat removal. the service life of the step drill is substantially improved thanks to the significant reduction in heat development. the ideal balance between optimised cutting and service life is achieved through the step drills special wedge angle. the specially modified cutting geometries facilitates an extremely smooth transition between each of the steps. radial forces are dramatically reduced by up to 80% when drilling. every step on the tool is designed with a special optimised relief, clearance angle, which prevents the edge from breaking out and from catching in the workpiece. the smooth drilling operation of the step drill means there is no 'warping' when drilling thinner materials. reductions in torque forces from the step drill, protect the drilling machine from overload and enable an 'easy to use' hole making solution. the 3-edge shank provides a secure hold within the chuck, eliminating any possibility of slippage. this provides the maximum force transfer to the cutting edges of the tool. ideal for use in hand-held drilling machines. Ø2 C HSSE Co 5 HSS Ø1 118° 90° Step drills HSS and HSSE-Co 5, CBN ground, spiral fluted with split point L1 The CBN ground and spiral flutes guarantee quiet running and high cutting performance. Especially the chip flow is optimized, so even long, non-breaking chips will be removed easily. The optimized chip flow protects the cutting edges and reduces built-up edges and cold weld marks. The cone makes it easier to withdraw the tool from the material. available July 2018 Ø3 Packing unit: in plastic tubes of 1 - Cooling - Adjust speed - Do not press - Step drill is pulled automatically into the plate Steel (N/mm2) < 900 Brass Steel (N/mm2) < 1100 Bronze Steel (N/mm2) < 1300 Plastics Rust-resistant steel Cast iron Aluminium Titanium alloyed Size no. Ø1 - Ø2 mm L1 mm Steps Ø3 mm HSS HSSE Co 5 HSS HSS 0/5 0/9 1 2 3 4 5 6 7 8 9 12 13 18 4,0 - 12,00 4,0 - 12,00 4,0 - 20,00 4,0 - 30,00 6,0 - 38,00 6,0 - 26,75 4,0 - 39,00 6,0 - 32,00 5,0 - 28,00 6,0 - 30,50 6,0 - 37,00 6,0 - 32,00 6,0 - 40,00 6,5 - 32,50 65,0 65,0 75,0 100,0 100,0 75,0 107,0 75,0 69,0 80,0 100,0 76,0 105,0 91,0 5 9 9 14 12 8 13 8 7 9 12 9 16 12 6,0 6,0 8,0 10,0 10,0 10,0 10,0 10,0 10,0 10,0 10,0 10,0 13,0 10,0 101 050-5 101 050-9 101 051 101 052 101 053 101 055 101 056 101 057 101 058 101 098 101 060 101 096 101 097 — — 101 050-9 E 101 051 E 101 052 E — — 101 056 E — — — 101 060 E — — 101 534 E 101 050-5 T 101 050-9 T 101 051 T 101 052 T 101 053 T 101 055 T 101 056 T 101 057 T 101 058 T 101 098 T 101 060 T 101 096 T 101 097 T — 101 050-5 F 101 050-9 F 101 051 F 101 052 F 101 053 F 101 055 F 101 056 F 101 057 F 101 058 F 101 098 F 101 060 F 101 096 F 101 097 F — 1 1 1 1 1 1 1 1 1 1 1 1 1 1 * straight flute Size no. 0/5 0/9 1 2 3 4 5 6 7 8 9 12 13 18 Drilling range Ø mm 4,0 / 6,0 / 8,0 / 10,0 / 12,0 4,0 / 5,0 / 6,0 / 7,0 / 8,0 / 9,0 / 10,0 / 11,0 / 12,0 4,0 / 6,0 / 8,0 / 10,0 / 12,0 / 14,0 / 16,0 / 18,0 / 20,0 4,0 / 6,0 / 8,0 / 10,0 / 12,0 / 14,0 / 16,0 / 18,0 / 20,0 / 22,0 / 24,0 / 26,0 / 28,0 / 30,0 6,0 / 9,0 / 13,0 / 16,0 / 19,0 / 21,0 / 23,0 / 26,0 / 29,0 / 32,0 / 35,0 / 38,0 6,0 / 9,0 / 11,4 (PG7) / 14,0 (PG9) / 17,25 (PG11) / 19,0 (PG13,5) / 21,25 (PG16) / 26,75 (PG21) 4,0 / 6,0 / 12,0 / 15,0 / 18,0 / 21,0 / 24,0 / 27,0 / 30,0 / 33,0 / 36,0 / 39,0 6,0 / 9,0 / 11,2 (R1/8) / 14,5 (R1/4) / 18,2 (R3/8) / 22,3 (R1/2) / 27,9 (R3/4) / 32,0 5,0 / 8,8 (G1/8) / 11,8 (G1/4) / 15,3 (G3/8) / 19,0 (G1/2) / 24,5 (G3/4) / 28,0 6,0 / 9,0 / 12,5 (PG7) / 15,2 (PG9) / 18,6 (PG11) / 20,4 (PG13,5) / 22,5 (PG16) / 28,3 (PG21) / 30,5 6,0 / 9,0 / 12,5 (PG7) / 15,2 (PG9) / 18,6 (PG11) / 20,4 (PG13,5) / 22,5 (PG16) / 26,0 / 28,3 (PG21) / 30,5 / 34,0 / 37,0 (PG29) 6,0 / 9,0 / 12,0 / 16,0 / 20,0 / 22,5 / 25,0 / 28,5 / 32,0 6,0 / 11,0 / 17,0 / 23,0 / 29,0 / 30,0 / 31,0 / 32,0 / 33,0 / 34,0 / 35,0 / 36,0 / 37,0 / 38,0 / 39,0 / 40,0 6,5 / 8,5 / 10,5 / 12,7 / 15,2 (PG9) / 16,2 / 18,6 (PG11) / 20,4 (PG13,5) / 22,5 (PG16) / 25,5 / 28,3 (PG21) / 32,5 HSS HSSE Co 5 C 118° 90° Step drill sets HSS and HSSE-Co 5 in steel case HSS HSS HSS 101 026 E 101 026 T 101 026 F HSS HSS 101 026 F 101 026 T 101 026 101 026 3-piece set of step drills spiral fluted, sizes 0/9, 1, 2 HSSE Co 5 Step drill sets HSS and HSSE-Co 5 in plastic case 101 026 ERO 101 026 TRO 101 026 FRO 101 026 FRO 101 026 RO 101 026 RO 3-piece set of step drills spiral fluted, sizes 0/9, 1, 2 HSSE Co 5 101 026 TRO HSS Step drillS the next generation variationS HSS HSS HSS HSSE Co 5 outstanding performance in: Sheets made from construction steels, high alloyed steel, stainless steel, brass, Perspex®, wood, chrome plated steel, aluminium.
101026RO 价格&库存
很抱歉,暂时无法提供与“101026RO”相匹配的价格&库存,您可以联系我们找货
