101083P
101083P
    RUKO
    RUKO - 101083P - Drill Bit, 8 Step, 6 mm Bit Size, 120 mm Overall Length, ULTIMATECUT Series
101083P 数据手册
STEP DRILLS NEXT GENERATION NEXT GENERATION NEXT GENERATION NEXT GENERATION NEXT GENERATION NEXT GENERATION 90 Point angle HSS 2 118° HSS 2 118° HSS 2 HSS 2 118° HSSE Co 5 2 118° HSS 2 HSS 2 118° HSS 3 118° HSS 2 HSS 2 118° HSS 2 118° HSS 2 max 3,5 mm 2 92 - 95 C 4,0 - 12,0 6,0 - 40,0 101 050-5 101 097 96 - 99 C 4,0 - 12,0 6,5 - 32,5 101 050-9 E 101 534 E 96 - 99 C 4,0 - 12,0 6,0 - 40,0 101 050-5 T 101 097 T 96 - 99 C 4,0 - 12,0 6,0 - 40,0 101 050-5 F 101 097 F 96 - 99 6,0 - 18,0 101 068 F-1 100 C 4,0 - 12,0 4,0 - 30,0 101 050-9 H 101 052 H 101 C 4,0 - 12,0 4,0 - 30,0 101 050-9 TH 101 052 TH 101 C 4,0 - 12,0 4,0 - 30,0 101 061 101 063 101 C 3/16 - 1/2 7/8 - 1 1/8 101 701 101 709 102 C 3/16 - 1/2 7/8 - 1 1/8 101 701 E 101 709 E 102 C 3/16 - 1/2 7/8 - 1 1/8 101 701 T 101 709 T 102 C 3/16 - 1/2 7/8 - 1 1/8 101 701 F 101 709 F 102 4,0 - 12,0 4,0 - 30,0 101 350-9 101 352 103 C 5,3 - 30,5 6,5 - 32,5 101 090 101 093 104 C 5,3 - 30,5 6,5 - 32,5 101 090 T 101 093 T 104 C 5,3 - 30,5 6,5 - 32,5 101 090 F 101 093 F 104 12,0 - 20,0 30,0 - 40,0 101 361 101 363 104 130° C Page 101 082 P 101 084 P Shank 6,0 - 12,0 6,0 - 27,0 Point cut Material thickness max 10,0 mm Cutting edges HSS Article no. GENERATION 118° Ø mm NEXT max 4,0 mm GENERATION max 4,0 mm NEXT max 4,0 mm GENERATION 2 max 4,0 mm NEXT HSS max 4,0 mm GENERATION 118° max 4,0 mm NEXT 2 max 2,0 mm GENERATION HSS max 4,0 mm NEXT 118° max 4,0 mm GENERATION 2 max 4,0 mm NEXT HSSE Co 5 max 4,0 mm GENERATION 118° max 4,0 mm NEXT 2 max 4,0 mm GENERATION HSS max 4,0 mm NEXT 4 max 4,0 mm GENERATION HSS max 4,0 mm NEXT Surface Range and applications overview: Material 04 118° 118° 118° 118° Explanation of symbols from page 314 Steel (N/mm2) < 1100 Steel (N/mm2) < 1300 < 900 N/mm²
101083P 价格&库存
很抱歉,暂时无法提供与“101083P”相匹配的价格&库存,您可以联系我们找货
