101351
101351
    OTHER
101351 数据手册
COMPETENCE IN PRECISION STEP DRILLS AND QUALITY Step drills Product information 1.4 The flutes of new RUKO high performance step drills are CBN ground from the solid hardened form. Because CBN (cubical boron nitride) is a much harder abrasive than even silicium carbide or corundum, a better and sharper cutting edge is achieved - without burrs. And, with higher dimensional precision the drills will last considerably longer while maintaining the precise process tolerances. 1. CBN ground spiral flute 1. CBN ground spiral flutes enable very sharp and burr-free cutting edges compared to the ordinary milled flutes. Especially the chip flow is optimized, so even long, non-breaking chips will be removed easily. The optimized chip flow protects the cutting edges and reduces built-up edges and cold weld marks. Due to these special features, cutting performance and tool life are extended significantly. 2. Each step has a radially adjusted relief produced by CBN grinding that relates directly to the diameter of the step. This means the cutting edge is always the highest point of the diameter. 3. Each step is axially CBN relief ground. This means the cutting edge is always the highest point of the axial cutting axis. 4. The cutting edge of each step has relief angle. This means the cutting edge is also the highest point in advance direction. 5. The CBN ground bit ensures centering and spot-drilling even in thin-walled material. 2. Radially adjusted relief produced by CBN grinding Product application 1. The ideal tool for sheet metal working in the following sectors of industries: electrical (size 4 + size 9), sanitary engineering and heating technics (size 6 + size 7) or automotive, mechanical engineering, aviation (size 0/5, size 0/9, size 1, size 2, size 3, size 5) and switching systems (size 0/9k, size 1k, size 2k) up to 2 mm sheet thickness. 3. Axially relief produced by CBN grinding 2. This tough tool is suitable for all standard industrial materials: nonferrous metal, special steel, thermoplastics and duroplastics as well as sheet metals up to 4 mm thickness. 3. This durable and versatile tool will center, spot-drill, bore and debur - all in one smooth, high performance working cycle. 4. By using RUKO cutting spray or RUKO cutting paste tool life will be considerably prolonged. 4. CBN ground relief angle 5. CBN ground bit with split point DIN 1412 C - 56 - Step drills Step drills HSS, CBN ground, spiral fluted with split point Point cut: Point- / Step angle: Ø-tolerance: Surface: Right hand cutting work´s specification with split point DIN 1412 C 118° / 90° work´s specification bright The CBN ground and spiral flutes guarantee quiet running and high cutting performance. Especially the chip flow is optimized, so even long, non-breaking chips will be removed easily. The optimized chip flow protects the cutting edges and reduces built-up edges and cold weld marks. The cone makes it easier to withdraw the tool from the material. Packing unit: in plastic tubes of 1 Size no. 0/5 0/9 1 2 3 4 5 6 7 8 9 10 11 12 13* Drilling range mm Steps 65 65 75 100 100 75 107 75 69 80 100 54 65 76 105 5 9 9 14 12 8 13 8 7 9 12 5 7 9 16 Shank-Ø mm 6 6 8 10 10 10 10 10 10 10 10 6 10 10 13 8,0 mm 10,0 mm 12,0 mm Article no. Ø mm Point- / Step angle: Ø-tolerance: Surface: Right hand cutting work´s specification with split point DIN 1412 C 118° / 90° work´s specification bright Packing unit: in plastic tubes of 1 Size no. 0/9 1 2 9 Drilling range mm Total length mm 4,0 mm 6,0 mm 8,0 mm 10,0 mm 12,0 mm 14,0 mm 16,0 mm 18,0 mm 20,0 mm No. 1 4,0 - 12,00 4,0 - 20,00 4,0 - 30,00 6,0 - 37,00 65 75 100 100 9 9 14 12 Shank-Ø mm 6 8 10 10 Article no. No. 2 Ø mm The CBN ground and spiral flutes guarantee quiet running and high cutting performance. Especially the chip flow is optimized, so even long, non-breaking chips will be removed easily. The optimized chip flow protects the cutting edges and reduces built-up edges and cold weld marks. The cone makes it easier to withdraw the tool from the material. Steps 4,0 mm 6,0 mm 8,0 mm 10,0 mm 12,0 mm 14,0 mm 16,0 mm 18,0 mm 20,0 mm 22,0 mm 24,0 mm 26,0 mm 28,0 mm 30,0 mm Ø mm 101 050-5 101 050-9 101 051 101 052 101 053 101 055 101 056 101 057 101 058 101 098 101 060 101 094 101 095 101 096 101 097 6,0 mm 9,0 mm 13,0 mm 16,0 mm 19,0 mm 21,0 mm 23,0 mm 26,0 mm 29,0 mm 32,0 mm 35,0 mm 38,0 mm No. 3 Ø mm 6,0 mm 9,0 mm 11,4 mm 14,0 mm 17,25 mm 19,0 mm 21,25 mm 26,75 mm Point- / Step angle: Ø-tolerance: Surface: Right hand cutting work´s specification with split point DIN 1412 C 118° / 90° work´s specification titanium-nitride coated Packing unit: in plastic tubes of 1 101 050-9 E 101 051 E 101 052 E 101 060 E Size no. Drilling range mm Total length mm Steps Shank-Ø mm Article no. 0/9 1 2 9 4,0 - 12,00 4,0 - 20,00 4,0 - 30,00 6,0 - 37,00 65 75 100 100 9 9 14 12 6 8 10 10 101 050-9 T 101 051 T 101 052 T 101 060 T * straight fluted - 57 - 7 9 11 13,5 16 21 Ø mm 4,0 mm 6,0 mm 9,0 mm 12,0 mm 15,0 mm 18,0 mm 21,0 mm 24,0 mm 27,0 mm 30,0 mm 33,0 mm 36,0 mm 39,0 mm Price / each € The CBN ground and spiral flutes guarantee quiet running and high cutting performance. Especially the chip flow is optimized, so even long, non-breaking chips will be removed easily. The optimized chip flow protects the cutting edges and reduces built-up edges and cold weld marks. The cone makes it easier to withdraw the tool from the material. PG No. 4 Ø mm R 6,0 mm 9,0 mm 11,2 mm 14,5 mm 18,2 mm 22,3 mm 27,9 mm 32,0 mm Step drills HSS-TiN, CBN ground, spiral fluted with split point Point cut: 1.4 No. 0/9 Price / each € Step drills HSS Co 5, CBN ground, spiral fluted with split point Point cut: Ø mm 4,0 mm 5,0 mm 6,0 mm 7,0 mm 8,0 mm 9,0 mm 10,0 mm 11,0 mm 12,0 mm 6,0 mm No. 0/5 Total length mm 4,0 - 12,00 4,0 - 12,00 4,0 - 20,00 4,0 - 30,00 6,0 - 38,00 6,0 - 26,75 4,0 - 39,00 6,0 - 32,00 5,0 - 28,00 6,0 - 30,50 6,0 - 37,00 4,8 - 10,65 6,0 - 25,00 6,0 - 32,00 6,0 - 40,00 Ø mm 4,0 mm No. 5 No. 6 Ø mm 4,0 mm 6,0 mm 8,0 mm 10,0 mm 12,0 mm 14,0 mm 16,0 mm 18,0 mm 20,0 mm 22,0 mm 24,0 mm 26,0 mm 28,0 mm 30,0 mm Ø mm 4,0 mm 6,0 mm 8,0 mm 10,0 mm 12,0 mm 14,0 mm 16,0 mm Price / each € 18,0 mm 20,0 mm No. 1 No. 2 1/8 1/4 3/8 1/2 3/4 Step drills Step drills HSS, CBN ground, spiral fluted with split point Point cut: 1.4 work´s specification with split point DIN 1412 C Point angel: 118° Step angle: 90° Ø-Tolerance: work´s specification Surface: bright Right-hand cutting Packing unit: in plastic tubes of 1 Size no. 0/9k 1k 2k Drilling range mm Total length mm 4,0 - 12,00 4,0 - 20,00 4,0 - 30,00 48 58 72 Ø mm 4,0 mm 5,0 mm 6,0 mm 7,0 mm 8,0 mm 9,0 mm 10,0 mm 11,0 mm 12,0 mm The CBN ground and spiral flutes guarantee quiet running and high cutting performance. Especially the chip flow is optimized, so even long, non-breaking chips will be removed easily. The optimized chip flow protects the cutting edges and reduces built-up edges and cold weld marks. The cone makes it easier to withdraw the tool from the material. Step height 2 mm. Ideal to produce switchboards. Steps 9 9 14 Shank-Ø mm 6 8 10 Article no. Ø mm 4,0 mm 6,0 mm 8,0 mm 10,0 mm 12,0 mm 14,0 mm 16,0 mm 18,0 mm No. 0/9k 20,0 mm Price / each € Ø mm 4,0 mm 6,0 mm 8,0 mm 10,0 mm 12,0 mm 14,0 mm 16,0 mm 18,0 mm 20,0 mm 22,0 mm 24,0 mm 26,0 mm 28,0 mm 30,0 mm 101 061 101 062 101 063 No. 1k Step drills HSS, CBN ground, spiral fluted with split point for metric cable connections, through holes after DIN/EN 50262 Point cut: work´s specification with split point DIN 1412 C Point angel: 118° Step angle: 90° Ø-Tolerance: work´s specification Surface: bright Right-hand cutting Packing unit: in plastic tubes of 1 Ø mm 6,5 mm The CBN ground and spiral flutes guarantee quiet running and high cutting performance. Especially the chip flow is optimized, so even long, non-breaking chips will be removed easily. The optimized chip flow protects the cutting edges and reduces built-up edges and cold weld marks. The cone makes it easier to withdraw the tool from the material. Step height 4 mm. Size no. Drilling range mm Total length mm Steps Shank-Ø mm Article no. 15 17 6,5 - 32,5 6,5 - 40,5 79 96 9 11 10 10 101 092 101 090 Price / each € 8,5 mm 12,5 mm 16,5 mm 20,5 mm 25,5 mm 29,0 mm 32,5 mm Ø mm 6,5 mm 8,5 mm 10,5 mm 12,5 mm 16,5 mm work´s specification with split point DIN 1412 C Point angle: 118° Step angel: 90° Ø-Tolerance: work´s specification Surface: bright Right-hand cutting Packing unit: in plastic tubes of 1 20,5 mm No. 15 25,5 mm 29,0 mm 32,5 mm 36,5 mm 40,5 mm Step drills HSS, CBN ground, spiral fluted with split point for metric cable connections, core holes after DIN/EN 60423 Point cut: No. 2k 10,5 mm Ø mm No. 17 5,3 mm 7,0 mm 9,0 mm 10,5 mm The CBN ground and spiral flutes guarantee quiet running and high cutting performance. Especially the chip flow is optimized, so even long, non-breaking chips will be removed easily. The optimized chip flow protects the cutting edges and reduces built-up edges and cold weld marks. The cone makes it easier to withdraw the tool from the material. Step height 4 mm. 14,5 mm 18,5 mm 23,5 mm Ø mm 27,0 mm 5,3 mm 7,0 mm 9,0 mm 10,5 mm 30,5 mm 14,5 mm 18,5 mm 23,5 mm 27,0 mm 30,5 mm No. 14 Size no. Drilling range mm Total length mm Steps Shank-Ø mm Article no. 14 16 5,3 - 30,5 5,3 - 38,5 79 96 9 11 10 10 101 093 101 091 34,5 mm 38,5 mm Price / each € No. 16 - 58 - Step drills Table of application for step drills HSS, HSS Co 5, HSS-TiN, CBN ground Size No. 0/5 No. 0/9 No. 1 No. 2 No. 3 No. 4 No. 5 No. 6 No. 7 No. 8 No. 9 No. 10 No. 11 No. 12 No. 13 No. 14 No. 15 No. 16 No. 17 Ø mm Description for metric hole diameters Ø 6,0 mm Ø 8,0 mm Ø 10,0 mm Ø 12,0 mm Ø 4,0 mm Ø 11,0 mm Ø 5,0 mm Ø 12,0 mm Ø 6,0 mm Ø 7,0 mm Ø 8,0 mm Ø 9,0 mm Ø 10,0 mm Ø 4,0 mm Ø 18,0 mm Ø 6,0 mm Ø 20,0 mm Ø 8,0 mm Ø 10,0 mm Ø 12,0 mm Ø 14,0 mm Ø 16,0 mm Ø 4,0 mm Ø 18,0 mm Ø 6,0 mm Ø 20,0 mm Ø 8,0 mm Ø 22,0 mm Ø 10,0 mm Ø 24,0 mm Ø 12,0 mm Ø 26,0 mm Ø 14,0 mm Ø 16,0 mm Ø 28,0 mm Ø 30,0 mm Ø 6,0 mm Ø 26,0 mm Ø 9,0 mm Ø 29,0 mm Ø 13,0 mm Ø 32,0 mm Ø 16,0 mm Ø 35,0 mm Ø 19,0 mm Ø 38,0 mm Ø 21,0 mm Ø 23,0 mm PG 7 Ø 11,4 mm PG 9 PG 11 PG 13,5 PG 16 PG 21 Ø 14,0 mm Ø 17,25 mm Ø 19,0 mm Ø 21,25 mm Ø 26,75 mm Ø 4,0 mm Ø 24,0 mm Ø 6,0 mm Ø 27,0 mm Ø 9,0 mm Ø 30,0 mm Ø 12,0 mm Ø 33,0 mm Ø 15,0 mm Ø 36,0 mm R 1/8" Ø 11,2 mm R 1/4" Ø 14,5 mm R 3/8" Ø 18,2 mm R 1/2" Ø 22,3 mm R 3/4" Ø 27,9 mm G 1/8" Ø 8,8 mm G 1/4" Ø 11,8 mm G 3/8" Ø 15,3 mm G 1/2" Ø 19 mm G 3/4" Ø 24,5 mm for metric hole diameters Ø mm PG 6,0 mm 9,0 mm 12,5 mm 15,2 mm 18,6 mm 20,4 mm 22,5 mm for metric hole diameters for metric hole diameters for steel conduit threads (core holes) for pipe threads (core holes) for steel conduit threads (through holes) PG 11 Ø 18,6 mm PG 13,5 Ø 20,4 mm PG 16 Ø 22,5 mm PG 21 Ø 28,3 mm PG 7 Ø 12,5 mm PG 9 Ø 15,2 mm PG 11 Ø 18,6 mm PG 13,5 Ø 20,4 mm PG 16 Ø 22,5 mm PG 21 Ø 28,3 mm 3/4 Ø mm PG 7 9 11 13,5 16 26,0 mm 28,3 mm 21 30,5 mm 34,0 mm 37,0 mm 29 6,4 mm No. 9 7,2 mm 9,6 mm 10,65 mm PG 29 Ø 37 mm Ø mm 6,0 mm 9,0 mm 12,0 mm 16,0 mm Ø 6,4 mm Ø 7,2 mm Ø 9,6 mm Ø 10,65 mm Ø 6,0 mm Ø 9,0 mm Ø 12,0 mm Ø 16,0 mm Ø 20,0 mm Ø 22,5 mm Ø 25,0 mm Ø 6,0 mm Ø 28,5 mm Ø 9,0 mm Ø 32,0 mm Ø 12,0 mm Ø 16,0 mm Ø 20,0 mm Ø 22,5 mm Ø 25,0 mm Ø 6,0 mm Ø 32,0 mm Ø 39,0 mm Ø 11,0 mm Ø 33,0 mm Ø 40,0 mm Ø 17,0 mm Ø 34,0 mm Ø 29,0 mm Ø 36,0 mm Ø 30,0 mm Ø 31,0 mm Ø 37,0 mm Ø 38,0 mm M6 Ø 5,3 mm M 32 Ø 30,5 mm M8 Ø 7,0 mm M 10 Ø 9,0 mm M6 Ø 6,5 mm M 32 Ø 32,5 mm M8 Ø 8,5 mm M6 Ø 5,3 mm M 32 Ø 30,5 mm M8 Ø 7,0 mm M 40 Ø 38,5 mm M 10 Ø 9,0 mm M6 Ø 6,5 mm M 32 Ø 32,5 mm M8 Ø 8,5 mm M 40 Ø 40,5 mm M 10 Ø 10,5 mm for metric hole diameters with high steps 1/2 24,5 mm 6,0 mm 9,0 mm 12,5 mm 15,2 mm 18,6 mm 20,4 mm 22,5 mm 4,8 mm Ø 4,8 mm for metric hole diameters with high steps 3/8 19,0 mm 28,3 mm 21 30,5 mm Ø mm PG 9 Ø 15,2 mm for blind rivets M3 - M4 - M5 - M6 - M8 15,3 mm 7 9 11 13,5 16 Ø 18,0 mm Ø 21,0 mm Ø 39,0 mm PG 7 Ø 12,5 mm for steel conduit threads (through holes) 1/8 1/4 No. 7 No. 8 for metric hole diameters for pipe threads (external Ø, through holes) 8,8 mm 11,8 mm 28,0 mm Ø 4,0 mm for metric hole diameters G 5,0 mm No. 10 20,0 mm 22,5 mm 25,0 mm for metric hole diameters and large diameters Ø 23,0 mm Ø 35,0 mm Ø mm 6,0 mm 9,0 mm 12,0 mm for metric cable connections, core holes after DIN/EN 60423 M 12 Ø 10,5 mm M 16 Ø 14,5 mm M 20 Ø 18,5 mm M 25 Ø 23,5 mm 16,0 mm 20,0 mm 22,5 mm 25,0 mm 28,5 mm 32,0 mm for metric cable connections, through holes after DIN/EN 50262 M 10 Ø 10,5 mm M 12 Ø 12,5 mm M 16 Ø 16,5 mm M 20 Ø 20,5 mm M 25 Ø 25,5 mm for metric cable connections, core holes after DIN/EN 60423 M 12 Ø 10,5 mm M 16 Ø 14,5 mm M 20 Ø 18,5 mm No. 11 M 25 Ø 23,5 mm Ø mm 6,0 mm 11,0 mm 17,0 mm 23,0 mm 29,0 mm 30,0 mm 31,0 mm 32,0 mm 33,0 mm 34,0 mm 35,0 mm 36,0 mm 37,0 mm 38,0 mm 39,0 mm 40,0 mm No. 12 for metric cable connections, through holes after DIN/EN 50262 M 12 Ø 12,5 mm M 16 Ø 16,5 mm M 20 Ø 20,5 mm M 25 Ø 25,5 mm No. 13 - 59 - 1.4 Step drills Step drills bit HSS, CBN ground, spiral fluted with split point Point cut: 1.4 work´s specification with split point DIN 1412 C Point angle: 118° Step angle: 90° Ø-tolerance: work´s specification Surface: bright Shank: 6,35 x 27 mm Right hand cutting Ø mm 4,0 mm 5,0 mm 6,0 mm 7,0 mm 8,0 mm 9,0 mm 10,0 mm 11,0 mm The CBN ground and spiral flutes guarantee quiet running and high cutting performance. Especially the chip flow is optimized, so even long, non-breaking chips will be removed easily. The optimized chip flow protects the cutting edges and reduces built-up edges and cold weld marks. The cone makes it easier to withdraw the tool from the material. 12,0 mm Ø mm 4,0 mm 6,0 mm 8,0 mm 10,0 mm Packing unit: in plastic tubes of 1 12,0 mm 14,0 mm No. 0/9 16,0 mm 18,0 mm 20,0 mm Size no. Drilling range mm Total length mm Steps Shank hexagon Article no. 0/9 1 2 4,0 - 12,0 4,0 - 20,0 4,0 - 30,0 72 81 105 9 9 14 1/4" 101 050-9H 101 051 H 101 052 H 1/4" 1/4" Ø mm Price / each € 4,0 mm 6,0 mm 8,0 mm 10,0 mm 12,0 mm 14,0 mm 16,0 mm 18,0 mm 20,0 mm 22,0 mm 24,0 mm 26,0 mm 28,0 mm 30,0 mm Emphasised articles are new additions. No. 1 Ø inch No. 2 3/16" 1/4" 5/16" Step drills HSS, inch size, CBN ground, with split point Point cut: work´s specification with split point DIN 1412 C Point angle: 118° Step angle: 90° Ø-tolerance: work´s specification Surface: bright Right hand cutting 3/8" 7/16" 1/2" The CBN ground flutes guarantee quiet running and high cutting performance. The cone makes it easier to withdraw the tool from the material. Ø inch 1/8" 5/32" 3/16" 7/32" 1/4" 9/32" 5/16" 11/32" 3/8" 13/32" 7/16" 15/32" 1/2" No. 1 Ø inch 1/4" 5/16" 3/8" 7/16" 1/2" 9/16" 5/8" 3/4" 1 1/16" Packing unit: in plastic tubes of 1 Size no. 1 2 3 4 5 6 7 8 9 Drilling range inch 3/16 - 1/2 - 1/2 1/4 - 3/4 3/16 - 7/8 1/2 - 1 7/8 - 1 3/8 3/8 - 1/2 7/8 7/8 - 1 1/8 1/8 Total length inch Steps Shank Ø inch Article no. 3 1/8 3 1/8 2 3/4 3 1/4 3 1/4 3 1/4 1 7/8 2 19/32 3 7/64 6 13 9 12 9 5 2 1 2 1/4 101 701 101 702 101 703 101 704 101 705 101 706 101 707 101 708 101 709 1/4 3/8 3/8 3/8 3/8 1/4 3/8 3/8 Price / each € No. 2 Ø inch 3/16" 1/4" 5/16" 3/8" 7/16" 1/2" 9/16" 5/8" 11/16" 3/4" 13/16" 7/8" No. 3 Ø inch 1/2" 9/16" 5/8" 11/16" 3/4" 13/16" 7/8" 15/6" 1" No. 4 No. 5 - 60 - Step drills Step drills HSS-TiN, inch size, CBN ground, with split point Point cut: work´s specification with split point DIN 1412 C Point angle: 118° Step angle: 90° Ø-tolerance: work´s specification Surface: titanium-nitride coated Right hand cutting The CBN ground flutes guarantee quiet running and high cutting performance. The cone makes it easier to withdraw the tool from the material. 1 2 3 4 5 6 7 8 9 Drilling range inch 3/16 - 1/2 - 1/2 1/4 - 3/4 3/16 - 7/8 1/2 - 1 7/8 - 1 3/8 3/8 - 1/2 7/8 7/8 - 1 1/8 1/8 7/8" 1 1/8" Ø inch 1 7/32" 1 1/4" 3/8" 1/2" 1 3/8" Packing unit: in plastic tubes of 1 Size no. Ø inch No. 6 Total length inch Steps Shank Ø inch Article no. 3 1/8 3 1/8 2 3/4 3 1/4 3 1/4 3 1/4 1 7/8 2 19/32 3 7/64 6 13 9 12 9 5 2 1 2 1/4 101 701 T 101 702 T 101 703 T 101 704 T 101 705 T 101 706 T 101 707 T 101 708 T 101 709 T 1/4 3/8 3/8 3/8 3/8 1/4 3/8 3/8 No. 7 Price / each € Ø inch 7/8" No. 8 Step drill set HSS, CBN ground, spiral fluted in steel case Description Article no. Step drills HSS spiral fluted, sizes 0/9, 1, 2 101 026 Price / set € No. 101 026 E Step drill set HSS Co 5, CBN ground, spiral fluted in steel case Description Step drills HSS Co 5 spiral fluted, sizes 0/9, 1, 2 Article no. Price / set € 101 026 E No. 101 026 T Step drill set HSS-TiN, CBN ground, spiral fluted in steel case Description Step drills HSS-TiN spiral fluted, sizes 0/9, 1, 2 Article no. Price / set € 101 026 T Step drill set Combi HSS, CBN ground, spiral fluted in steel case No. 101 027 Description Article no. Step drills HSS spiral fluted, sizes 1, 2 + 1 milling drill HSS Ø 6,0 mm x 90 mm 101 027 - 61 - 7/8" Ø inch Price / set € 1 1/8" No. 9 1.4 Step drills Step drills HSS, CBN ground with 3 cutting edges 1.4 Point cut: work´s specification Point angle: 118° Step angle: 90° Ø-tolerance: work´s specification Surface: bright Right hand cutting Ø mm 4,0 mm 5,0 mm 6,0 mm 7,0 mm The deep-ground flutes of step drills with 3 cutting edges guarantee absolutely chatterfree working. The reduced load of the cutting edges allows a higher feed rate especially for soft materials like non-ferrous metals. The cone makes it easier to withdraw the tool from the material. 8,0 mm 9,0 mm 10,0 mm 11,0 mm Ø mm 4,0 mm 12,0 mm 6,0 mm 8,0 mm 10,0 mm 12,0 mm 14,0 mm Packing unit: in plastic boxes of 1 16,0 mm No. 0/9 18,0 mm 20,0 mm Ø mm Size no. Drilling range mm Total length mm Steps Shank-Ø mm 0/9 1 2 4,0 - 12,00 4,0 - 20,00 4,0 - 30,00 65 75 100 9 9 14 6 8 10 Article no. Price / each € 4,0 mm 6,0 mm 8,0 mm 10,0 mm 12,0 mm 14,0 mm 16,0 mm 18,0 mm 20,0 mm 22,0 mm 24,0 mm 26,0 mm 28,0 mm 30,0 mm 101 350-9 101 351 101 352 No. 1 No. 2 Step drill set HSS, CBN ground with 3 cutting edges in steel case Description Article no. Step drills HSS with 3 cutting edges, sizes 0/9, 1, 2 101 326 Price / set € No. 101 326 Milling drills HSS, HSS-TiN Point cut: helical point Point angle: 118° Surface: bright / TiN Right hand cutting For drilling and milling contours into wood, sheet metal, plastics and other thin-walled materials. Twist drill at the front, turning into a milling cutter with chip breakers. No. 101 201 Packing unit: in plastic boxes of 1 Ø mm Total length mm Material Article no. 6,0 8,0 6,0 8,0 90 90 90 90 HSS HSS HSS-TiN HSS-TiN 101 201 101 202 101 201 T 101 202 T - 62 - Price / each € No. 101 201 T Step drills Step drills HSS, CBN ground Point cut: without point Step angle: 90° Ø-tolerance: work´s specification Surface: bright Right hand cutting Ø mm The CBN ground flutes guarantee quiet running and high cutting performance. The cone makes it easier to withdraw the tool from the material. NEW Drilling range mm Total length mm Steps Shank-Ø mm 20 30 40 12,0 - 20,00 20,0 - 30,00 30,0 - 40,00 66 78 78 9 11 11 8 10 10 Article no. High carbon High carbon Alloyed struc. steel struc. steel steel up to 700 over 700 up to 1000 N/mm² N/mm² N/mm² 101 361 101 362 101 363 No. 0/5 No. 0/9 No. 1 No. 2 No. 3 No. 4 No. 5 No. 6 No. 7 No. 8 No. 9 No. 10 No. 11 No. 12 No. 13 No. 14 No. 15 No. 16 No. 17 No. 20 No. 30 No. 40 Size No. 1 No. 2 No. 3 No. 4 No. 5 No. 6 No. 7 No. 8 No. 9 up to 4 up to 4 No. 30 No. 40 Cast iron Cast iron up to 250 N/mm² over 250 N/mm² up to 4 up to 4 CuZnalloy brittle CuZnalloy tough Alalloy up to 11% Si Thermoplastics Duroplastics up to 4 up to 4 up to 4 up to 4 up to 4 30 20 20 15 10 60 35 30 20 15 Cutting spray Cutting spray Cutting spray Air Air Air Air Cutting spray Water Air Ø mm r.p.m. r.p.m. r.p.m. r.p.m. r.p.m. r.p.m. r.p.m. r.p.m. r.p.m. r.p.m. 4,0-12,0 4,0-12,0 4,0-20,0 4,0-30,0 6,0-38,0 6,0-26,8 4,0-32,0 6,0-32,0 5,0-28,0 6,0-30,5 6,0-37,0 4,8-10,7 6,0-25,0 6,0-32,0 6,0-40,0 5,3-30,5 6,5-32,5 5,3-38,5 6,5-40,5 12,0-20,0 20,0-30,0 30,0-40,0 Ø inch 3/16 - 1/2 1/8 - 1/2 1/4 - 3/4 3/16 - 7/8 1/4 -1 1/4 - 1 3/8 5/32 - 1/2 5/32 - 7/8 5/32 - 1 1/8 2389-796 2389-796 2389-478 2389-318 1592-251 1592-357 2389-299 1592-299 1911-341 1592-313 1592-258 1990-897 1592-382 1592-299 1592-239 1803-313 1470-294 1803-248 1470-236 796-478 478-318 318-239 r.p.m. 2006-752 3009-752 1505-502 2006-430 1505-376 1505-274 2407-752 2407-430 2407-334 1592-531 1592-531 1592-318 1592-212 1062-168 1062-238 1592-199 1062-199 1274-227 1062-209 1062-172 1327-598 1062-255 1062-199 1062-159 1202-209 980-196 1202-165 980-157 531-318 318-212 212-159 r.p.m. 1337-502 2006-502 1003-334 1337-287 1003-251 1003-182 1605-502 1605-287 1605-223 1592-531 1592-531 1592-318 1592-212 1062-168 1062-238 1592-199 1062-199 1274-227 1062-209 1062-172 1327-598 1062-255 1062-199 1062-159 1202-209 980-196 1202-165 980-157 531-318 318-212 212-159 r.p.m. 1337-502 2006-502 1003-334 1337-287 1003-251 1003-182 1605-502 1605-287 1605-223 1194-398 1194-398 1194-239 1194-159 796-126 796-179 1194-149 796-149 955-171 796-157 796-129 995-449 796-191 796-149 796-119 901-157 735-147 901-124 735-118 398-239 239-159 159-119 r.p.m. 1003-376 1505-376 752-251 1003-215 752-188 752-137 1204-376 1204-215 1204-167 796-265 796-265 796-159 796-106 531-84 531-119 796-100 531-100 637-114 531-104 531-86 663-299 531-127 531-100 531-80 601-104 490-98 601-83 490-79 265-159 159-106 106-80 r.p.m. 669-251 1003-251 502-167 669-143 502-125 502-91 802-251 802-143 802-111 Cooling lubricant Size up to 4 30,0 mm 31,0 mm 32,0 mm 33,0 mm 34,0 mm 35,0 mm 36,0 mm 37,0 mm 38,0 mm 39,0 mm 40,0 mm Price / each € Step drills - table of cutting speeds Vc = m/min Ø mm 20,0 mm 21,0 mm 22,0 mm 23,0 mm 24,0 mm 25,0 mm 26,0 mm 27,0 mm 28,0 mm 29,0 mm 30,0 mm Ø mm Size no. Sheet thickness mm 1.4 No. 20 Packing unit: in plastic boxes of 1 Material 12,0 mm 13,0 mm 14,0 mm 15,0 mm 16,0 mm 17,0 mm 18,0 mm 19,0 mm 20,0 mm - 63 - 4777-1592 2787-929 2389-796 1592-531 4777-1592 2787-929 2389-796 1592-531 4777-955 2787-557 2389-478 1592-318 4777-637 2787-372 2389-318 1592-212 3185-503 1858-293 1592-251 1062-168 3185-714 1858-417 1592-357 1062-238 4777-597 2787-348 2389-299 1592-199 3185-597 1858-348 1592-299 1062-199 3822-682 2229-398 1911-341 1274-227 3185-627 1858-365 1592-313 1062-209 3185-516 1858-301 1592-258 1062-172 3981-1794 2322-1047 1990-897 1327-598 3185-764 1858-446 1592-382 1062-255 3185-597 1858-348 1592-299 1062-199 3185-478 1858-279 1592-239 1062-159 3605-627 2103-365 1803-313 1202-209 2940-588 1715-343 1470-294 980-196 3605-496 2103-290 1803-248 1202-165 2940-472 1715-275 1470-236 980-157 1592-955 929-557 796-478 531-318 955-637 557-372 478-318 318-212 637-478 372-279 318-239 212-159 r.p.m. r.p.m. r.p.m. r.p.m. 4012-1505 2340-878 2006-752 1337-502 6018-1505 3511-878 3009-752 2006-502 3009-1003 1755-585 1505-502 1003-334 4012-860 2340-502 2006-430 1337-287 3009-752 1755-439 1505-376 1003-251 3009-547 1755-319 1505-274 1003-182 4815-1505 2809-878 2407-752 1605-502 4815-860 2809-502 2407-430 1605-287 4815-669 2809-390 2407-334 1605-223 1194-398 1194-398 1194-239 1194-159 796-126 796-179 1194-149 796-149 955-171 796-157 796-129 995-449 796-191 796-149 796-119 901-157 735-147 901-124 735-118 398-239 239-159 159-119 r.p.m. 1003-376 1505-376 752-251 1003-215 752-188 752-137 1204-376 1204-215 1204-167 For your notes 1.4 - 64 -
101351 价格&库存
很抱歉,暂时无法提供与“101351”相匹配的价格&库存,您可以联系我们找货
