102143
102143
    RUKO
102143 数据手册
Taper and deburring countersinkers Taper and deburring countersinkers type D 90° HSS Counters. angle: 90° Shank: Morse taper Cutting edges: 1 Surface: bright Right-hand cutting Because of the CBN deep-ground flutes the cutting edges are extremely sharp. Ideal for burr- and chatter-free deburring and countersinking. Applicable for steel, cast iron, nonferrous and light metals. Best results at low cutting speeds. Nominal Ø d1 mm L Packing unit: in plastic tubes of 1 Total length L mm 16,0 20,0 25,0 30,0 40,0 50,0 1.5 92,0 107,0 110,0 114,0 145,0 152,0 Shank MT Article no. MT 1 MT 2 MT 2 MT 2 MT 3 MT 3 102 531 102 532 102 533 102 534 102 535 102 536 Price / each € d1 Hand deburrer DIN 335 type C 90° HSS, CBN ground Packing unit: in plastic tubes of 1 Description Article no. Hand deburrer with countersinker Ø 12,4 mm Hand deburrer with countersinker Ø 15,0 mm Hand deburrer with countersinker Ø 16,5 mm Hand deburrer with countersinker Ø 20,5 mm Hand deburrer with countersinker Ø 25,0 mm 102 143 102 144 102 145 102 146 102 147 Price / each € No. 102 143 Universal handle to fit countersinkers Packing unit: in plastic tubes of 1 Description Article no. Universal handle for countersinker with 8,0 mm shank Ø Universal handle for countersinker with 10,0 mm shank Ø Universal handle for countersinker with 1/4" hexagon socket 102 148 102 149 102 320 Price / each € No. 102 148 Taper and deburring countersinker Bits 90° HSS Counters. angle: 90° 1/4" hexagon Shank: Cutting edges: 3 Surface: bright Right-hand cutting Rapid tool-changing thanks to hexagonal bit holder. Ideal for burr- and chatter-free deburring and countersinking. Applicable for steel, cast iron, non-ferrous and light metals. Best results at low cutting speeds. No. 102 320 Countersinker nominal Ø d3 d1 mm mm 6,3 8,3 10,4 12,4 16,5 20,5 1,5 2,0 2,5 2,8 3,2 3,5 Total length L mm Shank hexagon 31,0 31,0 34,0 35,0 40,0 41,0 1/4" 1/4" 1/4" 1/4" 1/4" 1/4" Countersinkings as per DIN 74 AF BF M3 M4 M5 M6 M8 M 10 Article no. 102 313 102 314 102 315 102 316 102 317 102 318 - 75 - Price each € L Packing unit: in plastic tubes of 1 d3 d1
102143 价格&库存
很抱歉,暂时无法提供与“102143”相匹配的价格&库存,您可以联系我们找货
