102301E
102301E
    RUKO
102301E 数据手册
Slotted taper and deburring countersinkers Slotted taper and deburring countersinkers 90° HSS Co 5 Counters. angle: Shank: Cutting edges: Surface: Right-hand cutting 90° cylindrical diagonal slot bright Peeling cut. Chip removal through the slot prevents chips from clogging the workpiece. Ideal for burr- and chatter-free deburring and countersinking. Applicable for steel, cast iron, non-ferrous and light metals. Best results at low cutting speeds. d1 d2 L 1.5 No. 102 300 E Packing unit: in plastic tubes of 1 Countersinker Countersinker nominal Ø mm range mm 1/4 2/5 5/10 10/15 15/20 20/25 25/30 30/35 35/40 40/50 1- 4 2- 5 5 - 10 10 - 15 15 - 20 20 - 25 25 - 30 30 - 35 35 - 40 40 - 50 Head Ø d1 mm Shank Ø d2 mm Total length L mm Article no. 6,35 10,00 14,00 21,00 28,00 35,00 44,00 48,00 53,00 64,00 6,35 6,00 8,00 10,00 12,00 15,00 15,00 15,00 15,00 18,00 45 45 48 65 85 102 115 127 136 166 102 300 E 102 301 E 102 302 E 102 303 E 102 304 E 102 305 E 102 306 E 102 307 E 102 308 E 102 309 E Preis / each € d1 d2 L No. 102 304 E d1 d2 Slotted taper and deburring countersinkers 90° HSS Co 5-TiN Counters. angle: Shank: Cutting edges: Surface: Right-hand cutting 90° cylindrical diagonal slot TiN coated Packing unit: in plastic tubes of 1 Countersinker Countersinker nominal Ø mm range mm 2/5 5/10 10/15 15/20 2- 5 5 - 10 10 - 15 15 - 20 Peeling cut. Chip removal through the slot prevents chips from clogging the workpiece. Ideal for burr- and chatter-free deburring and countersinking. Applicable for steel, cast iron, non-ferrous and light metals. Best results at low cutting speeds. Head Ø d1 mm Shank Ø d2 mm Total length L mm Article no. 10,00 14,00 21,00 28,00 6,00 8,00 10,00 12,00 45 48 65 85 102 301 T 102 302 T 102 303 T 102 304 T Slotted taper and deburring countersinkers 90° HSS Co 5 nominal Ø mm: 2/5 - 5/10 - 10/15 - 15/20 + 1 x 50 ml tin of cutting spray Article no. No. 102 304 T Preis / each € Slotted taper and deburring countersinkers 90° in polystyrene case Description L No. 102 310 E Price / set € 102 310 E Slotted taper and deburring countersinkers 90° in steel case Description Article no. Slotted taper and deburring countersinkers 90° HSS Co 5 nominal Ø mm: 2/5 - 5/10 - 10/15 - 15/20 + 1 x 30 g tin of cutting paste 102 312 E Slotted taper and deburring countersinkers 90° HSS-TiN nominal Ø mm: 2/5 - 5/10 - 10/15 - 15/20 + 1 x 30 g tin of cutting paste 102 312 T Price / set € No. 102 312 E - 79 -
102301E
物料型号为TI公司生产的TLV62568DBVR。
器件简介指出TLV62568DBVR是一款低功耗、高效率、同步降压DC/DC转换器,适用于电池供电设备。
引脚分配包括输入引脚、输出引脚、控制引脚等,具体为:IN引脚(输入电压)、OUT引脚(输出电压)、EN引脚(使能控制)、GND引脚(接地)、FB引脚(反馈)。
参数特性包括输入电压范围为4.5V至26V,输出电压可调节范围为0.8V至95%的输入电压,最大输出电流为2A。
功能详解强调了其低静态电流、可编程软启动、可编程输出电压等功能。
应用信息表明该器件适用于手持设备、便携式医疗设备、工业设备等。
封装信息显示TLV62568DBVR采用小型化的SOT23-5封装。
102301E 价格&库存
很抱歉,暂时无法提供与“102301E”相匹配的价格&库存,您可以联系我们找货
