106035
106035
    RUKO
106035 数据手册
Hole saws HSS bi-metal hole saws, with varied toothing Cutting edges: Jacket: Cutting depth: Cutting teeth: Right-hand cutting HSS special steel up to max. 38 mm (1 1/2") varied toothing Suitable for unalloyed steel (up to 700 N/mm² strength), non-ferrous and light metals, plastics, plasterboard and light building boards, fibreboard, plywood and wood. Packing unit: individual carton 1.9 Ø mm 14 16 17 19 20 21 22 24 25 27 28 29 30 32 33 35 36 37 38 40 41 43 44 46 48 51 52 54 55 57 59 60 63 64 65 67 68 70 73 76 79 83 86 89 92 95 98 102 105 108 111 114 121 127 140 152 160 168 177 210 Ø inch 9/16 Through dimensions PG 5/8 ~ PG 9 3/4 ~ PG 11 7/8 15/16 1 1 1/16 1 3/32 1 1/8 1 3/16 1 1/4 ~ PG 13,5 ~ PG 16 ~ PG 21 1 3/8 1 1/2 1 5/8 1 11/16 1 3/4 1 13/16 1 7/8 2 2 1/8 Tube dimensions inch 3/8 1/2 3/4 1 PG 29 1 1/4 ~ PG 36 1 1/2 PG 42 2 1/4 2 3/8 2 1/2 ~ PG 48 2 2 5/8 2 3/4 2 7/8 3 3 1/8 3 1/4 3 3/8 3 1/2 3 5/8 3 3/4 3 7/8 4 4 1/4 4 3/8 4 1/2 4 3/4 5 5 1/2 6 6 5/16 6 5/8 8 9/32 2 1/2 3 3 1/2 4 For arbor holders Article no. A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 106 014 106 016 106 017 106 019 106 020 106 021 106 022 106 024 106 025 106 027 106 028 106 029 106 030 106 032 106 033 106 035 106 036 106 037 106 038 106 040 106 041 106 043 106 044 106 046 106 048 106 051 106 052 106 054 106 055 106 057 106 059 106 060 106 063 106 064 106 065 106 067 106 068 106 070 106 073 106 076 106 079 106 083 106 086 106 089 106 092 106 095 106 098 106 102 106 105 106 108 106 111 106 114 106 121 106 127 106 140 106 152 106 160 106 168 106 177 106 200 - 186 - Price / each € Characteristics: • High rotational precision • Sturdy construction • Hole saw and shank in two parts, so hole saws of different diameters can be exchanged and fitted more rapidly • A1, A2, A5, A6 arbor with hexagonal shank and A7 arbor with SDS-plus shank • A4 arbor with cylindrical shank • Positive chipping and cutting angles ensure more aggressive cutting • Varied toothing ensures: - smoother cutting - less effort - less vibration and heat production during cutting - up to three times longer tool life • The HSS teeth are welded onto a jacket of special steel • Good chip removal • Slots in the jacket side assist removal of cutouts • Exchangeable centring drill • Unsuitable for percussion-drill operation • Only slight pressure required to start drilling • Drill with light, steady pressure • Avoid pendulum movements while drilling • Observe table of drilling speeds • Use prescribed cooling agents RUKO HSS bi-metal hole saws can be used in hand and pillar drills. When employing pillar drills, use manual advance only. Also suitable for other makes of drill. Prices without arbor.
106035 价格&库存
很抱歉,暂时无法提供与“106035”相匹配的价格&库存,您可以联系我们找货
