201 042
201 042
    RUKO
    RUKO  201 042  DRILL BIT, N HSS, 4.2MM
201 042 数据手册
Twist drills Twist drills DIN 338 type N HSS rolled 1.1 Point cut: Point angle: Helix angle: Ø tolerance: Surface: helical point 118° 20-30° h8 black, vacuum metalized Right-hand cutting Highly efficient standard drill suitable for all usual drilling work in all normal materials. High security against fracture. Applications: for steel and cast-steel alloyed and unalloyed up to approx. 900 N/mm² strength, grey cast, malleable cast iron, diecast metal, iron sinter, nickel-silver, graphite cast iron, short-chipping aluminium alloys, bronze and brass. Packing unit: Ø 0,30 mm up to 10,40 mm in plastic box of 10 Ø 10,50 mm up to 16,00 mm in plastic box of 5 Ø 16,50 mm up to 20,00 mm in plastic box of 1 Ø mm Total length mm Flute length mm Article no. 0,30 0,40 0,50 0,60 0,70 0,80 0,90 1,00 1,10 1,20 1,25 1,30 1,40 1,50 1,60 1,70 1,75 1,80 1,90 2,00 2,10 2,20 2,25 2,30 2,40 2,50 2,60 2,70 2,75 2,80 2,90 3,00 3,10 3,20 3,25 3,30 3,40 3,50 3,60 3,70 3,75 3,80 3,90 4,00 4,10 4,20 4,25 4,30 4,40 4,50 4,60 4,70 19 20 22 24 28 30 32 34 36 38 38 38 40 40 43 43 43 46 46 49 49 53 53 53 57 57 57 61 61 61 61 61 65 65 65 65 70 70 70 70 70 75 75 75 75 75 75 80 80 80 80 80 3 5 6 7 9 10 11 12 14 16 16 16 18 18 20 20 20 22 22 24 24 27 27 27 30 30 30 33 33 33 33 33 36 36 36 36 39 39 39 39 39 43 43 43 43 43 43 47 47 47 47 47 201 003 201 004 201 005 201 006 201 007 201 008 201 009 201 010 201 011 201 012 201 0125 201 013 201 014 201 015 201 016 201 017 201 0175 201 018 201 019 201 020 201 021 201 022 201 0225 201 023 201 024 201 025 201 026 201 027 201 0275 201 028 201 029 201 030 201 031 201 032 201 0325 201 033 201 034 201 035 201 036 201 037 201 0375 201 038 201 039 201 040 201 041 201 042 201 0425 201 043 201 044 201 045 201 046 201 047 Price each € - 26 - Ø mm Total length mm Flute length mm Article no. 4,75 4,80 4,90 5,00 5,10 5,20 5,25 5,30 5,40 5,50 5,60 5,70 5,75 5,80 5,90 6,00 6,10 6,20 6,25 6,30 6,40 6,50 6,60 6,70 6,75 6,80 6,90 7,00 7,10 7,20 7,25 7,30 7,40 7,50 7,60 7,70 7,75 7,80 7,90 8,00 8,10 8,20 8,25 8,30 8,40 8,50 8,60 8,70 8,75 8,80 8,90 9,00 80 86 86 86 86 86 86 86 93 93 93 93 93 93 93 93 101 101 101 101 101 101 101 101 101 109 109 109 109 109 109 109 109 109 117 117 117 117 117 117 117 117 117 117 117 117 125 125 125 125 125 125 47 52 52 52 52 52 52 52 57 57 57 57 57 57 57 57 63 63 63 63 63 63 63 63 63 69 69 69 69 69 69 69 69 69 75 75 75 75 75 75 75 75 75 75 75 75 81 81 81 81 81 81 201 0475 201 048 201 049 201 050 201 051 201 052 201 0525 201 053 201 054 201 055 201 056 201 057 201 0575 201 058 201 059 201 060 201 061 201 062 201 0625 201 063 201 064 201 065 201 066 201 067 201 0675 201 068 201 069 201 070 201 071 201 072 201 0725 201 073 201 074 201 075 201 076 201 077 201 0775 201 078 201 079 201 080 201 081 201 082 201 0825 201 083 201 084 201 085 201 086 201 087 201 0875 201 088 201 089 201 090 Price each € Twist drills Twist drills DIN 338 type N HSS rolled Point cut: Point angle: Helix angle: Ø tolerance: Surface: helical point 118° 20-30° h8 black, vacuum metalized Right-hand cutting Highly efficient standard drill suitable for all usual drilling work in all normal materials. High security against fracture. Applications: for steel and cast-steel alloyed and unalloyed up to approx. 900 N/mm² strength, grey cast, malleable cast iron, diecast metal, iron sinter, nickel-silver, graphite cast iron, short-chipping aluminium alloys, bronze and brass. Packing unit: Ø 0,30 mm up to 10,40 mm in plastic box of 10 Ø 10,50 mm up to 16,00 mm in plastic box of 5 Ø 16,50 mm up to 20,00 mm in plastic box of 1 Ø mm Total length mm Flute length mm Article no. 9,10 9,20 9,25 9,30 9,40 9,50 9,60 9,70 9,75 9,80 9,90 10,00 10,10 10,20 10,30 10,40 10,50 10,60 10,70 10,80 10,90 11,00 11,10 11,20 11,30 11,40 11,50 11,60 125 125 125 125 125 125 133 133 133 133 133 133 133 133 133 133 133 142 142 142 142 142 142 142 142 142 142 142 81 81 81 81 81 81 87 87 87 87 87 87 87 87 87 87 87 94 94 94 94 94 94 94 94 94 94 94 201 091 201 092 201 0925 201 093 201 094 201 095 201 096 201 097 201 0975 201 098 201 099 201 100 201 101 201 102 201 103 201 104 201 105 201 106 201 107 201 108 201 109 201 110 201 111 201 112 201 113 201 114 201 115 201 116 Price each € - 27 - Ø mm Total length mm Flute length mm Article no. 11,70 11,80 11,90 12,00 12,10 12,20 12,30 12,40 12,50 12,60 12,70 12,80 12,90 13,00 13,50 14,00 14,50 15,00 15,50 16,00 16,50 17,00 17,50 18,00 18,50 19,00 19,50 20,00 142 142 151 151 151 151 151 151 151 151 151 151 151 151 160 160 169 169 178 178 184 184 191 191 198 198 205 205 94 94 101 101 101 101 101 101 101 101 101 101 101 101 108 108 114 114 120 120 125 125 130 130 135 135 140 140 201 117 201 118 201 119 201 120 201 121 201 122 201 123 201 124 201 125 201 126 201 127 201 128 201 129 201 130 201 135 201 140 201 145 201 150 201 155 201 160 201 165 201 170 201 175 201 180 201 185 201 190 201 195 201 200 Price each € 1.1
201 042 价格&库存
很抱歉,暂时无法提供与“201 042”相匹配的价格&库存,您可以联系我们找货
